I turn on the dryer and after a minute I here the igniter click on. I have checked the dryer a number of times after the dryer has been running around 5 minutes and it is warm. At the end of the drying cycle the cloths are still wet. The vent line was removed and relocated about 2 weeks ago. When the line was removed it was discovered that the line was blocked which i suspected. The new run is about 19 feet which is now a little bit shorter with one 90 degree elbow.
  • Brian Steimle Nov 18, 2009
    every thing was cleaned out and inside the dryer as well
    Maytag model mdg2301bww
  • 388 Answers
When you replaced the vent line, did you also clean out the vent line in the dryer and the lint filter in the dryer?
Posted on Nov 18, 2009
  • 2 more comments
  • bulldogchief
    bulldogchief Nov 18, 2009
    Ok, so you are indeed hearing the igniter click, are you hearing when the gas ignites? Have you checked the blower motor that pushes the hot air into the drying chamber?
  • bulldogchief
    BTW, can you give me the make and model number of your dryer so I can get a look at it myself?
  • bulldogchief
    Thanks. I will get back with you shortly.
  • bulldogchief
    bulldogchief Nov 19, 2009
    Okay, this is what I suspect your problem is; inside the dryer are two gas coils. They are solenoid coil valves that regulate gas flow. What I suspect is these two coils are not allowing gas in the dryer and therefore you are feeling warmth but not actual heat; this is why your clothes are still wet after the cycle ends. You can fix this yourself, I will walk you through it here.
    You can remove the hinges on the dryer door by removing the screws from the hinges. Once that is done, you lift the door off of the dryer frame. Next, you remove the two screws on the opposite side of the door. Now you can take the front panel off, it will be easy because you will see where the clips hold it on.
    The coils will be on the gas valve, all you need to do is pull the old ones and put the new ones in. I am including a link where you can order the new coils. Here is the link: http://www.repairclinic.com/SSPartDetail...
    This should fix your problem. Good Luck!
Dryer heats for 5 minutes then no heat, but keeps tumbling
Perhaps the flame sensor is not working. If it does not sense heat, it will shut off the gas. You might go online and search for a manual to help you troubleshoot, or go to:
for troubleshooting help and parts. I hope this is of help to you.
Jan 16, 2014 | Dryers
The dryer has no heat when turned on.
Check your coils & igniter. Access door usually located in lower right front of dryer. Remove (pry up & out from bottom of panel, if no screws, exposing burner assembly. Set dryer for heated dry and start, you should see the igniter glow bright orange (give it at least a minute) followed by a CLICK sound,(again, a few seconds) this is the coils opening the gas valve, followed by a blue flame for heat. If no glow, replace igniter. If igniter glows bright and no click, replace the coils.
Feb 13, 2011 | Dryers
Frigidaire crown gas dryer runs fine but after about 10 minutes it turns itself off and i cant turn it back on for about an hour
From the description you give the most likely cause of this problem are bad gas coils or a bad gas valve.
You say you see the flames for 10 minutes before it stops heating but you don't mention if the igniter is continuing to glow. One thing we need to know is if the igniter continues to cycle on and off when the dryer stops heating.
There is a small square plug on the front panel you can remove to try and visually check if the igniter is glowing.
The problem won't be the thermal fuse or one of the thermostats. Once the fuse is open the dryer won't heat but it won't start to heat after 20 minutes.
After the dryer runs ten minutes and stops heating then check if the igniter is still cycling on and off. This is important because if the igniter is working then the thermostats and igniter are okay.
When the igniter glows at some point you might hear a click and the igniter would stop glowing. The click is from the flame sensor and after the click and the voltage is removed from the igniter at the same instant the voltage is applied to the gas coils and you should get a flame.
You might hear a hum, buzz or vibration from the coils when this happens. If the coils seem to react to the voltage but there is no flame then most likely the gas valve is bad. If the coils don't do anything then most likely the coils are the problem. The gas valve and gas coils can work for 10-15 minutes and then heat up and stop working till everything cools down.
One other thing I must tell you about the gas coils. Here is a link to the gas coils you will need. These are the new style that will last quite a bit longer the the older one. The coils are like the spark plugs in your car. The will need replacing in time due to wear. Below is a video to walk you thru the repair process.
utube.png You-Tube video "RjonjNitfVk" placeholder
Jan 09, 2011 | Frigidaire GLGR642A Gas Dryer
My Maytag DG712 dryer does not dry the clothes. The burner comes on when it first starts and then shuts off after several minutes. After about a minute it restarts but only stays on for about another...
If you have a gas dryer..
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer is electric..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Apr 16, 2010 | Dryers
Gas never ignites in any cycle in a 10yr old Kenmore dryer.
Chances are your igniter has gone bad. It must pull atleast 3.2 amps to open the gas valve and ignite the gas. A new igniter could probably purchased for 20 or 30 dollars.
Mar 13, 2009 | Dryers
Dryer lights but turns off within minutes
most coomn issue witha unit lighting the first time andthen consecutive lighting the glow coil "glows" but doesnt ignite, soundslike a bad set of valve coils.Located atop ofthe valve body itself, simplpe enough to change and cost about $25 part number 279834
Feb 27, 2009 | Amana Dryers
Gas Dryer Problem
I would change both coils anyways,they can go bad after they heat up.
Nov 02, 2008 | Whirlpool Dryers
Whirpool Senseon stops mid-cycle
there is a thermostat called a thermister on the blower box that will do that(run for few minutes and shut off) get the model number off dryer door or on inside dryer door wall ,go to sears .com click on parts put in model number and it will show you exactly where everything goes,let me know how you do-mike
Oct 02, 2008 | Whirlpool LER4634J Electric Dryer
Maytag washer/dryer lsg7806aae
The easiest way i can tell you if it is an ignitor problem or a thermal fuse or something else is to turn the timer  to the timed section past 10-20 minutes then slowly turn the time back while the machine is running once you hit the last 5 minutes you should hear a click at the timer and at the gas valve. If you only hear a click at the  timer and not at the gas valve it is probably a thermal fuse and control thermastat. If you hear a loud click at the gas valve it could be a bad ignitor .If you see an orange glow but no heat or intermitant heat the coils on the gas valve may be at fault
Oct 10, 2007 | Maytag LSE7806A Top Load Stacked...
Washing Machines Logo
Top Washing Machines Experts
