Question about Riso Office Equipment & Supplies
Image on master (Risograph GR3770) is not centered when burned.
On our Risograph gr3770 when we burn a master from the computer thru a rip the imprint on the master is not centered when burned. The image is shifted so when it is printed on the letter size paper it is so far down that even adjusting the print position all the way to the right, the image is still not centered. What could be causing this and how do I correct the situation?
4 Suggested Answers
checkitright
  • 1362 Answers
SOURCE: Paper tray will not lift on a GR3770
either the motor is not turning to lift it up or the gear is broken, do you hear the motor turning when the tray is pushed in? take the tray out and look in the back to see if there is anything blocking it also.
Posted on Sep 16, 2008
  • 55 Answers
SOURCE: Risograph GR3770 - cannot pul out the drum, Error
This solution is ONLY for pulling out the drum.
Open front door. If you look at the metal housing below the drum you will see a plate mounteg with two screws. Get it off and you will see a small lever. Turn it right to loosen the drum. Be extremely careful when pulling out the drum. If the drum is not in zero-position it might be a bit difficult (e.g. have a look at the master clamp). Please note that it may be difficult to insert the drum again.
Posted on Apr 27, 2011
aviral_srms
  • 1216 Answers
SOURCE: After making 'Masters' my RISO
sounds like you have a print head alignment issue. you should be able to correct that from the printer menu.
Posted on Jun 26, 2011
How do remove jammed master from the disposal unit on a risograph GR3770?
This model is pretty obsolete, finding someone to service it will be difficult, and most will only promise to attempt it and not warranty the work, never the less, its what I recommend. If you must attempt it yourself, I recommend a set of picks from Menard's (around $5 for a set, they look like dental picks) and an exacto knife and then cut the master free in small pieces.
most riso techs who are trained on these will do a partial disassemble. If this were an RZ or an EZ I'd be willing to try talking you through that. I don't recommend it if you're a novice on these though. They're much crankier.
Jul 14, 2014 | Riso Office Equipment & Supplies
How do i remove jammed master in disposal unit in a riso gr3770?
On the back there is a box where the masters are used, remove and check for any play between the master and the shipping box. Open trough the green lever the lid covering the box used masters and check the part that carries the master used for the box, if there pieces or entire master mired in this piece. Let her go trough the alavacas extremities. Make sure the drum is with the clamp without damage, because it holds and releases the master of the carregamanto and unloading of master. Remember these tips without seeing the machine and if you have knowledge of the equipment inside are a little difficult, but be able to get there. I hope I helped you.
Jul 14, 2014 | Riso RZ220 Duplicator
Risograph GR3770 - cannot pul out the drum, Error code T14. How can I pull it out :)? thanks
Jan 03, 2011 | Riso RZ220 Duplicator
Anybody know if Risograph GR hd black ink is ok for use in Riso FR machines?
Short answer is no. RISO GR HD ink is only compatible with a GR3770, a 600 dpi machine.
Mar 05, 2010 | Eagle Signal Br1 30min Reset Timer
Error Code T14 on Riso GR3770
The machine is not alinged. I had that code this evening and the guy came here and in no time he fixed it. is your drum going in the machine? if so then turn off the machine and while pushing down the clear/reset button turn the machine on
Oct 16, 2008 | Riso RZ220 Duplicator
Sep 16, 2008 | Riso RZ220 Duplicator
Riso GR3770 Paper Jam, Check paper feed
Sounds like you forgot to plug the High voltage transformer or a sensor back
Dec 11, 2007 | Office Equipment & Supplies
49 people viewed this question
Top Riso Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Marius Chiriac
paulfvincent
Are you a Riso Office Equipment and Supply Expert? Answer questions, earn points and help others
