Question about Samsung HCM4216W 42" Rear Projection Television
Contrast Issue Recently I noticed the contrast going dark to normal during viewing. This occured repeatedly. Do you have a solution? Thanks.
It's most likely a capacitor starting to go, or your contrast knob is flaky
Posted on Jan 10, 2008
WD 73835 has ghosting images during dark or red scenes
Make sure your contrast isn't set too high. Most ghosting is caused by either contrast, brightness or tint issues. Try adjusting these settings. Also check if there is a Dynamic contrast setting for your TV as well as this can cause ghosting also.
Apr 06, 2014 | Mitsubishi Diamond 835 Wd-73835 73" 1080p...
I find the colour contrast is very dark could you send me ideal colour settings for perfect clarity thanks
Hello
Adjust the contrast to 55 to 70%; brightness to 45 to 55% and colour to your viewing taste. Now the brightness will be very low I thinks. Advance the brightness and contrast after setiing the colour to Zero. Adjust for a well defined B/W picture first. The advance the coulour. Take reference of the face colour of a news reader at studio. The picture will be perfect. OK.
Jul 07, 2011 | LG 42LB1D 42 in. HD-Ready LCD TV
I just mounted my new 55" Samsung lcd television and noticed that when the screen is very dark a large section in the middle is noticeably brighter than the rest of the screen. The oval shaped section is...
hi good day! just a tip and it might help try to check on the cables if they are properly plugged or you can try to check on the contrast as well, just a tip hope it would work good luck!
Jun 03, 2010 | Samsung Televison & Video
How do you set the contrast on the TI-85? My
turn the TI-85 on and then hit the yellow "2nd" button and then down arrow. This may take several repeats. If it gets too light hit "2nd" and Up arrow.
May 12, 2010 | Texas Instruments TI-85 Calculator
The picture tends to get really dark during dark scenes. Can hardly see faces or details. Goes back to normal during brighter scenes.
the only thing you can do is adjust your brightness, contrast, sharpness controls. every station is different especially the sound is louder on some channels and lower on some.
Mar 05, 2010 | Hannspree (K206-10U1-005) Television
The screen comes up with a large dark square on it ,no cursor, no input is possible, all batteries are new
Contrast too high.
Press [CLEAR] key and adjust contrast (Reduce)
Reduce the contast as follows
1.Press [2nd] key and release it
2.Press [DownArrow] and release it
3. Keep repeating the sequence until contrast is adequate.
To increase contrast Do the same but press [UpArrow] instead of [DownArrow]
Hope it helps
Sep 08, 2009 | Texas Instruments TI-83 Plus Calculator
My calculator works fine but recently when I use it the screen is very light. I already have it on maximum darkness and sometimes it works but occasionally the screen flickers?
When screen is at maximum darkness you see almost nothing.
Here how you change screen contrast (just in case another readed does not know how to do it).
To increase contrast:
1. Press [2nd] key then release it
2.Press [UpArrow] key then release it.
3. Repeated steps 1 and 2 in sequence, until contrast is dork to your taste.
To decrease contrast:
Follow the algorithm (a very big word for procedure) above substituting [DownArrow] for [UpArrow].
Hope it helps.
Jul 17, 2009 | Texas Instruments TI-83 Plus Calculator
Sony BRAVIA KDL-40W4000
I've been looking into this myself as I've also recently purchased the KDL-40W4000. I was watching a murky old film and was getting a bit of sludgy ghosting but found that by reducing the contrast to 25, setting the backlight on low, colour on neutral and the brightness about 40-60 (and taking ALL advanced noise functions off), this reduced the ghosting considerably.
BUT, this is quite a cool and dark image. If you watch standard TV and films mainly, a variation of the Cinema setting is probably the best overall setting i.e.
backlight: min
contrast: 79
brightness: 50
colour: 53
colour temp: Warm 2 (although Warm 1 is less yellow and still fine)
sharpness: min
noise reduction: off
mpeg nr: off
contrast enhancer: off
colour space: standard
Ben, UK
Oct 11, 2008 | Televison & Video
Flash File Overall Color and Contrast too light
MAINLY CONTRAST OF THE FILE IS DUE 2 BRIGHT COLORS. SO YOU BETTEER 2 USE LIGHT CLORS. & BRIGHTNESS MUST BEE REDUCED 2 SOME WAT ACCORIND 2 YOUR PROJECT
Sep 26, 2007 | Macromedia Flash MX
Display contrast needs adjusted
press speaker button and dial 602+ up and down key to adjust the display. dial 601 to increase ring volume. DJ
Jul 25, 2007 | NEC Electra Elite DTU 16D-2 Corded Phone
Samsung HCM4216W 42" Rear Projection Television Logo
Jerry Greenberg
Jerry Greenberg
