Question about Syntax OleviaL 527V 27 in. LCD Television
When I press the Power button the light on the button goes out but the tv does not function.
  • 834 Answers
This model has a history of power board failure check to see if you have a couple of puffed up caps these can like devices will have a puffed out top from venting the values are written on the side if this fix does not take care of it you need to try and order a new supply from shopp jimmy.com
Posted on Nov 18, 2009
I cant find my paper to my codes to my remote
Most remotes have a button called "code search". This is the method you will have to use. Press "code search". Wait for the light to come on. Let the button go. Press the desired function, i.e. "TV". The light will flash once. Make sure the unit is on. i.e. the TV. Press the power on/off button on the remote until the TV goes off, then quickly press the "Enter" button. That's it! Turn the TV back on with the remote, and start surfing. If you screw up, just start over. Do the same for the other functions such as "DVD".
Apr 01, 2012 | GE Televison & Video
How do i get my dishnetwork remote programed to my world tv
Janicesim851, Programming the remote is pretty simple.
We don't have any codes for a World TV available, though you can check out this link for more information
http://www.dishnetwork.com/SupportSection/remote-setup
In case you already have a code available I will provide both instructions to address the remote, and how to power scan the code in.
Addressing Remote to
TV: 1.) Press and hold the clear TV button until all mode lights light up.
2.) Release and TV light will be blinking.
3.) Enter code and press #. The TV button should flash 3 times.
4.) Try functions (Volume, Power, etc..) and see if working.
5.) If no function, repeat steps 1-4 with another code.
Power Scan to TV:
1.) With the TV on, press and hold the TV button (about six seconds) on top of the remote until all mode button backlights come on, then release.
2.) Press and release the red power button, then press the Up button once a second while pointing the remote at the TV. If the code for the TV comes up, it will power off.
3.) Press the POUND (#) button. If the code entered is valid for the remote, the mode light flashes three times. To verify the code works try several different functions for that equipment.
Let me know if you have any other questions!
Tommy Faust
DISH Network
Jul 21, 2011 | DISH Network IR Remote Control
My dish remote will not work with my naxa tv
Hey sevenwindham,
If the remote won't work it may need to be programmed to the TV. You can personally look at the steps in the link below, just look up the model of your remote. The steps to program your remote are also provided
Addressing Remote to TV:
If that doesn't work you can also try the Power Scan listed below.
Power Scan:
1.) With the TV on, press and hold the desired mode button (about six seconds) on top of the remote until all mode button backlights come on, then release.
2.) Press 0 then press STAR (*) and press and release the Power button.
3.) Press the Up button once a second while pointing the remote at the TV. If the code for the TV comes up, the TV will power off.
4.) Press the POUND (#) button. If the code entered is valid for the remote, the mode light flashes three times. To verify the code works try several different functions for that equipment.
If you have any other questions let me know!
Tommy Faust
DISH Network
Jun 15, 2011 | DISH Network IR Remote Control
Remote control not working with tv
The remote control is an acess to the TV device for example only from a distance. A remote controll for functionality would require to insert batteries a power source making possible communiction with devices requiring reception transmittion of signals. The remote is handheld pointed to the direction of TV requiring signal before button pressed woudl achieve response. a common button to start the remote control experience is pressing on the power button, that displays a signal on the TV. The TV should momentarily produce a sound and lighting effect,, and displaying on the dark screen a light blue screen. The initial signal response from remote control to TV indicates devices are functioning as required. Additional buttons on the remote controll could perform functions of several available.
The remote control has master button, menu on which every additional function is deriveable. Once the menu button is pressed with remote pointed in the direction of TV, should dicplay a list of options on the blue screen already established by power button. Every additional remote control device functionality is achievable by only after the first two buttons have been powered and pressed to display option results on a screen of TV. The remote controll buttons remaining perform complementary functionalities. For example, the arrow keys on remote control make movement of the options displayed on the screen, where a comfrimation button or identified as select allows to confirm remote functions displayed on the screen. A remote control could have several functionalities only accessible once made to display in screen. The three most common buttons on a remote control are First power button that powers on the TV, menu button that displays a list of functionalities on the powered on bl;ank blue screen, and using the arrow buttons on the remote would moves an indicator arround the screen area options. The selection button makes confrimation of the option.
