Question about Seagate 750GB ST3750640AS SATA300 16MB 7200RPM (Bare drive) Hard Drive
How to format an unallocated section on a hard drive in windows 7 pro. computer management shows the following: system reserved - ntfs 100 mb healthy (system, active, primary patition) (c:) - ntfs 210.18 gb healthy ( " " " " ) 488.36 gb unallocated I am using windows 7 and this is a new load.
3dmaster
  • 183 Answers
SOURCE: new sata 500 gig hdd - ST3500320AS SD15
Dear Customer,
thats problem regardiong to your windows version if its working proerly when newly installed than may some files delted during some uninstalation can do all this stuff,
so try to install new full version windows xp than try ,i m sure about that your problem will fixed up.
THNX
Posted on May 17, 2008
dante777
  • 623 Answers
SOURCE: seagate sata hdd error
Quick format removes files from the partition, but does not scan the disk for bad sectors, while a normal format does that. That's why the formatting takes so much longer.
You should definitely check your drive for bad sectors by issuing "chkdsk /r" in the command line, which scans for and attempts the recovery of bad sectors.
If there is a bad sector somewhere, your system might crash at any time and it might be at a very inconvenient moment.
If you find bad sectors, you should consider replacing the drive
Posted on Mar 02, 2009
  • 8 Answers
SOURCE: disk management does not see working hard drive
Are the Hard drives setup as master & slave ? (plastic jumper on Hard drive at cable)..... is the Hard drives connected on separate ide cables... if they are ide drives ?
Posted on Mar 30, 2009
damien729
  • 221 Answers
SOURCE: seagate free agent go 250 gb external / macbook pro os x tiger
If you can see the drive in Applications --> utilities --> Disk Utility, then you will be able to reformat it in the Mac OS format and read it.
Good day, Damien
Posted on May 30, 2009
SOURCE: How do I format my
you can only do 30GB
Posted on Sep 27, 2011
How to partition the HD into two portion with OS windows 8?
Hold the Windows logo key on your keyboard and press "R" (Winkey+R). This will launch the Run the utility. Type "diskmgmt.msc" inside the text box and press Enter. This will open the Windows Disk Management utility. This is where you can format, create, and delete hard drive partitions.
order to create a partition, you need unallocated space. Unallocated space is basically disk space that is not formatted or not prepared for storage. Formatting is the act of preparing a disk space for storage. It similar to building a foundation for a place to be inhabited. Thus, unallocated space is just useless blank space with no "foundation" or format.
To create unallocated space, you need to shrink your hard drive. When you shrink your hard disk, the remaining space becomes unallocated.
To do this, right-click your main drive and select "Shrink Volume."
You will then see the region of unallocated space (shaded black). Remember, this space is not yet usable.
Now you need to create "foundation" or format for the unallocated space. This will allow for the space to become usable.
Right-click the region of unallocated space and select "New Simple Volume."
This will launch the New Simple Volume Wizard. This will guide you through the installation process.
ssign the disk a drive letter. You can choose any drive letter that is not currently in use.
Select a file system for the disk. The file system is basically the type of format or "foundation" the storage device has. If you plan on installing a Windows OS to the partition select the"NTFS" file system.
Name the partition in the "Volume Label" text box. You can choose any name for your partition.
Now click "Finish" to create the new partition.
Regards
David
Sep 19, 2013 | Lenovo B590 6274 - 15.6" - Core i3 2328M -...
Is it possible to format a HCS725032VLA380 in NTFS ?
Absolutely...just make sure you have any data you want to keep backed up. If there's no data, then it's pretty straight forward.
  1. To format right click on My Computer (or just Computer in Windows 7) and select Manage.
  2. Go down to Storage and select Disk Management
  3. You'll see a list of drives connected to your system. If the drive you need to format doesn't have a partition, it will show as either Unallocated or Not Initialized.
  4. If it's not initialized right click on the drive and select to initialize it.
  5. Once complete, the box will show "Unallocated".
  6. Right-click on the box to the right of the drive listing (Disk X) and select New Partition.
  7. Accept all of the default parameters, or change the volume name it's up to you. You might want to select quick format to save some time.
