Question about Garden
What size chain do i need for a poulan pro 35cc no pp3516 ?
    President:
  • 2,220 Answers
Take it with you to a local chainsaw shop, they can make one to fit. Chain size depends on drive links
what size chain do i need for a poulan pro 35cc no - e982cd8.jpg The new chain will have the same number as your existing chain. 1 or 2 drive links won't have much impact on the size of the loop; it will impact you ability to tension it. HTH
Lou
Posted on Nov 18, 2009
  • shanecookson Sep 18, 2011
    for the pp3516avx, it 's has 56 drive links
  • 24 Answers
The chain goes by bar length
What size of chainsaw file do I need for poulan pro PP4620AVX
hi there susan brown6
if your chain is a 3/8 lo pro chain the file will be 5/32nd ------- and if its a 0.325 size use a 3/16th file -------- or if its a 3/8 -0.58 chain use a 7/32nd file
but its more likly to be either 5/32nd( for 3/8 low pro chain ) or 3/16 th for .325 chain
cheers
pauly46
Sep 10, 2011 | Poulan Pro PP4620AVX 46cc Gas Chainsaw...
How can I get a instruction manual for my Poulan Pro 35cc chain saw. I have miss placed mine.
Check the link below for your model. If not available as a download, the contact info is on the left side of the page. Poulan is now owned by Husqvarna, BTW.
http://www.poulan.com/node7925.aspx
Aug 27, 2011 | Poulan Garden
Replacing gas line
Your fuel lines are routed like the schematic below. I suggest you replace the filter, all hoses (2 different sizes), and the purge button (bleeder).
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
May 07, 2010 | Poulan ES350 16" Chain Saw
Remove chain guard
The OM for your saw is is the best guide. You can download a replacement here (disengage the chain brake first - pull handle aft):
Poulan.com/CurrentModels
http://www.poulanpro.com/node4043.aspx
Type just the model numbers (choose the suffix after the list is provided).
A broad adjustment procedure can be found here. Completely remove the bar cover, slide the bar against the drive sprocket, remove the chain from the bar.
http://www.fixya.com/support/r4146814-chainsaw_chain_installation
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Apr 10, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
What size chain does the Poulan Pro 4218 use?
It is an 18" chain .The user manual is at http://www.chainsawsdirect.com/manuals/PP_3516_4218_Man.pdf
On page 6 the part numbers for the bar and the chain are shown
Hope this helps .. if so, pls leave feedback, if not - let me know!
Jan 24, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I have a poulan pro 35cc chainsaw. The coil spring was not doing its job. Now I can't get it back in.
Coil it up real tight. Try putting mini cable ties on to hold it together while you slip it into the housing then snip them off carefully with side cutters. It can be tricky. I use ties for lawnmowers, outboards and all small engines.
Hope this helps.
Rob
Sep 21, 2009 | Poulan Pro Chain Saw 46cc 20"
Need manual for a Poulan Pro 35cc 16 inch Chain Saw that I can download online... Purchased, used, from a friend without a manual. A manual in PDF format would be awesome and much appreciated... I have...
Your manual can be purchased here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The IPL can be downloaded free.
I haven't found any source for the operator's manual. We cannot help you further with this question.
Jul 02, 2009 | Poulan Garden
PULL ROPE WON'T RECOIL AND IS FULLY OUT
Possible broken return spring or excess junk in starter mechanism. Remove starter assembly to check out.
Jun 27, 2009 | Poulan Pro Chain Saw 46cc 20"
Open Questions:
Garden Logo
158 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
