Question about Uniden CXAI5198 Corded Phone
How do I set speed dial phone #s? - Uniden CXAI5198 Corded Phone
Found owners manual online
Posted on Nov 19, 2009
How do I set up speed dialing on my phone DECT1560 ?
ou can save up to 8 phone numbers in your speed dial book. The speed dial keys go from 2 to 9. When you place a call, our system prompts you to "enter the phone number you wish to dial". You just press the appropriate speed dial key followed by the pound sign (#) and your call goes through. No long numbers to enter any more!
If you set a speed dial for our access number on your phone machine, you have to press three keys only to complete a dial - as easy as "1-2#"! That's it!
For example, you can set your parents' phone number as speed dial key 2 and your friend's number as key 3. After dialing the access number from your phone, you will press 2 then # to reach your parents, or press 3# to reach your friend. Nothing could be easier!
Speed Dial set up Instructions:
Dial the access number, wait for prompt.
Enter PIN number, wait for prompt.
Dial: "#" "2" "#" [a speed dial number: 1-9] "#" [destination number] "#". The system will confirm the number.
Example: [#] [2] [#] [5] [#] [011-888-88-88-88-88] [#]
Use Speed Dial:
Dial: [speed dial key (1-9)] "#"
Hope this will help to solve the problem....
Aug 18, 2011 | Uniden Cell Phones
How do we change the phone numbers on the speed dial
Feb 27, 2010- Speed dial numbers 001 -255 (256-279 are personal speed dial entries) are system wide speed dial numbers and are changed in system programming. System programming is done on M7310,M7324 and T7316 set only.
Enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say Terminals&Sets.
The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the next key 3 times(bottom right arrow).
The display should say Sys speed dial.
Press the show key (top right arrow)
The display should say speed dial#:--
enter in the speed dial number you wish to program.
Press the show key (top right arrow) .
The display should show the existing speed dial number
Press the chg key
Enter in new telephone number
press ok when finished
repeat for remaining speed dials
Press the release key when finished
Apr 16, 2010 | Nortel T7316E 2-Line Corded Phone
CECT KA08-how to set up speed dial?
Follow the following:
>Call Center at the bottom
>General call settings
>03 Speed dial
>Check that "enable speed dial" is on
Then
>02 Set number
>You will see a list of "empty"
>Touch on the one you want to assign a number
>Edit
>this takes you to your phone book
>Choose a name from your list and save it to your speed dial.
>To call the number from your speed dial list, click on the "Phone dial" icon, and hold the number down. For example, is the number 2 is home, hold 2 down until you see it dial and there you have it.
Hopes this helps
Jul 29, 2009 | Dual Electronics CECT P168 Cellular Phone
Program and use speed dial numbers
speed dial must set at port ' 00 ' or 000
to check, use display phone, press #402 or #401
speed dial code are from 60 to 99
to set press speed dial , redial , speed dial code eg. 60, press 9 follow by destination number asn redial to confirm
to use speed dial to call press speed dial short key follow by speed dial code or *60
May 26, 2009 | Toshiba Lands Phones
How to set a speed dial and delate old speed dial no
Just figured this out (though a lot of people seem to have tried giving an answer without seeing if it works.
Setting speed dial numbers doesn't allow you to choose one for the voice mailbox. Go to Messages -> Voice Mailbox Number (option 12). There you can change the number.
May 21, 2009 | Nokia 1100
How do I set up and use speed dial on a Toshiba dkt2010-sd
what system u using??
if DK series go to phone port number "000" (at phone press Intercom #401 to check port), check at every phone with display phone.
- to set speed dial press REDIAL SPEED DIAL standard speed dial   code 60 or 600, follow by 9+destination number, REDIAL to confirm.
- to call press speed dial + code or press * + speed dial code (*60 / *600)
- if CTX/CIX must set at adminsrater phone. #66, speed dial code number (200-999), 9 follow destination number #
- to dial press *200...
Apr 22, 2009 | Toshiba DKT2020SD Phone
How do I set up speed dial for a Toshiba DKT2010-Sd phone
what system u using??if DK series go to phone port number "000" (at phone press Intercom #401 to check port), check at every phone with display phone.
Nokia 6085 how to speed dial
To assign a number to a speed dialing key, select Menu > Address Book > Speed
dial list, and scroll to the speed-dialing number that you want.
Select Assign or, if a number has already been assigned to the key, select Options >
Change. Select Find and the contact you want to assign. If the Speed dialing function
is off, the phone asks whether you want to activate it
FOR MAKING CALL
Assign a phone number to one of the speed dialing keys, 2 to 9. Call the number
in either of the following ways:
• Press a speed dialing key, then the call key.
• If Speed dialing is set to On, press and hold a speed-dialing key until the cal
Dec 22, 2008 | Nokia 6085 Cellular Phone
Speed dial not working
Maybe because the speed dial service is not on.
Click.
Menu -> Settings -> Cal Settings -> Speed Dial -> On.
then try.
Nov 14, 2007 | Nokia 6030 Cellular Phone
Pre-set dial numbers
Pick up the handset / handsfree button, hit the SET/SAVE key, punch in the entire phone number you wish to program to speed-dial, hit the SET/SAVE key again, hit the speed dial key you want to save to (0-9). To actually use the speed-dial key once set, you have to pick up the handset / handsfree, hit the AC key followed by your speed dial (0-9) I know this seems unusual and you have to do it relatively quick, but it's the only way that works properly on this phone unit. Cheers!
Mar 31, 2007 | Innovage 69420210126 Phone
Uniden CXAI5198 Corded Phone Logo
46 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
