Question about Sony FD Trinitron WEGA KV-27FS120 27" TV
Moved tv from 1 location to another
My Sony KV-27FS12 was moved from den (connected to cable box) to an upstairs bedroom (connected directly to cable jack in wall). Picture is very distorted, with intermittant "no signal" messages. Sound is OK when signal is picked up. This is the kicker: The tv works fine when we hook it back up in the den through cable box. The old tv from upstairs works fine when directly connected through the jack in the wall. Therefore, the Sony 27" is working ok, and the cable jack is working ok, but for some reason the 2 just don't jive.
  • diannasgifts Jan 10, 2008
    I have done all the fine tuning I can think of. Any other suggestions? Thanks
  • 149 Answers
Hi there, it may need some fine tune for the sony kv-27fs12 to be connected directly to cable jack wall. do some test. ty
Posted on Jan 10, 2008
  • Redentor Rey Jr
    Redentor Rey Jr Jan 10, 2008
    hello, see the cable connection connected directly to the jack wall, it maybe short enough to reached the connection to the tunner. your problem is someware near that cable. ty
I have a Sony kv-27fs12 the picture go out but you still can hear it and the standby light turns on first it flash 5 times then stop and do it again now flash continuously please if you know let me kn
Continuous blink once a second, no pausing - No reply from the jungle IC301 (data bus is busy, shorted to ground, or held high), IK video path is defective. If you want to know more about the blinking codes to Sony Brand TVs, check this link.
Jan 14, 2013 | Sony KV-27FS12 27" TV
Suddenly, "No Signal" display when cable box/VCR Connected to UHF/VHF Jack
How long have you owned the tv? You have two options though your best bet is to locate your nearest authorized service center to have the tv repaired.
Sep 14, 2008 | Sony KV-27FS13 27" TV
Using a video transmitter to extend your cable network to another TV in the...
When I first purchased a cable plan I only had one TV in my house and it seemed like a waste to get multiple cable boxes for TV that I had not yet purchased. When the prices came down on TVs I decided that it was time to get a set to go in my bedroom upstairs but I didn't have a cable box to connect to the set.
I could have gone out and spent a $100+ on a new bulky cable box that is not really all that pretty or I could get a video transmitter that will extend my signal to the upstairs TV set for around $50. Even though it takes a little bit of set up the results are great, I can even use the one remote on both television sets.
To set up your video transmitter first you have to take the transmitter and receivers out of the box and make sure that they are both set to the same channel. This will ensure that they will read each other. Then you take the cables that came with the transmitters and connect them to the back of the cable box, matching up the yellow, red and white cables to each other. Position the transmitter box so that it is lined up with the signal transmitter of the cable box.
Then you want to go upstairs to the second TV and connect the receiver to the back of the television set the same way that you connected the transmitter to the cable box. Take the remote from the set downstairs and it should have extended the connection of the cable box to both TV sets. Now you are able to control the cable box from upstairs and watch your stations on both TVs.
on Jan 22, 2014 | Televison & Video
When i try to turn on my sony kv-27fs12 keep turn off and blink 4 time a red led make a pause and keep blinking 4 times, what that could be?
Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
Vertical sweep failure. Check all the solder terminals to vertical output IC. If it do not help, replace that IC.
Jul 03, 2012 | Sony KV-27FS12 27" TV
My 27" Hitachi TV is about 14-15 yrs. Last night
could be alot of things but it comes on by hitting it makes me think either a bad relay or solder connection on the pcb board
Jan 29, 2011 | Sony FD Trinitron WEGA KV-36FS120 36" TV
No Power Sony KV-27FS12
IF the unit is completely dead (no standby light at all) then teh main fuse is most likely open. Try replacing that first. If the stnadby light is on, then when you attempt to turn it on, the light shouild blink. If so, the blinking should be a repeated count with a short pause between sequences. Post that count here as it will indicate what circuit has the problem. We will continue from there.
Feb 11, 2009 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Flyback serial?
The Sony part number for the flyback transformer is:
Oct 13, 2007 | Sony KV-27FS12 27" TV
most sony tubes bow in the corners, they just arent built that well
Apr 11, 2006 | Sony KV-27FS12 27" TV
Sony FD Trinitron WEGA KV-27FS120 27" TV Logo
139 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
