Question about NorStar M7310 Corded Phone
How do you activate call display on the Norstar M7310 phone system. email me a elainedrew47@hotmail.com Thanks you
  • 2 more comments
  • elainedrew47 Nov 19, 2009
    On the display window on the phone it displays only Month Day and Time.
    I would like it to display the telephone no. that is calling. Caller ID.
    Please advise
    Elaine Drew
    The question is still how do I programme this feature.
    Push the feature button and Star what no.
    Thanks,
    Elaine
  • elainedrew47 Nov 23, 2009
    All my Feature combinations are 2 digits. Try again.
    Thanks
  • Carl Navarro
    Carl Navarro May 11, 2010
    Post here, read here. What "call display" are you looking for? Doesn't the display already show where the inercom calls are coming from, or are you talking about CID?
  • NorStar Master
  • 2,460 Answers
CID call display requires 3 items, CID service from the telco,CID trunk cards, and maybe a software upgrade. If you program it and it doesn't work, then you need a CID trunk. If your software is in the neighborhood of 4, then you may need to upgrade to get a display on all phones when the phone rings.
Carl
Posted on Nov 19, 2009
  • Carl Navarro
    Carl Navarro Nov 19, 2009
    It's programmed into the set as CALLER ID SET (Y/N) or by pressing FEATURE 811.
  • Carl Navarro
    Carl Navarro Nov 23, 2009
    Never overlook the fact that your M7310 phone might be connected to a Compact 308 or old 616 system. Look at the gray cabinet that all the phones plug into. If it's not an (C)ICS system, then you can't have CID to the sets without it. Here are the Nortel codes that work on the CICS. http://www.public.carl.airpost.net/Norte...
    For reference, a CICS cabinet is about 18" high by 9" wide and about 6" deep. The trunk card(s) are about 13" x 1" and have an NT7875xxxx part number on a tag at the bottom of the card. It's delivered with one card installed in the left slot and that works for 4 lines. Maximum is 2 cards. On the right side, where the cables come in, there's a plastic cover that, if you could pry it open it would tell you it's a CICS. I don't believe CID is practical or available on any of the lower level systems.
Does auto answer feature is available on Norstar phones? if yes, how?. Thanks!
Yes in system programming, handsfree answer back must be enabled. There are several different phone system models that the M7310 phone works on. I need the model number of the phone system to give accurate programming directions.
Dec 07, 2010 | NorStar M7310 Corded Phone
How do i program my nt8b20af-03 with an extension number?
If you plug the telephone into an activated (connected to the Norstar System) telephone jack, the lights should begin to blink while the phone boots-up. The system automatically assigns an extension number. To see what the ext. # assigned to the phone is, press "Feature * 0" (Button Inquiry) and press an intercom button. This will display the ext, # and Set Name of the phone.
Good Luck!
Aug 18, 2010 | NorStar Meridian M7310 Phone
F 981
If none of your voicemail feature codes(f980-f989) are active, then that means that the system doesn't recognize any nortel voicemail on the system.Which means that a) your system has a non-nortel voicemail system attached to it, b) theres no voicemail attached to the system at all or c) the voicemail is no longer functioning.
Jun 23, 2010 | NorStar Meridian M7310 Phone
How do I reset the time on a m7310 norstar system
Changing the time on a Norstar system must be done using a display phone. Using a M7310 or T7316 the right 2 buttons under the display are "NEXT" and "SHOW" respectively.
1.- To enter programming mode press "FEATURE" and "* * 2 6 6 3 4 4"
2.- Enter password (default = 266344) - display should read "Terminals & Sets"
3.- Press "NEXT"(bottom right arrow) 5 times - display should read "Time and Date"
4.- Press "SHOW" (top right arrow)- display should read "Hour:___"
5.- Press softkey "CHANGE"
6.- Enter hour - display should read "AM OK or Change"
7.- Select AM or PM
8.- Press "NEXT"(bottom right arrow) - display should read "Minutes:___"
9.- Press softkey "CHANGE"
10.- Enter minutes
11.- Press "NEXT"(bottom right arrow) - display should read "Year:___" 12.- Press softkey "CHANGE"
13.- Enter year
14.- Press "NEXT"(bottom right arrow) - display should read "Month:___"
15.- Press softkey "CHANGE"
16.- Enter month
17.- Press "NEXT" (bottom right arrow)- display should read "Day:___"
18.- Press softkey "CHANGE"
19.- Enter day
20.- Press "NEXT" (bottom right arrow)
21.- Press the Rls key
Mar 15, 2010 | NorStar M7310 Corded Phone
We have a Norstat Meridian M7310 phone system - is
THE PHONE IN THE BACK IS THIS A NORSTAR PHONE. WHAT IS THE QWEST VMAIL AND WHAT DOES THE NORSTAR SYSTEM LOOK LIKE . SOUNDS TO ME THAT QWEST IS SUPPLING VMAIL AND NOT YOU OWEN NORSTAR COULD YOU CLARIFY THIS FOR ME.
Dec 17, 2009 | NorStar Meridian M7310 Phone
How do i get to system programming on my norstar m7310 to get to auto relocate
Enter Administration Mode
  • Using you telephone set push feature * * 266344
  • Display will read Password
  • Using you telephone set enter password: 2 6 6 3 4 4
  • Display will read Configuration
  • Press Show
  • Display will read Trk/Line Data
  • Press Show
  • Display will read Sys speed dial
  • Press Next several times until the display reads Set relocation: Y or N
  • Press Change until the phone displays Y for ON or N for OFF
Jul 02, 2009 | NorStar M7310 Corded Phone
Can you change the password on NORSTAR M7310? I have the restricted line (long distance phone call) and I would like to remove that restriction. Can you help me? thanks Brandon
Yes u can change the password.
Go to system programming by Fetature **266344 password will be 266344.
Keep pressing next until display shows restrictions.
press show there it will ask for COS password press show there u press 00
u will get a pasword press change as per ur requirement.
Jun 26, 2009 | NorStar M7310 Corded Phone
Norstar M7310- buttons don't produce tone anymore
Its the problem from the system.
Go to the programming of Norstar by Feature **266344 and the password is 266344.
Go to line datd or line and make dialling made as Tone.
It will fix ur problem.
Apr 21, 2009 | NorStar M7310 Corded Phone
Caller ID
First off seven to nine you do not use an external cid unit for norstar systems. Make sure you have a caller id card in the main ksu or key service unit( the phone cabinet) It should say CI on it. If the card says DS then you do not have a caller id card on the system and will need to exchange it for one. Then the system phones will have to be programmed for cid.
Feb 16, 2008 | NorStar Meridian M7310 Phone
NorStar M7310 Corded Phone Logo
224 people viewed this question
Top NorStar Lands Phones Experts
george  peters
george peters
dan4261
Level 1 Expert
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