Dec 02, 2010 | Philips Televison & Video
I had my dish installed to one tv. Now i switched out the tv for another one how do i get my dish to work with the new tv
Hi there this is Kimberly Escobar with DISH Network. I will be glad to help you by providing you the information that can help you. To program the DISH Network remote with your T.V we usually integrate a code into the remote that works with the brand of your T.V allowing our remote to function with the T.V itself by reading your post you don't mention the brand of your television but that is not a problem there is another way to help program your remote without having to use a code, it is called Power Scan in the Power scan procedure we search for the code that gets the remote to control your T.V. To perform a Power Scan your T.V must be on, you press and hold the T.V button until all the other buttons at the top light up in red. Once they light up in red you enter the number 500, you wait for the top buttons to go off and the you will press and hold once again the T.V button until the buttons light up again once you see them come on you will press the big red Power button on the remote once immediately after you press the big red power button you will press one repeatedly the channel up arrow one time after another until T.V turns off immediately after it goes off press the pound button (#) you should see the T.V button light up 3 times then try turning the T.V back on using the remote it should work. Here is this link http://www.dishnetwork.com/SupportSection/power-scan-instructions it shows you the procedures. I hope you find this helpful if you have any questions or need further assistance please contact us directly at 1800-333-DISH thank you.
Jun 25, 2010 | DISH Network IR Remote Control
I have dish network and a new rca tv with dvd the
You can power scan for the code.
Turn ON the electronic device you want to program the remote to control.
Press the Mode button( sat,tv,dvd,aux) on the remote until the appropriate mode light is flashing.
Press the Power button. The mode light will stop flashing and stay lit.
Press the Up or Down arrow button to set the remote to the next code. The Down arrow button scans backward and the Up arrow button scans forward.
When the correct code is reached, the device (whether a TV, VCR, or other) will turn off.
Press the pound key button to store the code in the remote control memory. If the code is valid for your remote, the mode light will blink 3 times.
Turn the device back ON by pressing the Power button.
Press sat mode key once you power back on the tv to be able to operate the receiver box.
Try some other functions to make sure you have the correct code. Occasionally the Power button may work when others do not.
If the other buttons work you are finished.
If the other buttons do not work, repeat the previous steps. The scan will resume from the last code stored.
The mode light will flash rapidly when the scan has returned to the starting point and all codes have been tested for that mode. The remote control may not control some device models.
Mar 11, 2010 | DISH Network 322 DTV Receiver
Child lock will not allow my tv to turn on
i was programming my television by hand because i do not have a remote to my television and i accidentally set the child lock and now my tv will not turn on what can i do to fix my tvtv is on standby, standby light is on. can turn tv on with programable remote after pressing on button several times to set code on remote. press any function button and screen says child lock is on. can't get anywhere pressing any buttons, turn tv off with on/off button and tv goes back to stand by. don't have magnavox remote any ideas?
Jul 19, 2008 | Philips Magnavox 20MS3442 20" TV
Konka tv code
Try "auto search" with your remote. Normally you press the TV button and the "OK/Select" button simultaneously for about 3 seconds untill the TV light burns steady. Then press "channel up" one press at a time untill the TV turns off. When it turns off, then press "power" on your remote and if the TV comes back on, test the other functions such as volume and mute. If all functions work, then press the "TV" button one more time to save the code and then you are "in business". If functions do not work, then continue to press "channel up" untill the TV shuts off a second time. Then press "power" and test all functions. Continue repeating this until you find a code that enables all desired functions. Hope this helps.
Keever
Mar 04, 2008 | Televison & Video
Philips universal codes
If you dont have the codes for a philips universal remote you have to press code search and TV at the same time till the led light stays on. Then press the power button a few times untill the power turns your TV off, then press the OK button. After that the code should be in the remote.
Dec 07, 2007 | Philips Magnavox Learning Universal Remote
Syntax OleviaL 527V 27 in. LCD Television Logo
80 people viewed this question
Top Syntax Televison & Video Experts
Computer Repairing
Computer Repairing
Kolbrun...
Jaime Hernandez
Are you a Syntax Televison and Video Expert? Answer questions, earn points and help others
