Question about Hoover Washing Machines
Washer will not drain or spin with pipe in specific washer drain but will if placed in the sink We have moved house and the new house has the usual pipework behind the washer. The machine will fill and wash but will not drain or spin with the pipework in place. So I tried putting the drain pipe into the sink and it will happily drain and spin.
  • kimheseltine Nov 18, 2009
    You were right !!! Thank you
    Scholar:
  • 62 Answers
Hi.
ok Did you say the drain hose was placed on a spiggot underneath the sink???
the appliance is obviously working as you have tried the drain hose in the sink.
You may find, if you unscrew the drain spiggot, there is a blanking cap. your previous owners put this in place to stop a huge water leak when using the sink
remove cap, refit hose and it should work ok.
Please let me know if I was right?
regards
aardvark Repairs
Posted on Nov 18, 2009
My garbage does not work.it makes humming sound for few seconds but does not rotate blades.
Use a broomstick handle to see if disposal blades rotate freely
If blades are stuck, use broomstick to wedge blades free.
If blades rotate freely, and motor does not turn on, then garbage disposal is broken.
Disposal mechanism cannot be disassembled for repairs.
Disposal will need to be replaced at some point.
I wrote tips for replacing disposal from days when I worked apartment maintenance.
Here are basic disposal parts:
1) Sink basket that connects to sink and is held with 3 screws from below.
2) Disposal body which connects to sink basket using metal ring.
3) Rubber washer between disposal and sink basket.
4) Dishwasher connection at upper part of disposal with a hose.
5) Electric wire from disposal switch connects to disposal near red reset button.
6) Tubular drain pipe connection on side of disposal
In apartment maintenance, we replaced disposal with same size and brand disposal.
That way we didn't have to change out sink basket or move pipes around under the sink.
How to: Disconnect 2 nuts on p-trap and trap falls loose.
Using hammer and screwdriver, rotate steel connector disk that holds disposal to sink basket, and disposal comes off.
Before installing new disposal.
Attach electric wire to new disposal, black wire to black and white to white, and push in red reset button.
Attach dishwasher tube to new disposal. Knock out plug inside dishwasher opening.
Lift new disposal up into place, and attach to old sink basket.
There is a rubber washer between disposal and sink basket, Use new washer.
Connector ring catches at three points, all three have to connect.
You can use bottle jack to lift disposal if you have problem.
Re-assemble tubular pipe.
Image shows direction for connecting new disposal.
If this is your home, you want new sink basket that comes with new disposal because it looks shiny and new.
Buy a tub of plumbers putty also.
Remove 3 screws that hold sink basket, remove basket and clean sink opening.
Put finger-size roll of plumbers putty around sink opening, and then push new strainer basket into plumbers putty.
Tighten basket from below, wipe away excess putty around sink opening.
Install new disposal as described above.
Tips for tubular pipes:
When taking apart tubular pipes, start at p-trap and take apart as few pieces as needed to do job.
On image above, loosen both upper and lower nuts, trap falls loose, and then work on disposal.
Any tubular drain pipe that gets moved while working under sink needs to be disassembled, cleaned and re-assembled.
Metal pipes have rubber washer >> always use new rubber washers.
Plastic pipes have plastic washers > plastic washers can be cleaned and re-used.
Plastic washers have flat side that goes toward nut, tapered side away from nut.
When reassembling tubular pipe, we use rectorseal on washers and joints.
Always slap a good amount all around washer just before pushing washer in place and attaching nut.
Rectorseal will ensure tubular drain pipes won't leak.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on disposal or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 21, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
The disposal will not work untill i take the wrench and turn it a few times then it works fine but the next day i have to do the same thing and it works.Can i lubricate it.???
Garbage disposal mechanism cannot be disassembled for repairs.
Jan 20, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
My badger 5 is leaking from the bottom around what seems to be the electrical cord opening. any suggestions
Your disposal is rusted out and needs replacement.
4) Dishwasher connects to upper part of disposal with a hose.
5) Electric wire coming from disposal switch connects to disposal near red reset button.
6) Tubular drain pipe connects to side of disposal
You might be able to buy time filling hole with epoxy or silicone caulk and let dry for 2 days.
10-year old garbage disposal had a good run.
When I worked apartment maintenance, we replaced disposal with same size and brand disposal.
Slap a good amount on washer just before pushing washer in place and attaching nut.
Also take advantage of fixyas phone service.
For a price, fixya expert speaks with you over phone while you work on disposal, or any do-it-yourself project.
Jan 11, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Making a metal grinding sound when turns on but dont feel any forks or spoons in it
Garbage disposals can get noisy and sound like they're eating spoons instead of banana peel.
You can put vacuum hose in sink opening and see if something is in there.
As long as disposal disk rotates freely, and disposal is not shaking around and causing pipes to leak, then you can use it until it dies.
Otherwise, the bearing is probably rusted, or something is loose. Disposals rust out and eventually freeze, or the motor slows down and overheats, or they rust a hole and water leaks under sink.
