Question about RCA L37WD12 37 in. LCD HDTV
I need to determine which part to replace to eliminate my ''flashing'' issues on model L37WD12YX1. Do I need to replace the power supply or some capacitors? The flashing happens when you power on the TV and it will not tune to digital stations, instead it flashes a blue field at the bottom with the statement ''one moment please''. Unplugging does not work. I suspect P/S safeguard features are not allowing the TV to power on fully. The issue is intermittent and occasionally the TV works perfectly. Lately, it has worked less frequently. It's hard to find RCA documentation to help me finish this repair.
  • 2 more comments
  • davesgonerun Nov 19, 2009
    Thanks again, Chu. That's the easier fix. When you say Main video board, I assume that Master means the same thing and that's what I need to change. I appreciate your suggestions.
  • davesgonerun Dec 10, 2009
    I replaced the main video board as you suggested, but the flashing problem persists. I think it's likely to be the power supply as I had suspected. Any comments?
    This is regarding my RCA L37WDE12YX1 issue that you commented on earlier.
  • 4,234 Answers
The power supply part number is: 272062 and is available for $116.39 from tritronicsinc.com with a core return refund of $30. This means that upon the return of the defective part, you will receive a $30 refund.
Hope this helps,
Dan
Posted on Nov 18, 2009
Testimonial: "At least now I know the correct part, which I did verify. Thanks 4 info. Need to confirm cause, though. Other guy thinks it's the video backlite board"
  • ABRsvcs Dec 10, 2009
    The "one moment please" message is generally posted during a startup sequence. Had the backlight circuit been the problem, you would not have seen the message at all. At best you would have seen one quick message before the backlight system shutdown and that is it. It does not recover. The startup" message will continue to be displayed during the startup sequence. Since this set "recovers" somteimes, I would lean toward the power supply as it seems to not completely startup properly. This can be as simple as the 5V line not being clean or the "kicker" capacitors starting to fail. In any case, I would start with the power supply board as I indicated before.
    Dan
  • RCA Master
  • 8,457 Answers
Ur video main backlight board the problem,must change,beacause u getting video intermitent.
Testimonial: "Good input, but how do I know it's not the caps on the P/S? Others seem to suggest this as cause. Thanks a lot. "
  • Chi Chu Nov 19, 2009
    Listen to me,if u have video some time it not the power supply.
  • Chi Chu Dec 10, 2009
    Ur tv might have to need both boards is the problem.Don't return the video board yet return it lateter for money back with 5% restocking fee.Buy the power board use it with ur old video board.don't work use both new power and video boards.
    Need both new boards to work sometime,one board damage the other so both is death.Because it has power sometime keep using it might have effect the power supply board also damage.
How to troubleshoot Bestec ATX-1956D Power supply to determine if it is the power supply or another computer component..computer will not power up green light on power supply goes dim but does not flash...
The power supply is very inexpensive and can most likely be bought from any of your computer retailers, Amazon - Just make sure to confirm the right model type of power supply. BEST to have it tested before replacing it. To make sure that is the issue.. Many computer shops will test for free.
Oct 06, 2011 | HP Bestec ATX-1956D 200w HP Part No...
Our Sony TV, model # KV-32S15 will not turn on. Is there a reset button or something we can try? The power is working...it just wont come on at all.
Unfortunatly there is not much we can do. You can try the old unplug for an hour or so to see if something may re set, but that does not work much of the time. Most likely you have an issue with your power supply and it will need to be looked at by a qualified tech to determin what the board is that went bad. Your power may be coming on but if the voltage is not there it will not allow the set to come on. Could aslo be as simple as a bad lamp. Do you get any flashing codes? if so look this up in the manual or googls the flashing codes to determine what the issue may be. Although Google can't give you an exact cause it may get you close.
Jul 10, 2011 | Sony Televison & Video
RCA 37" FLAT SCREEN NON STOP FLICKERING/FLASHING SCREEN
you need to remove main ckt, (m.board) some part need to re solder specially in hot area. (lost contact i one of the flickering problem you encountered.
Mar 26, 2010 | RCA L37WD12 37 in. LCD HDTV
Have hp compaq d530 problems turning on. Wont boot, showing 1 green flash when power button is depressed & thats it!,,,,, ASSISTANCE!!!!!!! johnhall248@yahoo.com
That is most likely a bad power supply but it could also be a bad mainboard. You can find replacement power supplies for under $50 so try that first.
Mar 18, 2010 | HP Compaq Evo d530 PC Desktop
Power button blinks and then goes blank. the power on the computer was turned off immediately and the computer never powered down properly.
had the same problem, its actually an issue with the motherboard, but just to eliminate that possibility, just get your computer power supply (you will find this inside the tower) checked first by a qualified technician
Sep 25, 2009 | Dell Dimension 8400 PC Desktop
My tv wont switch on its clicking and led is flashing?
Your power supply will most likely need to be replaced which is actually a common problem in new electronics. If you have a relay next to the power supply, you can check with a multi-tester or ohmmeter to determine if relay is faulty. Most likely faulty capacitor in the power supply
Aug 24, 2009 | Samsung LN40A450 LCD TV
Will not power up and flashing red led
The power supply board may have failed, and or there is another board that has a short and must also be replaced. The boards are swapped out with known working boards to find out the ones that have failed.
These sets are not supported for service at the component level. The manufactures normally do not sell copies of detailed schematic diagrams for component level troubleshooting.
You can end up spending many hours trying to find failed components even if you were able to determine exactly the failed boards to start with. Then if you do find anything, chances are that you will not be able to purchase the parts unless they are of generic types.
I don't service this particular model, but they are very similar as far as the process of finding defective boards is concerned.
We swap out the bad boards using the process if elimination, then follow the set up procedures from the factory instructions that we have, and using their recommended calibration instruments.
What I can also tell you is that after the set is more than a year or two old, sometimes the replacement boards are no longer available. If the set is under warranty the customer gets a new set of the same or the closest possible model in the same brand name.
When out of warranty, if replacement boards are available the service cost is very expensive. Most of the time it is better to buy a new set when there is failure. If the set is more than a few years old there is a chance it will fail again.
Jerry G.
Apr 26, 2009 | LG RZ32LZ55 32 in. HD-Ready LCD Television
Rca L37WD12YX1
Rebuilt power supply by replacing capacitor on power board ,they are not swolen but if you pull and check them you will find out that they have changed in value.
Jul 14, 2008 | TruTech PLV16260 Television
Jvc dvd/hdd recorder model dr-mh20sek
OK changing the caps only resulted in proper filtering and voltage smoothing and did very little to solve your problem. Now what swollen caps are a sign of is an over voltage condition. what I would suggest because you may have a bad voltage regulator, is that you have to get a schematic and measure the voltage levels on the power supply to determine if they are correct or not. This will tell you if the regulator is bad or not. You do have a power supply problem you just have to determine where in the power supply. This can be done with the schematic and a voltmeter.
Sep 17, 2007 | Televison & Video
RCA L37WD12 37 in. LCD HDTV Logo
841 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