  8. The formatting will start and will be busy until complete.
  9. Once the formatting is complete your drive will be accessible.
Jan 24, 2013 | Computers & Internet
How to install wins 8 on dell Inspiron netbook 1018
proceed according. God bless you
  1. Create a New Partition
    • 1 Launch the Disk Management tool on your computer running Windows 7 by opening the Start menu and typing "diskmgmt.msc" in the search bar. The Disk Management tool, showing all connected storage devices, appears.
    • 2 Pick the hard drive onto which you'll install Windows 8. The normal choice is Disk0, which is the primary hard drive. This disk should already show your C: drive, and possibly other items like recovery partitions.
    • 3 Verify the available free space on the selected disk. For most computers with no other dual-boot setups installed, the entire drive should be occupied, so you'll have to shrink an existing drive (like C:). If there is a section with a black bar titled "unallocated," then this represents free space not currently in use.
    • 4 Shrink your C: drive by right-clicking on it and selecting "Shrink Volume." The computer assesses and reports how much free space is available on the disk. You need a minimum of 16GB of free space to install 32-bit Windows 8 and 20GB of space for 64-bit Windows 8. Type either 160000 or 200000 in the "Enter the amount of space to shrink in MB" box. Increase that number if you want additional storage space for files and programs within Windows 8. Click "Shrink" to continue.
    • 5 Right-click on the new unallocated space and select "New Simple Volume." Leave the defaults, ensuring that NTFS is selected as the file system type. Give the drive a name, like "Windows 8."
    • 6 Insert your Windows 8 installation disc or USB drive into your computer. When the new drive is formatted, restart the computer and boot from your installation disc or drive.
    Install Windows 8
    • 7 Select "Custom" during the Windows 8 Setup initialization process.
    • 8 Select the new drive you created when the installation program asks you where you want to install Windows 8. Be sure to select the drive with the label you used for the new drive; if you install to the C: drive, you will overwrite your existing Windows 7 installation.
    • 9 Follow onscreen instructions to install Windows 8.
    • 10 Reboot after you install Windows 8, ensuring that you've removed any installation media. When the computer restarts, you are presented with a boot screen that lets you pick between Windows 7 and Windows 8.
Oct 18, 2012 | Computers & Internet
Adding 250gbhd to double my storage.Hdd in bios but not in "my computer"
Is this an internal or external drive? If it is an internal drive, you need to partition and format the drive. For Windows XP and later, this is available in the drive management service. In Windows 7, click Start > Control Panel > System and Security. Look in Administrative Tools and click on Create and Format Hard Disk Partitions. (Make sure that you have logged in as the administrator.) In the lower section of the window, the new hard drive should show (probably as Disk 1). Select the correct drive (it will probably say unallocated space). Click on Action > All Tasks to find the option to format the disc. If this drive will be used with the current computer or only with the recent Windows OS, format the disc in NTFS. Mac's have a similar utility but HFS is their current file system. If the drive will be used on multiple computers with different OS versions, format it in FAT32.
Other programs (Partition Magic, Partition Manager) will give you more options for formatting.
If this is an external drive, looking for the drive in Disk Management will let you check if the OS finds the disc but has a problem with the format.
I hope this helps.
Jun 07, 2012 | Computers & Internet
ONLY 650 MB OUT OF ONE TERABYTE lacie all terrain
For anyone else that runs into this issue, you don't need the EXE.
Follow the instructions on here to get to the Storage control panel area on your computer so you can view partitions:
http://www.ehow.com/how_5022760_check-partitions-hard-drive.html
Locate your LaCie drive, and delete the small partition that shows as "Healthy". Once you delete that, you should have a large "Unallocated" space. Format that normally using either FAT32 or NTFS. Your drive will now have its full allocation (which with a 500GB drive, should be around 465GB, give or take depending on the system accessing it).
Mar 31, 2012 | LaCie Rugged All-Terrain (301017) Hard...
I have a 8gb UltraSpeed flash drive. I cant access it.windows says I need to format it before I can use it.I had try alot of solution But it says it is write protected.I try to format it using different...
