Question about Panasonic Panafax UF-885 Plain Paper Laser Fax
Panafax UF-885 flashing UF-885 (AU) message
Our Panafax UF-885 is flashing this message: UF-885 (AU). The manual said to replace the battery (CR3032) and reset the time. I replaced the battery but the flashing did not stop. We can not use the fax.
  • brooksli Nov 19, 2009
    I did put in a new battery. But that didn't fix the fax.
    Problem Solver:
  • 7 Answers
Yes there is a batt on the board it will need to replaced i have seen this many times
Posted on Nov 18, 2009
Info Code 060 on our Panafax UF 885
Code 060 means that the toner door is open. Check the switches.
You might have to tape the door closed on the rear side or call a technician to replace the door.
Nov 25, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
Panasonic Panafax UF-885 low battery on display how do you change the battery and what size is it and where is it
Pull up and open the doc feeder. Push the large white tab hanging down towards the rear to release the battery holder....it's hard to do.
The battery is a CR-2032 available anywhere.
If there is no white tab to push, somebody has lost the battery holder.
Oct 08, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
Machine totally unresponsive just blinks model with letters AU after it" for model UF 885
Remove the toner cart
Pull up on the operation panel to open
unplug the machine
hold down the pointed switch near the **** glass while plugging the machine back in.
wait for the beep
close feeder
scroll down to SHIPMENT SET
press SET
press 2
press SET
wait for the machine to initialize
Jun 15, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
Panafax UF 885 replace battery
Turn the machine off for 10 seconds.
If the display shows 00% there is nothing in memory.
Apr 20, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
Fax machine error code 021
If a new toner cartridge doesn't take care of it, replace the fuser.
Apr 07, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
Panafax UF-885 - Error Code 055
Error 055 is a laser error. the laser is not spinning at the proper speed and may need replacement. There is another solution, where some ferrite cores are added around three cables to reduce electronic interference. Best call a local technician for further diagnosis.
Mar 25, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
Replacing the LCD battery on a Panafax UF-885
Open up the document feeder by pulling straight up.
You will see a white tab sticking out of the black base.
Push FIRMLY towards the rear with your thumb.
The battery is a CR-2032 as printed on it.
Feb 02, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
Panafax UF-755e
Sometimes when this machine loses power it goes to a default setting (flashing time and date) You will need to got to the user parameters and reset the time and date. If you refer to your user manual it will tell you how to do this.
Hope this helps...
Jun 16, 2008 | Panasonic Panafax UF-885 Plain Paper Laser...
I can neither send or receive faxes
hi 003 - Recording paper jammed when feeding from the 3rd cassette. Remove the jammed paper. (1) Open the Printer Cover. (2) Remove the jammed paper. (3) Slide out the Paper Cassette. (4) Remove the jammed or wrinkled paper and reload the recording paper into the paper cassette. Caution: Make sure that the paper is set under the clips of the Paper Cassette. You can load about 500 sheets with standard weight paper (20 lb. or 75 g/m2). good luck
Feb 23, 2006 | Panasonic Panafax UF-885 Plain Paper Laser...
Panasonic Panafax UF-885 Plain Paper Laser Fax Logo
371 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
