Question about Microsoft Excel for PC
Counting How do I count only the "1"'s in a single row of mixed numbers?
  • 2 more comments
  • Kymber Jan 11, 2008
    COUNTIF(insert cell range,1)
    I had originally want to count "colors", while keeping a running total as the spreadsheet was edited. My macro would count the colors, but not keep the running total. - Plan B is not as "impressive" on my spreadsheet, but I can make the number system work.
  • Kymber Jan 14, 2008
    That would work if I wanted I didn't have so many rows to do this for - so thanks for trying. I did come with an answer on my own. COUNTIF(insert data range,1). As I stated in the comment above - this was my plan B. It is not as impressive as counting the colored cells in each row, but I couldn't figure out how to keep a running total as my spreadsheet expanded... Plan B works. Thanks, again.
  • Heather Bjorkman
    Heather Bjorkman May 11, 2010
    did you fix your problem?
    Problem Solver:
  • 23 Answers
Do a find and then you will see how many 1's if that is what you search for.
Posted on Sep 20, 2014
  • 265 Answers
If it isn't too big of a spreadsheet, you can sort it on the column which has the numbers in it, which will put all the 1's in the top of the stack and you can then select just the cells with 1's in them and Excel will count the number of cells that you currently have selected. The number will show up in the Name Box (above cell A1) as: R2 X C2 (for two rows and one column currently selected). Rows are horizontal and columns are vertical.
Posted on Jan 11, 2008
Tip
Features found on most bill counting machines
Bill and coin counters come with a host of different functions and features that when you learn and master the them you will be a bill counting ninja! There are many terms that you will hear when getting started with your coin counter but the the most important ones are hopper capacity, error detection, adding mode and batch counting.
The hopper is the part of the bill counter that holds the bills that are going to be counted. Bill counting machines have a limit to how many bills the hopper can hold this is known as the hopper capacity. Usually instructions come with a number for how many new bills the hopper can hold, but if you are going to be counting older and crumpled bills that number will be cut in half. So if the capacity is 100 new bills then the number of old bills with around 50.
when you are counting bills its important to watch for error detection on the machine. These errors can be for a feeding error, detection of fake bills or a problem with the sensors in the machine. Machines with error decors are on the higher end but they make troubleshooting easier as well as give you confidence in their counting.
These last two features can be combined into one key feature that makes counting bills with a machine a breeze. Adding and batch counting modes. In a regular mode on a bill counting machine the counter will reset when you finish counting a stack, but if you enable adding mode the counter will continue to count from where the last stack left off.
Batching on the other hand is good for when you have a huge stack of bills like lets say $5's and you want them to be split into stacks of 10's. You can set the machine to batch count so it will stop counting after 10 bills have passed through. This is really good for if you are stacking bills into increments that are easy to count.
on Nov 14, 2013 | Retail Supplies
Describe the difference between binary semaphores and counting semaphores.
Binary semaphore is a semaphore with the integer value ranges over 0 and 1 whereas the counting semaphore's integer value ranges over unrestricted domain. Binary semaphores are easier to implement comparing with the counting semaphore.
Binary semaphore allows only one thread to access the resource at a time. But counting semaphore allows N accesses at a time.
The 2 operations that are defined for binary semaphores are take and release.
The 2 operations that are defined for counting semaphores are wait and signal
Sep 25, 2016 | Computers & Internet
Counting numbers
Counting numbers are any numbers that you can count with. so 1 2 3 4 5 6. This doesn't include decimals or fractions or the number 0.
Jun 07, 2011 | Opt-6 Products MathTasks
All relays and what there for
Looking over the fender at the fuse box, you see three rows of relays. The first row, closest to the engine, has three relays. Below that are two rows of six relays each. Counting from the left:
Row One 1) Fuel Pump Relay 2) Main Relay 3) Oxygen Sensor Heater
Row Two 4) Horn 5) Tail/Fog Lights 6) Low Beam 7) High Beam 8) Emergency Flasher 9) Heater/AC Blower
Row Three 10) Rear Defogger 11) ABS System 12) ABS Pump 13) Radiator Fan High Speed 14) A/C Compressor 15) Radiator Fan Low Speed
#15 in the lower right corner of the fuse box is the one that seems to take the most grief and fail the most often.
Mar 05, 2011 | 1990 BMW 3 Series
I need a wiring diagram for the ignition control module and distributor on a 2.8 litre v6 motor
OKAY STANDING IN FRONT OF ENGINE ON LEFT SIDE CYLINDERS FACING YOU IS 1 3 5 ON RIGHT SIDE DRIVER SIDE CYLINDERS FACING YOU IS 2 4 6 LOOKING AT DISTRIBUTOR CAP NUMBER 1 SPARK PLUG ON CAP IN THE 9 OCLOCK POSITION YOUR NUMBER 5 SPARK PLUG ON DISTRIBUTOR CAP IN 6 OCLOCK POSITION .STARTING AT NUMBER 1 SPARK PLUG ON CAP COUNTING CLOCKWISE COUNTING 1 2 3 4 5 6 THATS YOUR SPARK PLUGS WIRES ON CAP TO ENGINE PLUGS. 6 PLUG WIRE ON CAP IS AT 7 OCLOCK POSITION.
Feb 07, 2011 | 1988 Pontiac Firebird
Situations about real number system
The Real Number System The real number system evolved over time by expanding the notion of what we mean by the word “number.” At first, “number” meant something you could count, like how many sheep a farmer owns. These are called the natural numbers, or sometimes the counting numbers.
Natural Numbers or “Counting Numbers”
1, 2, 3, 4, 5, . . .
  • The use of three dots at the end of the list is a common mathematical notation to indicate that the list keeps going forever.
At some point, the idea of “zero” came to be considered as a number. If the farmer does not have any sheep, then the number of sheep that the farmer owns is zero. We call the set of natural numbers plus the number zero the whole numbers.
Whole Numbers Natural Numbers together with “zero”
0, 1, 2, 3, 4, 5, . . .
Jun 22, 2010 | Google Chrome
What is the meaning of whole numbers?
no decimals (1.5, .56) no fractions (1/2, 1 3/4)
whole numbers are just whole numbers
1, 2, 3 and on 9,10,11 .....
not
1.5, 2.5, 2.356
1 1/5, 2 2/6,3 1/5
Jun 19, 2010 | Mathsoft StudyWorks! Mathematics Deluxe...
Jumpers guide Maxtor 2B020H1 20Gb Slim IDE 3.5'' Hard Drive
Maxtor jumper as follow:
looking at the connector top row 5 pins, buttom row 4 pins.
the single pin on the top row is index pin.
master jumper is located between top 2nd pin and 1st buttom, counting from the left.
slave has no jumper on any of the pins.
cable select jumper is located between top 4th and buttom 3rd pin. counting from the left.
Apr 24, 2009 | Computers & Internet
Open Questions:
See all Microsoft Excel for PC Questions
Microsoft Excel for PC Logo
103 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