I think you should try this out(In your windows operating system lyk.WIN 7) follow the steps:- 1. plug in your flash drive 2. ON DESKTOP OF YOUR COMPUTER OR LAPTOP 3. right click on my computer > then click on manage option 4. THEN A NEW WINDOW(computer management) WILL BE OPENED 5. then choose DISK MANAGEMENT in storage 6. then you'll see your hard disk partition and a separate partition of your 8GB flash drive 7. that (8gb partition will be unallocated) 8. right click on that partition(unallocated one) 9. then create a simple new volume..... by following these steps you'll be able to fix your problem HAVE A NICE DAY
Aug 15, 2011 | Transcend 32GB ExpressCard SSD, MLC 32 GB...
Hello i' have a question abaut the format of the samsung hm500jj usb Please send me the steps of the format with the acer aspire 7720g and operating sistem window 7 tnx for now! Attend your respons,...
  1. Open Computer Management by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33.png, clicking Control Panel, clicking System and Maintenance, clicking Administrative Tools, and then double-clicking Computer Management. 18abb370-ac1e-4b6b-b663-e028a75bf05b.png If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
  2. In the Navigation pane, under Storage, click Disk Management.
  3. Right-click an unallocated region on your hard disk, and then click New Simple Volume.
  4. In the New Simple Volume Wizard, click Next.
  5. Type the size of the volume you want to create in megabytes (MB) or accept the maximum default size, and then click Next.
  6. Accept the default drive letter or choose a different drive letter to identify the partition, and then click Next.
  7. In the Format Partition dialog box, do one of the following:
    • If you don't want to format the volume right now, click Do not format this volume, and then click Next.
    • To format the volume with the default settings, click Next.
  8. Review your choices, and then click Finish.
Apr 10, 2011 | Samsung HM500JI 500 GB SATA Hard Drive
I have a Lacie 320gb external harddrive which was connected to an eMac and is now connected to an Acer laptop. I've reformatted it as NTFS and it shows up in disk management as healthy but does not appear...
you need to give it a drive letter
A more reliable way to do this is via the computer management console
Start / Control Panel / Administrative Tools / Computer management / Disk Management.
Your drive should show up in here.
if it says Healthy and just above that gives the file system eg. NTFS or FAT32 etc it should be fine but may just need a drive letter.
If it does dot say any of those then right click on it and use the format option. Select how you want to format it (NTFS for XP is preffered)
and then tell it to do a FULL format. and also give it a drive letter !
It may take a while but I find it more reliable overall.
If it didn't have a drive letter then right click and use the Change Drive Letter and Paths option, then add a drive letter and use the one it offers.
I like to re-boot just to be sure windows sees it properly
Aug 28, 2009 | LaCie Hard Disk 320GB with Hi-Speed USB2.0...
WD My Book doesn't show up in My Computer
If yours is like mine it's because someone whipped it without reformatting it. Go to Contorl Panel, System and Maint., Admin Tools, Comp Management, Disk Management. You should see the drive there, but unallocated. Right click on the unallocated portion at the bottom of the screen and choose Simple Volume. Follow the Wisard, choose Quick Format and you've formated your Ex. Hard Drive. It should come up in My Computer now. Congrats!
Mar 15, 2009 | Western Digital My Book Essential Edition...
My External USB 250hard drive shows error Drive is not accessible
You most likely need to delete the partition on your external hard drive, then create a new one and format it again. You will lose the data on your external hard drive.
1. Go to the Control Panel, click on Administrative Tools, click on Computer Management, then Disk Management. (You will need Administrators rights to carry out the following tasks)
2. On the lower Right Panel select the External drive, this will be displayed as Disk 1, Right click on this drive (MAKE SURE YOU DON"T SELECT THE C: DRIVE which will be displayed as Disk 0)
and then Delete the partition.
3. This drive should then be Unallocated, Right Click on this drive and create a New Partition.
4. Then select Primary partition.
5. Check that the maxium disk size matches close to 240000(MB) you about 10+MB in the formating process
6. Click Assign the following drive letter (let the computer select this.
7. Chick Format the partition with the following settings
File System = NTFS
Allocatin unir size = Default
Volume label = "name of your choice eg. BACHUP DATA"
DON'T TICK Perform a quick format & Enable file & folder compression
8. Click Finish
Nov 27, 2008 | Western Digital 250GB MyBook External USB...
Seagate 750GB ST3750640AS SATA300 16MB 7200RPM (Bare drive) Hard Drive Logo
119 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
