Question about Sony Cyber-Shot DSC-H1 Digital Camera
What means brk - Sony Cyber-Shot DSC-H1 Digital Camera
I solved the problem myself
Posted on Nov 19, 2009
I have a hard wired BRK Electronics smoke detector model 86RAC. replaced the battery but still beeps at the wall.
yep sometimes they do that-check to make sure the batteries are good(even new ones do not mean they are good-trust me i found out after many aggravating beeps0 Or also make sure they are in the right way -they may be backwards-being a home improvement specialist i have even done that myself
Sep 10, 2017 | Home
How do I remove base plate from a BRK 770MBX smoke alarm, tried twisting and it will not move
There is a locking key that must be removed first. Always remove primary power before working on these units. Here is the manual for your detector:
http://brk.co.uk/wp-content/uploads/2011/11/BRK_700-series-manual12.pdf
Sep 29, 2014 | Home
Write a program that creates a linked list of characters from a string entered by the user. (The string can be initially entered into an array if you wish.) Your program is then to move the second part...
Here's a brute-force C++ program to do it, assuming FixYa doesn't mangle the formatting. The last loop merely outputs the resulting list, since it makes no sense to just do all the work without showing the result.
#include <iomanip>
#include <iostream>
#include <list>
#include <string>
using namespace std;
int main()
int brk, j;
list<char> lst;
string str;
cin >> str;
for (string::const_iterator i(str.begin()); i != str.end(); ++i)
lst.push_back(*i);
cin >> brk;
j = 0;
for (list<char>::iterator i(lst.begin()); j < brk; ++j) {
lst.push_back(*i);
lst.erase(lst.begin(), ++i);
for (list<char>::const_iterator i(lst.begin()); i != lst.end(); ++i)
cout << *i;
cout << endl;
return 0;
Nov 01, 2013 | Televison & Video
I have a 1997 olds cutlass supreme and have no brk lites
sounds like a bad or loose ground wire, it would be located in the trunk near the tail light assembly, the other switch is for the cruise contro, it's what cuts the cruise when you hit the brakes.
Feb 09, 2010 | 1997 Oldsmobile Cutlass Supreme
Hi. My handbrake light is on solid. What does this mean? mazda 323f 1998 1.5
check the brake fluid level, if low the brake light will light, if fluid is full then you may have a bad switch for e-brake handle, unplug switch ,if light goes out then switch is bad. also when e-brk is released make sure handle goes all the way down. start there hope this helps.
Dec 24, 2009 | Mazda 323 Cars & Trucks
I have a 1993 jeep grand cherokee and need to know which fuse controls my windows
The cavity 26 fuse 30 amp/brk
More detail in ZJ-Secc-8W-Wiring-Diagrams
Hope helped (rated this). Good luck.
Oct 19, 2009 | 1993 Jeep Grand Cherokee
BRK smoke/co2 detector - won't stop beeping
sometimes the alarms are ganged to other apartments .. that's so if there is a fire in one apartment then others are alerted as well .. so the low battery warning could be from a neighbor ... also there may be a common ceiling space that will allow you to hear your neighbors detector .. at any rate someone around you has a low battery in their detector .. if they are ganged then that may be an apartment management maintenance item ..
Sep 19, 2009 | Kitchen Appliances - Others
2005 grand caravan radio fuse
gen. under hood are for engine electronics. check inside left of brk. pedal, on end of dash panel.
Jul 26, 2008 | 2005 Dodge Grand Caravan
Sony Cyber-Shot DSC-H1 Digital Camera Logo
191 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
