Question about Poulan Garden
How do I tighten chain on Model Poulan 2050. Can't seem to get tight enough.
    President:
  • 704 Answers
Hello JNorth, It's possible that the chain tensioner and the little "cog" that fits into the bar, has slipped out and isn't letting you properly tension/tighten the chain and bar.
To check this and get the bar & chain properly tightened, you'll need to remove the two (2) chain break/guard cover nuts on the side, so you can clean out the gung under it and reposition the chain tightener back to engage the bar.
Once you have the tightening screw and cog turned so it can engage the bar, make sure the chain is on the bar, in the groove, and using a screwdriver or the provided chainsaw multi-tool, turn the tensioner screw until you get most of the slack out of the bar and chain. Now you can put the chain break/guard cover back on and only hand tighten the nuts snug. Now continue adjusting the chain tensioning screw until the chain is snug, while holding the tip of the bar and chain up (I find using a small piece of 2 X 4 placed under the tip of the chainsaw makes this easier to do).
Now properly tension the chain so that it is snug by not overtight. You should be able to turn it by hand (wear gloves so as not to cut yourself!)
Now tighten the chain break/guard cover nuts all the way and again, check for movement by hand.
Here's a link to a free downloadable manual for your model Poulan chainsaw, just look at the upper right side of the page. Once you click on the link, you have to answer a few questions (basically giving your rating of the chainsaw) to get the download. Save a copy to print it out.
Please refer to page 6 and 7 to see the manufacturers recommended steps, as I've outlined above, for checking and tensioning the bar and chain.
http://safemanuals.com/user-guide-instructions-owner-manual/POULAN/2050-_E
I hope you find this Very Helpful and best regards!
Posted on Nov 18, 2009
    President:
  • 2,220 Answers
Hold the nose up!
How do I tighten chain on Model Poulan 2050. - c581361.gif Chain Adjustment
  1. Make sure the chain brake is off (gloves will protest your fingers).
  2. If necessary, loosen the bar nuts that are clamping the clutch cover in place (or whatever holds the clutch cover and bar on). They don't need these really loose - finger tight will do.
  3. Ease the tension adjustment until the chain is obviously loose.
  4. Using one hand, hold the nose of the bar up.
  5. While holding the nose up, adjust the tensioner so that the center of the chain just touches the underside of the bar, add a touch more.
  6. Continue holding the nose of the bar up & tighten up the bar nuts / bolts / quick-release system. HTH
Lou
  • dontbother10
    dontbother10 Nov 18, 2009
    If you are having difficulty fitting the drive links into the bar groove, the chain binds or rides up when rotated there may be burrs on the drive links. These often form if the chain comes off while at speed.
    Use a file on the flats of the drive links to remove burrs. HTH
    Lou
How to tune the carb on 1950le poulan chain saw
H I ONE quarter turn L one turn then adjust the idle.
Oct 10, 2014 | Oregon Poulan/Poulan Pro 12" Chain Saw...
Poulan chain saw 2050 2.0CL
The Poulan Chainsaw 2050 is a 36cc model with a 14" bar and chain.
Sep 02, 2014 | Poulan Garden
How to adjust a poulon pro chain saw 46cc 20" chain tighting
First, I'd read the manual if in doubt. No matter the type of adjuster, tool-less or not, you loosen the bar nuts, tighten the adjuster until the chain just touches the bar on the bottom (while holding the bar nose up) then tighten the bar nuts. Chain should move easily.
Re Poulan chain tightening. Be sure it's oiled and sharp, of course.
Aug 20, 2014 | Poulan Pro Chain Saw 46cc 20"
I have a Poulan 295. I needed to replace the chain. It is a 20" chain. There is bar oil in the resevoir. The chain will not stay on the bar (it seems loose even when fully tightened). I replaced...
If you replaced the bar AND the chain, you'll need to make sure the chain is the correct chain for the particular bar you've used. If you're only replacing the chain, you need to make sure the chain has the same # of drive links as your old chain (maybe one or two more, if you've had some removed because of chain stretch).
On that particular model, for a 20" chain, you could have a 78 OR 80 drive link chain (drive links being the part of the chain that rides in the groove of the bar). The correct drive link count is determined by the bar you've installed and should have been made clear by whoever you purchased the bar from. Some brands use an 80 drive link chain, but MOST use the 78 drive link chain.
If the bar you purchased uses the 78 drive link chain, but you have an 80 drive link chain, then no matter how far out you adjust the bar, you may not get the chain tight enough. PartsBuggy shows a listing of which bars use the 78 drive link chains here.
Aug 29, 2011 | Poulan Pro Chain Saw 46cc 20"
Poulan Pro Chainsaw chain tensioner is junk -- chain now goes from tight to falling off in 1 cut. Model PP4620AVX. Looking for more foolproof mechanism!
Hammy if you scream loud enough Poulan may foot the bill for this.
Poulan “PP4620AVX” IPL (exploded parts list)
We are going to replace this page 2; item 70
http://weborder.husqvarna.com/order_static/doc/NIUS/NIUS2009/NIUS2009-PP4620AVX-545103410-952802169.pdf
Poulan “PP4620AVHD” OM
http://weborder.husqvarna.com/order_static/doc/NOUS/NOUS2005/NOUS2005_545047502.pdf
Poulan “PP4620AVHD” IPL
http://www.ordertree.com/modelinfo/PWE/PP4620AVHD-Gas-Saw/75.PP4620AVHD-Gas-Saw.1.59.1.html
With this; “Handle, Chassis & Bar Assembly” print; item 67; ChainBrake Assembly; $21.83.
You also need;
  • Item 68; Bar Mounting Nut; $0.56 each (need 2) and
  • “Engine Assembly” print; not illustrated; part number 545006011; Scrench; $9.75.
This is the configuration professionals have used forever. The only thing to remember here is to hold the nose of the bar up when adjusting and tightening the bar nuts.
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank You for using FixYa.
Apr 18, 2010 | Poulan Pro Chain Saw 46cc 20"
JUST BOUGHT A 20'' POULAN PRO TENSION A CHAIN
the adjustment screw near the end of the bar( next to the engine) needs to be turned in to tighten the chain just don't tighten it to much
Apr 04, 2010 | Poulan Pro Chain Saw 46cc 20"
I am having a problem with the chain on my poulan chainsaw. the chain comes loose or comes off after just a few cuts. am i missing something or could it be a malfunction
It sounds like the chain is not being set quite tight enough. Turn the tightening screw until the chain barely lifts above the bar when pulling on the middle of the chain.
May 11, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan pro with tooless chain tightening - chain will not stay on
i have a 4620 poulan that had the same problem. use it for 10 minutes, spend 15 minutes reinstalling the chain. i sent poulan an email threatening to sue them and they decided to send me the parts to change it over to the old style for free. try poulan.com
Mar 04, 2009 | Poulan Pro Chain Saw 46cc 20"
Chain becomes very loose with little use
the problem with torqueing the nuts is that it's not enough tighting.i tell my customers that you need to tighten them as tight as you can get them.the nuts will not vibrate loose then.don't worry about breaking the studs they are very hard.
Feb 19, 2009 | Poulan Pro Chain Saw 46cc 20"
Poulan Farmhand chainsaw chain tightens too tight for motor to move chain
Make sure the chain is not over tightened. When adjusting the tightness, ensure there is at least 1/8" of looseness by pulling up on the chain in the middle of the bar and releasing it. If a chain becomes overheated because of leaning on the saw when the chain is dull, or lack of oil on the chain, it may expand in the track and not turn freely.
Marlyn, Mountain, Ont. Canada
Oct 02, 2008 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Garden Logo
248 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
