Question about Dell Inspiron 1525 Laptop
Dell 1525 motherboard does not power on help . battery , power switch, charger , ram ,cpu ,all ok help me thanku
  • williamsw Nov 21, 2009
    change the lence mean dvd rome? i removed it same problem
Change the lence
Posted on Nov 19, 2009
Inspiron 1525 mother board problem can i fix?
It does seam like a mother board issue ..but I suggest to check the CPU ..if you can get one with a similar socket ..even if it is smaller on properties...just to see if it works ..cause usually when you do have power indicators..and the fan works ..it shows that the motherboard have power ..so it may be ok ..and only the cpu may have issues or something ..So my advice is to see the socket time (see the specs for the laptop ) ...get another one ...second hand but be sure even if it is a cheap one ..that it is functional ..and try it on ..It might surprise you ..In my oppinion ..this is a clear cpu failure..(remember that the fan is powered up from the motherboard..and if this one is faulty there isn't power present .on the fan nor in the indicator led ..
Nov 22, 2011 | Dell Inspiron 1525 Notebook
Dell inspiron 1525 does not power up. i powered
Hi
Thank you for yuor query
Please can you try the following
1) Remove battery
2) Remove wall charger
3) Press and hold the power button in for 30 seconds
4) Plug in wall charger only
5) Retry powering the laptop and if it switches on plug battery in after 5 minutes
Regards
Shauqat
Apr 28, 2010 | Dell Inspiron 1525 Laptop
Dell 1525 won't run on ac but will on generic battery
Dell systems will not charge the battery without a Dell Branded AC adapter connected to the system (The BIOS looks for the adapter ID and disables the battery charger if not ID'd)
It appears, that since the system will not power on with either AC adapter, that there is a problem with the power connection of the system. You can replace the power board
http://cgi.ebay.com/DeLL-Inspiron-1525-1526-Power-Jack-Board-48-4W006-011_W0QQitemZ380212346664QQcmdZViewItemQQptZMotherboards?hash=item58866bff28#ht_953wt_1165
if that fails to resolve next is the motherboard
http://shop.ebay.com/i.html?_nkw=dell+inspiron+1525+motherboard&_sacat=0&_dmpt=Laptop_Adapters_Chargers&_odkw=dell+inspiron+1525+charger+board&_osacat=0&_trksid=p3286.c0.m270.l1311
Mar 14, 2010 | Dell Inspiron 1525 Notebook
Computer-challenged person can't find memory slot
Hello
Thank you for using
FixYa for your problem
There is a little plastic thing in the front part of the unit. push this and it will now come out, now you can put in your SD/MMC memory card
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Nov 18, 2009 | Dell Inspiron 1525 Notebook
My laptop is not chage dell 1525 when power is on laptop is working ok when power is rimove laptop is totaly off
I think the battery is bad. how long have you been using it now?
Look for someone that has the same laptop, remove the battery and test it with yours to be sure if it is the battery that is bad or not.
Please give me feedback if it is not the battery.
I wish you the best.
Nov 13, 2009 | Dell Inspiron 1525 Notebook
For some reason my Dell Inspiron 1525 wont charge!!. I plug it into the main and the green light comes on the charger lead and it is putting power into the computer but just not actully getting any charge...
This only mean that you have a failing battery and does not hold charge anymore.. battery life can last upto 2years, depending on how frquent you use..
HOpe this helps
Oct 30, 2009 | Dell Inspiron 1525 Laptop
Intel DG33FB motherboard problem
Dear User,
Please remove the RAMs from the motherboard slots and then switch on your computer. if it give beep for RAM then your motherboard is almost ok. if it does'nt give any beep then there would be problem at motherboard side. Then switch off your computer remove power. and then remove (CMOS) battery from motherboard to reset. and then start your computer while making sure that power is not connected to computer. this is for the releasing of power in motherboard so that BIOS gets to be factory defaults.
then install battery and RAM then powerup your computer hopefully it will work fine. if it does'nt then Motherboard have critical problem.
Please dont forget to rate my answer
Sep 05, 2009 | Intel D865GBF Motherboard
No power after 5 second
Check the cpu fan and fins are clean if you have to take processor out make sure you reapply thermal compound, Also check the ram is seated correctly.Also check the psu is functioning correctly as it could be a faulty psu . Good luck John
Aug 02, 2009 | Dell (E210882) Motherboard
Can I use ther Targus Adaptor for Inspiron 1525
On the long term, a power adapter with a bigger amperage can damage battery and battery charger.
Better to get an adapter with same specs as the 65/70W one , or an original replacemant:
Dell Inspiron 1525 New AC Power Adapter Supply $14.29 - Buy.com Dell Inspiron 1525 65 Watt Original AC Adapter $25.00 - parts4nb.com Dell Inspiron 1525 Power Cord PA-12 $16.95 - AmeriMax Advance
DELL Inspiron 1525 DC Power Laptop Adapter ... £25.23 - B2C Shopping UK DELL Inspiron 1525 Laptop AC Adapter power adapter £38.99 - Very Good Battery Dell Inspiron 1525 Ac Adapter Charger Power ... £16.50 - eBay UK
AU/NZ - DELL INSPIRON 1505 E1405 E1505 AC Adapter Power Supply
Dell : Lind Electronics 70-Watt DC Power Adapter for Dell Inspiron
Apr 22, 2009 | Dell Inspiron 1501 Notebook
Dell gx260
You have 500mA on usb port. If you cause a short on usb connectors, this can damage the motherboard.
Disconnect usb port on motherboard (work with power unplugged ), remove all ide and floppy cable,eventually remove and put back in place bios battery and Ram.
Restart Motherboard only with 1 module Ram (bios battery back in place), CPU and Fan (ensure cpu and fan are well in place), do not plug anything else than switch on button.
If it still does not work there is a good chance you blew the Motherboard.
Regards
Apr 18, 2008 | Dell OptiPlex GX260 PC Desktop
Dell Inspiron 1525 Laptop Logo
160 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
