Question about Dryers
Why is my indesit dryer blowing out cold air - Dryers
  • 3,463 Answers
It is more than likely that the heater element, and or the thermostat/s are faulty.
The only sure way to determine the cause of the prob, is to test them with an electric test meter.
Please rate my soution.
Thanks.
Posted on Nov 19, 2009
Is70c indesit condenser blowing cold air
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101[]][
Aug 10, 2011 | Dryers
Is70cuk dryer only blowing cold air, all filters are cleaned water emptied
the one shot stat has blown on the heater. remove rear heater cover and two smaller screws holding element to the cover. you will see the two round stats. both must be replaced. part numer is 1703200, aprox £25.
Jul 06, 2011 | Indesit IS70C Electric Dryer
My indesit is70c tumble dryer is just blowing cold air,
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 07, 2010 | Indesit Dryers
I have a indesit is31vu tumble dryer and it started to blow cold air i think it must be the thermostat hust wondered is it easy to change or am i better off buying new one?
There is more than 1 thermostat, and it could be the element.
TThe parts are located at the rear of the dryer behind a removeable panel.
You need a meter to test them with.
Hope this helps.
Jan 18, 2010 | Dryers
Indesit 1560v wont dry cloths it is just blowing cold air . rear vent is clear
you must replace the thermostats on the element.
Oct 24, 2009 | Dryers
Tumble dryer running but only blowing cold air
If your dryer is turning then things are not so bad. If a dryer is not heating then you need to check a few things.
First disconnect the power to the unit. Then you must check the heating element and the limits which are mounted on the heating box.
Remove one lead from the element and check for continuity thru the element. If you have continuity then check the limit by measuring for continuity, again you must remove one of the leads. This should solve your problem
Sep 15, 2009 | Dryers
My Indesit IS70C is only blowing cold air. It was fine this morning. Do we have to remove the silver back to get to the thermostat?
Remove the lower rear panel, there you will see the heater element and thermostats, make sure the heater is o/k, and replace both stats.
Plz rate my solution
Thanks.
Dec 18, 2008 | Dryers
Indesit dryer only blowing cold air
You need to check heater and thermostat(s), with a multimeter.
If o/k then could be faulty timer.
You did not state wether it was a vented dryer, or a condenser dryer., as this makes a difference to the solution, because other components are involved.
Dec 08, 2008 | Dryers
1s70c indesit condenser dryer still blowing cold after elements replaced
This is most probably due to the thermostats at the rear of the heater failing. There are 2 and must be replaced as a pair.
Jun 17, 2008 | Indesit WA 125 Front Load Washer
Dryers Logo
47 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
