Question about Compaq Presario 900 /1500 Series EVO n1015v 15. inch LCD Display -285520-001 (285520001) CD-ROM Drive
Compaq Presario 1245
Yesterday my laptop worked fine and today when I turn it on, it gets stuck on "starting windows". I have left it on for hours and it still doesnt work and I have turned it off and back on several times. Do you know how I can fix this?
Thank you,
Lynn
  • slynnvan Jan 10, 2008
    I put a game in and part of the screen froze up but I could go into the start menu and work around it. I restarted my computer hoping it would clear out the frozen part but this is what happened instead.
  • Anonymous Oct 16, 2008
    I have the same problem with my computer and I have tried everything and still nothing has changed
  • 589 Answers
Have you recently added any software?
It seems to be looking for a driver, etc and can't locate it, so it is "hanging".
Posted on Jan 10, 2008
Update
get a windows xp/7/8 disk and insert it into notebook then boot from cd drive with default button usally f9 or escape then install new windows by following instructions
May 09, 2013 | Compaq Presario 1245 PC Notebook
Compaq Presario CQ56 will not start
squeeze the left side below the keyboard from bottom to top.not the keyboard.do this while it is off then turn back on should work
Jul 01, 2012 | Compaq Presario CQ56-115DX Laptop
My laptop is completely dead, fine yesterday. Today no lights, sounds nothing. I tried removing the battery , unplugging no response. Thanks,
Remove the battery for at least 3 minutes... Then put it back and then plug in the charger and switch on the charger. If the battery is completely drained, it would take a while for the charging to initiate. Please have patience and leave it on charging even though without the charging indication for at least an hour. After that still if the charging indicator doesn't lit, then its definitely your charger or laptop. You will need to take it to a service centre in that case.
Nov 03, 2011 | Compaq Presario 2170US Notebook
How can i connect my compaq presario 1245 laptop to my cable modem via my wireless or wired router?
You can hook it up with a Ethernet cable from modem to laptop or if you have a wireless network setup at home you should be able to see your wireless network your laptop click on it and whala!! connected.
Feb 25, 2011 | Compaq Presario 1245 PC Notebook
I have been using presario CQ50 compaq laptop, it was working fine but as time went on the laptop felt as though it was starting to overheat and would randomly turn off, i wasnt sure if maybe it was the...
are you going to spend hard cash on this junk
its old and worth Zero
now
try a new battery, oops those are expensive.
i see working
presario CQ50
for $30 working
not working worth nothing
its worth at best the cost of potted plant.
why fool with it>? or spend cash on any COMPAQ.?
got to "GOODwill" fine a 10 year or newer system.
best advice of all that. one that works too.
Mar 28, 2017 | HP Compaq Presario 730US Notebook
Compaq Presario CQ60-215DX. Doesn't start
You will need to buy a new battery, there is no way old one will be OK. To see if it works, remove battery, and use wall adapter ONLY, PC should work fine. If not maybe Flat CMOS, replace, If replace and still NO go.must be bad motherboard (maybe try charge battery 5 hours left alone)
Mar 27, 2010 | Compaq CQ60-215DX Notebook
Compaq Presario V6000 rebooting blank screen
I am almost sure that it is a motherboard. When all of the lights stay solid and it seems to start, but shuts off is most likely the motherboard. You can save the data if you get a proper enclosure for the hard drive. You can call Compaq support to make sure that those signs are the motherboard.
Jun 30, 2009 | IBM ThinkPad T40 2373 Notebook
Presario V2000 - Does not turn on..
Hi
Have you tested your Power Adopter, it is working if yes check the battery, This may be the problem
Boopathy
Aug 10, 2008 | HP Compaq Presario V2000 Notebook
you could try booting on battery instead of mains and see what happens, also could the screen be switched off ? If you have access to another monitor, you could try plugging it in to see if the video output is ok. ( some laptops have a facility to switch off the screen display for security etc )
Jan 04, 2008 | Compaq Presario 900 /1500 Series EVO...
Compaq Presario 1245 doesn't start up
Most laptops have a video connector that you can use to connect you laptop to an external monitor. connect an external monitor to your laptop and see if anythig comes up on the external monitor.Your laptop has a key to switch between it's own screen and the external monitor.When you use the external monitor ,you'll have to use this key to switch to the monitor.Your battery should'nt matter if the laptop is running on AC.Let me know what happens and we'll go from there.
Jan 02, 2008 | Compaq Presario 900 /1500 Series EVO...
Compaq Presario 900 /1500 Series EVO n1015v 15. inch LCD Display -285520-001 (285520001) CD-ROM Drive Logo
76 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
