Question about Sanyo VPC-E760 Digital Camera
Error with lens on Sanyo Digital Camera
When I try to take a picture and I have the camera in the picture mode on the dial, the screen goes black and at the top of the screen it says "lens error: 27" or "lens error: 17" and then it shuts it self off. I have only had the camera about a year and it was a gift. I have only used it about 6 times and it has never been dropped or damaged. I always keep it in it's case and then in a carrying case so it reamins protected. Can anyone tell me what may be the problem and how or where to get it fixed?
SOURCE: my Sanyo VPC S670 - digital camera lence is stuck
my camera just stop taking pictures. shutter will not work. didn't do nothing wrong. the blue light at the top keeps coming on.
Posted on Nov 12, 2008
SOURCE: my sanyo vpc-e760 digital camera is showing lens error:22 what do i do
well i have a SANYO camera and every time i cut it on it cuts on a little bit and i see it and it sais lens error: 308 what does that mean?
Posted on Nov 23, 2008
SOURCE: my sanyo camera is not working
Well maybe I can solve this..... My lens would not retract and showed two error messages. Tried a number of tricks that have been recommended on this site to no avail. Ultimately what worked for me was pushing quite hard on the barrel of the lens trying to force it back in ( yeah i know, sounds extreme but did'n't think it could make the situation any worse ). The lens remained in the locked out position not moving in spite of the fact that I pushed it fairly hard. When I turned it on the lens retracted and it appears to be fully recovered from whatever was ailing it. Hope this works for you.
Posted on Mar 12, 2009
  • 102366 Answers
SOURCE: lens error:21/16 on my sanyo vpc-e870
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Feb 23, 2010
  • 11967 Answers
SOURCE: lens error 0x03110000 in sanyo vpc e1292
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Apr 23, 2010
When I turn my camera on a message says lens error 16 and shuts off, if i want to take a picture. If I put the camera in play mode to review pictures its says lens error 21 but lets me look at the...
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Aug 10, 2009 | Sanyo VPC-E760 Digital Camera
Camera turns on, lens goes out, but it is black, see nothing through it or on lcd screen (yes, cover is off). There is no error messages, still takes pictures but just black. Can view previous pictures on...
It coud be a very common IRIS/Shutter stuck problem...this has been reported on lot of S3 IS & S2 IS cameras... just search for this on web and you'll find a temporary solution also (related to taking battery out in the middle of taking picture during a long exposure (15" in Tv mode), but for more permanent fix you need take it back to Canon service center
Aug 03, 2009 | Canon PowerShot S3 IS Digital Camera
First a black screen, then a lens error
For the lens error:
For the black pictures (after you've corrected the lens error):
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Note, if you're going to try fix 5a on the above blog page, do it with the camera turned off to lessen the chance of damaging the lens.
Jul 04, 2009 | Canon PowerShot SD1000 Digital Camera
I have a sanyo camera 7.1 mega pink and everytime i try and take a picture my screen goes black and shuts off without the camera piece going back in! I have almost the same problem except when I take a...
In the first case, if the camera turns off by itself with lens not retracting, try fresh alkaline battery. If that does not work, then the ribbon cable from battery charger to mainboard inside the camera is probably causing the problem.
An internal contact can also cause same problem.
If instead pictures are completely black, then there are several possible reasons:
1 There is a setting problem, remove and put back batteries to fix the problem.
2 The camera curtain is stuck and it is not opening.
3 The CCD sensor is faulty, more likely the ccd sensor contacts are broken.
4 The lens assembly has an internal problem.
Apart situation 1 , in all the remaining cases the camera will need repair.
Regards.
Jun 01, 2009 | Sanyo VPC-S880 Digital Camera
Lens error:21/16 on my sanyo vpc-e870
Apr 11, 2009 | Sanyo VPC-E760 Digital Camera
Lens error
Oct 12, 2008 | Sanyo VPC-S7 Digital Camera
My sanyo vpc-e760 digital camera is showing lens error:22 what do i do
Oct 08, 2008 | Sanyo VPC-E760 Digital Camera
Camera freezes in any picture taking mode
Defective mechanism, a stucked mechanism is present. camcorder are smart it can detects error and shuts down itself for safety. earlier models dominoes the defect if the user is not quick enough to react when something goes wrong with the camera. you need professional service to fix it.
Dec 28, 2006 | Gateway DC-T50 Digital Camera
Sanyo VPC-E760 Digital Camera Logo
80 people viewed this question
Top Sanyo Cameras Experts
ray gallant
Are you a Sanyo Camera Expert? Answer questions, earn points and help others
