Question about Xerox C2424 Copier
Workcentre c2424 Color Problem
The colors are coming out different than they used to.
ex. Things that look Red on screen come out orange.
  • ststesting Jan 10, 2008
    Thanks, I printed those out fromthe Xerox support site right after I posted this and am going to try it out. I'll let you know what happens.
    Thanks
  • ajsmiths May 11, 2010
    How do I download the color table to the xerox c2424. Link provided here is no good
    President:
  • 2,072 Answers
For Microsoft Windows 2000 / XP OS:
  1. Within an application, click on [File] on the toolbar, and then select [Print] from the menu. The Print window will be displayed.
  2. Click on the [Properties] button. The Properties window will be displayed.
  3. Click on the [TekColor] tab.
  4. Select a TekColor correction.
    NOTE: It may be necessary to try all the color corrections to obtain the required results.
  5. Click [OK] twice to send the print job to the printer.
For Microsoft Windows 98 / ME OS:
  5. Click on [Apply].
  6. Click [OK] twice to send the print job to the printer.
From the Apple Macintosh OS 9:
  2. From the General pull-down menu, select [TekColor].
  3. Select a TekColor correction.
  4. Click on [Print] to send the print job to the printer.
From the Apple Macintosh OS X (10.2.x and 10.3.x):
  2. From the Copies and Pagespull-down menu, select [Image Quality].
    NOTE: If the Image Quality option is not displayed on Copies and Pages pull-down menu for OS X, configure the printer with the correct PPD. See the procedure below, if needed.
To configure the Printer with the correct PPD:
The PPD file contains features a particular printer supports such as TekColor Corrections. In order for the TekColor Corrections and other printer specific features to be available, the correct PPD file must be specified when the printer is installed, or modify the setting following the procedure below.
  1. Open the appropriate utility: Print Center (for OS 10.2.2.x) or the Printer Setup Utility (for OS 10.3.x):
    1. Double-click on the [Hard Drive].
    2. Double-click on the [Applications] folder.
    3. Double-click on the [Utilities] folder.
    4. Double-click on [Print Center] or [Printer Setup Utility].
  2. Select the appropriate printer from the Printer list.
  3. Click on [Printers] on the toolbar, and then select [Show Info] from the menu.
  4. From the Name and Location pull-down menu, select [Printer Model]. The current PPD being used will be displayed.
  5. If the PPD displayed is incorrect (for example; the PPD is set to 'Generic PostScript Printer'), click on the pull-down menu, and select [Xerox].
  6. Select the corresponding PPD for the printer and then click on [Apply Changes].
    NOTE: Make sure the correct feature set is selected. For example; if the printer is a Phaser 8400DP, make sure the DP feature set is selected.
  7. Close any open windows.
  8. Make sure the Image Quality option is available on the Copies and Pages pull-down menu following the OS X procedure above.
Posted on Jan 10, 2008
  • 3 more comments
  • Rick Kasper Jan 10, 2008
    Another option
    The updated sRGB Display and sRGB Vivid color tables for the WorkCentre will help with the following issues that have been found with the original factory color tables.
    • RGB images contain too much yellow.
    • RGB image red shades are too orange or too light.
    • RGB object blues are too dark or aqua.
    • CMYK objects use the sRGB Display color table when the Automatic TekColor correction is used. After the updated color tables have been downloaded to the WorkCentre, the CMYK objects will use the Commercial Press TekColor correction when Automatic is used as the TekColor correction.
      NOTE: The new color tables will only take affect when using the Enhanced or High Resolution / Photo print quality mode.
    To update the RGB color tables:
    1. Click on the [Drivers & Downloads] link under the Product Resources menu on this window to download the updated color tables to a known location on the computer's hard drive. The color table update file is located under the Color Profiles section on the Drivers and Downloads page.
    2. After the file has been downloaded to the computer, send the file to the WorkCentre. See the Related Items below for additional information.
    Related Items:> See AlsoDownload PostScript and Other Files, Such as a Firmware Update File, to the Printer From a Computer With Apple Macintosh 10.x Operating System (OS)
    > See AlsoDownload PostScript and Other Files, Such as a Firmware Update File, to the Printer From a Computer With Microsoft Windows 2000 / XP / Server 2003 Operating System (OS)
    > See AlsoHow To Download PostScript and Other Files, Such as a Firmware Update File, to the Printer
    1. Print the Diagnostic Test Pages. The test pages will be used to determine if the printhead is performing properly. See the Related Items below for additional information.
    2. Evaluate the test pages. Using an ink stick, make a mark of color next to each of the colors printed on the page. If the colors do not match, that color will need to be purged from the printhead.
    3. Create a job consisting of a full page (100% fill) of the color not printing correctly. For example, if Cyan is actually printing Black, the job should be a solid fill of Cyan.
      NOTE: Set print quality to 'standard' and the TekColor Correction to 'none' in the properties of the print driver. This will allow the job to purge only the problem color. Other settings may cause the printer to use a percentage of the other ink sticks.
