Question about Drills
Electrical Problem 92 Pont Grand AM
1992 Pontiac Grand AM SE OHC 4 cyc auto a/c 53K Passenger door window extremely weak/flakey, passenger power door lock button will only lock doors but will NOT unlock same. At least one passenger side speaker offline and static. Chk eng lite, ABS lite and Brake lites intermittant flash on dash. Car hit years ago passenger side front and repaired. Thinking electrical ground issue.
  • 24 Answers
Yopu got it. check the wires when u open the door that run between the main chassis and door.
Posted on Nov 18, 2009
How to change cigarette charger without removing dash on 2005 Pontiac grand am se
You should be able to reach under and unscrew the outer nut and then it will come out the front but first the fuse has not blown.
Jun 03, 2016 | 2005 Pontiac Grand Am Door Mirror...
2000 pont grand am se- rear passenger side window rolls down fine but wont roll up. wondering if it's the window regulator.
Probably, they are real junky on those cars, I know, I have one!! I have replaced 3 of my 4 regulators!! and one motor in the drivers door.
Nov 27, 2009 | Pontiac Grand Am Cars & Trucks
93 Pont Gran Am fuel pump relay location
under the hood in a black box though its not labled it is 2"x2" there should be one for the power windows rite nxt to it and yes they are the same so you can switch them...
Jul 31, 2009 | 1993 Pontiac Grand Am
Power doors not working on my 1992 explorer
try replacing the fuse if this does not work replace the relay then replace switch
Apr 08, 2009 | 1993 Pontiac Grand Am
1992 Pontiac Gran AM SE 53K Windows Speaker etc. Bad Ground??
you mentioned tht the quarter panel was hit before you owned it was the door hit also
if you think bout it small breaks in the wire from the accident could have got weather in them over time and cause there connections to corrode or deteroiate let an automotive electrical shop give it a look
Mar 04, 2009 | 1992 Pontiac Grand Am
02 Grand Am SE Instrument lights, fog lights don't work
There is a 10amp fuse located in the fuse box under the R/S instrument panel end cap cover.
Open the passenger door, remove the cover, if I remember correctly it is held in place with clips.
The Illumination fuse probobly blew when you were working on the multifunction switch, it happens.
Good luck, let me know if there is any thing further.
Regards,
Feb 20, 2009 | 2002 Pontiac Grand Am
1992 pontiac grand prix SE
get in the car anyway possible, you probrally cant open the door from the inside either. Your gonna have to reef the door panel off and reach inside towards the post where the door latches to, and play with it and unlock it by hand. what it is is the spring loaded locking part in the assembly rust out and wears out so that the door wont unlock. I have the same problem with my car i disconnected the power locks in my car cause when people want to roll the window down they accidentally push the lock button. then im stuck entering and exiting out of the passenger door untill i play with it and unlock it. so me and you are gonna have to replace the latch assembly from inside the door.
Jul 14, 2008 | 1992 Pontiac Grand Prix
1992 Pontiac Grand Prix 2 door
The SE and LE indicate opinions on the cars. Most of the parts will interchange. When doing engine changes, the best way is to swap the ECM also.
Jul 10, 2008 | 1992 Pontiac Grand Prix
92 F150 power window and locks
try taking apart and cleanig all contacts first. make sure you are getting power to switch. Sounds more switches are going bad. They usually last about 5 to 7 years before they start going out.
Jun 11, 2008 | 1992 Ford F150 SuperCab
Drills Logo
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