I wrote tips for replacing disposals that you can use when disposal gives out.
When I worked apartment maintenance, we replaced disposal with same brand and size disposal.
Rotate steel connector disk that holds disposal to sink basket, and disposal comes off.
Attach electric wire to new disposal, and push in reset button.
Attachment ring catches at three points, all three have to connect.
Remove old sink basket and clean sink opening.
For a price, fixya expert speaks with you over phone while you work on disposal.
Jan 08, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
How do you disassemble the Badger5 1/2 horsepower sink erator.model #5-81
The badger has two parts:
1) The sink strainer basket that attaches to sink with three screws visible from below.
2) The disposal which connects to sink basket with connector ring.
If you drop disposal loose from the sink, you can get spoons and other stuff out.
The disposal itself does not come apart for repairs.
I wrote tips for replacing disposal, which include information you might be able to use:
When I worked apartment maintenance, we replaced disposal with same brand disposal.
Push new disposal up into place, and attach to old sink basket.
There is a rubber washer between disposal and sink basket, use new washer.
On image below, loosen both upper and lower nuts, trap falls loose, and then work on disposal.
Jan 03, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
One of the grinder broke inside the unit, is this a replaceable part?
If disposal has loose parts inside, you have to replace the disposal.
If disposal still work and doesn't vibrate and loosen pipes under sink, then it's ok.
The don't sell replacement parts for disposals.
I wrote tips for replacing disposals:
Attach electric wire to new disposal.
Use new connector washer.
Jan 01, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Leaking from the bottom of the disposal in the connection area.
Disposals rust out and need replacement.
Check a couple things first.
Run paper towel around top of disposal to see if moisture is leaking from around sink basket or dishwasher hose connection. Then check where tailpiece connects on side of disposal.
If these places are dry, the disposal has probably rusted out.
I wrote instructions for disposal replacement:
That way we didn't have to change out sink basket or change pipes.
How to change disposal: Disconnect p-trap and tailpiece going into disposal.
Rotate connector disk clockwise that holds disposal to sink basket.
Push new disposal up into place, and attach to old sink basket with new connector disk.
Remove old sink basket and clean opening.
On image below loosen both upper and lower nuts, trap falls loose, and then work on disposal.
Apply good amount on washer just before pushing washer in place and attaching nut.
Apply rectorseal where lower p-trap comes together.
Add a comment
Dec 12, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Garbage Disposal is about 2-1/2 years old It is now no longer grinding up potato peels and clog every time! HELP--do we need a new one!!!
1/2 horsepower is the lighter weight model, and if you use it heavily, then it will not work like before.
Another thing to consider is whether the water is draining away completely while you're cutting.
If water and potato peels are both present, your p-trap and tubular drain may need to be cleaned.
Let's go through the whole thing: replacement, p-trap, tubular pipes, everything.
That way we didn't have to change out sink basket or move pipes around.
How to replace disposal body: Disconnect both nuts on p-trap. Remove p-trap and loosen tailpiece going into disposal.
If this is your home, you might want new sink basket that comes with new disposal because it looks shiny and new.
On image above, loosen both nuts on p-trap, trap falls loose, and then work on disposal.
Add a comment
Dec 10, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
While using our garbage disposal this afternoon, it went from grinding to humming. The blades do move freely, but the plate is very loose and tips. Is it possible to tighten the plate?
There is no way to tighten plate that I know of.
Maybe a clever welder could stick it back together, but the problem implies something underneath is rusted out or broken. The main thing is the cutter plate, and if disposal wobbles, it will loosen drain pipes under sink and cause dripping.
I wrote some tips for installing new disposal, and include them here since disposal will be replaced at some point.
That way we didn't have to change out sink basket.
How to replace disposal:
Make sure there's enough putty that it squeezes up all around sink basket.
Add a comment
Dec 06, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
I had to take it apart and now I can't seem to figure out how to put it back into the sink without it falling out.
If I understand correctly, your garbage disposal came loose from the sink basket.
The darker blue arrows point to the connector disc.
The connector disc rotates freely when garbage disposal is not connected to sink basket.
The trick is to lift the disposal into place with one hand.
Push up hard while keeping disposal
perfectly flat and aligned with sink basket.
Then use other hand to rotate connector until it catches on sink basket.
Before starting:
Disconnect the tubular drain pipes because these pipes will have to be re-sealed.
The electric wire and dishwasher hose can stay connected
If you are disabled or impaired, use a car jack or bottle jack to lift the disposal ... but go slow and don't lift the whole sink.
Now to reconnect the tubular drain pipes.
All drain pipes that were moved during the garbage disposal event should be taken apart.
Disassemble these pipes.
Clean the pipes and washers.
If washers are rubber, buy new ones.
If washers are plastic, re-use old ones after they are cleaned.
I use rectoseal on all tubular washers when installing pipes under the sink.
Coat the washers with plenty of rectoseal and the tubular drain pipes will seal first-time with no leaks.
Nov 11, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Washing Machines Logo
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