    4. Print approximately 50 - 100 pages of the job, as necessary, until the printed color returns to normal.
    5. Use the table below as a reference for the required resource files. See the Related Items below.
    Fill Color Resource Files
    Fill Color
    PDF Format (116KB)
    Zipped Windows File
    (443KB)
    Zipped Mac File
    (1.44MB)
    Cyan
    Cyan fill page
    Download EXE
    Download Mac file
    Magenta
    Magenta fill page
    Download EXE
    Download Mac file
    Yellow
    Yellow fill page
    Download EXE
    Download Mac file
    Black
    Black fill page
    Download EXE
    Download Mac file
    Related Items:> Go ToCyan Fill Page - Windows
    > Go ToMagenta Fill Page - Windows
    > Go ToYellow Fill Page - Windows
    > Go ToBlack Fill Page - Windows
    > Go ToCyan Fill Page - PDF
    > Go ToMagenta Fill Page - PDF
    > Go ToYellow Fill Page - PDF
    > Go ToBlack Fill Page - PDF
    > Go ToCyan Fill Page - Mac
    > Go ToMagenta Fill Page - Mac
    > Go ToYellow Fill Page - Mac
    > Go ToBlack Fill Page - Mac
    > See AlsoHow To Print a Diagnostics Test Page
    There are many options The Tek Color correction will most likely .
    Ok there are other things that can be done.
    That is the place to start.
    The red comming out orange is common.
    Sometimes you can also have bad ink sticks. The ink sort of cooks in the ink loader and becomes an off shade.
Phone Jack Wiring Problem
Your apartment is wired for two lines but you are using only one of the two. Your phone jack has red and green terminals for one line and yellow and black terminals for the other (old color codes). The four wires coming in to your apartment are actually two lines: orange/white and white/orange plus blue/white and white/blue (new color codes). One of those lines is active. Connect the orange/white wire to the red terminal and the white/orange wire to the green terminal. Plug in your phone and listen for a dial tone. If no tone, disconnect the first line and connect the second pair of wires. Listen again. DO NOT CONNECT ANY WIRES TOGETHER. Just follow the steps above. If you still don't get results, the phone company may not have activated your connection
Dec 30, 2012 | Lands Phones
I got a car stero with a cd player, the one I am taking out was
THe speaker wires from "new" radio will be in pairs ie;GREEN/ RED/ GREY / , They look like they are the same color but you will find a "tracer color" on one of the paired wires, ie plain GREEN / GREEN with a thin black stripe etc. The single Red will be Battery power the Orange will be Ign / accessory for the radio station memory. the other wires will vary but should be (possibly) panel illum/ power antenna/ aux power and ground wire . The radio will ground off the antenna connection .but should be connected at a later time . good luck .
May 03, 2010 | 1998 Chevrolet Lumina
I need a wiring color code for a pioneer deh p6400 stereo deck ex i need to know what each color goes to ex. which color is the constant which is right speaker + etc
constant is yellow . switched ignition is red. ground is black. amp remote is blue white. illumination is orange. speakers are gray front right. white is front left. green is rear left. purple is rear right. all speaker wires have a match with a black stripe.black stripe is negitive
Feb 07, 2010 | Pioneer DEH-P6400 CD Player
When I print color, the page has a lot of extra toner.
Start with this
  1. Make sure to set the Print Quality mode in the print driver to "Standard" and the TekColor Correction to "None" before performing the next step. This will allow the job to purge only the problem color. Other settings may cause the printer to use a percentage of the other ink sticks.
  2. Print approximately 50 - 100 pages of the document, as necessary, until the printed color returns to normal.
Next. This is on xerox.com downloads and drivers.
Jan 07, 2010 | Xerox WorkCentre M-24 Color Copier
Xerox Workcentre C2424.
You likely need modify darkness or the contrast.
Please take a look at the following from the Xerox site:
http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?St=458,E=0000000001668056207,K=4248,Sxi=0,Case=obj(6796)
Please let me know if this has been helpful or if there is anything else I can do. Thank you.
Sep 19, 2009 | Xerox WorkCentre C2424DN All-In-One Laser...
HP c3180 color printing problems
I would definitely start by printing a self-test page. With your model press and hold the Cancel button and then press the Start Color Copy button and then release both buttons. When this page comes out you should be able to identify the 4 different color sections...black, cyan, magenta and yellow. If any of these seperate areas are choppy or non-existant, you need to replace your cartridge. Here is a link that will show you examples of what you should/shouldn't see on the self-test report.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00661556&lc=en&dlc=en&cc=us&product=1146331&rule=25470&lang=en
Mar 30, 2009 | HP Photosmart C3180 All-In-One InkJet...
OKI C5800 color problems
Open the top cover. using a clean soft paper towel clean each othe glass vanes that hang down between the drums that are attached to the top cover. I use Alcohol, and a different paper towel for each vane.
Oct 25, 2008 | OKI C5800Ldn Led Printer
Xerox C2424 Copier Logo
762 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
