Question about Palm m505 Handheld
I stopped using my m505 for several months. How long until it will be charged enough to turn on? Its been charging now for at least 2 hours and nothing.
  • Palm Expert
  • 346 Answers
I would charge it over night. If the batteries went completely dead sometimes it takes an extended period of time to charge them. If that doesn't work try using the free palm chat. I have enclosed that link. Scroll to the bottom of the page and you will see Palm chat. From there click on the link that says chat now.
Best wishes.
http://kb.palm.com/wps/portal/kb/na/m-series/m500/unlocked/supportservices/page_en.html
Posted on Nov 19, 2009
Dirt devil easylite 7.2 v does not hold charge. Can you suggest any fix? Thanks
Sorry to say that the batteries seem to be worn out. Usually this is caused by using it for to short a time each time you use it. Batteries develop a 'memory' after several short time uses, and can only be charged the time it 'Thinks' is a full charge. You can try running it until it almost stops. Then let it sit for about an hour turned off, then turn it on again, and run it till it almost stops. After doing that put it on the charger for 8 hours. Then run it until it almost stops again. then charge it again. That process sometimes breaks the memory problem. If not, you need new batteries- or a new dirt devil.
Jul 02, 2017 | Dirt Devil Vacuums
My phone is not holding a charge. I charge it overnight and this morning it was only at 32% charged. The day before the charge ran out very fast. How can I fix this problem?
It sounds like you need to replace the battery in your phone. NiCad batteries will build a memory, so you should not use the phone for, say 3 hours and place it back on the charger. You should use the phone and let it run down until you get a warning on the phone of low battery. That is when you should put the phone on the charger. It is okay to leave the phone on the charger for extended hours and it will not do anything to the battery, but in your case it looks like you have a bad battery.
Aug 23, 2016 | Cell Phones
My kindle will not charge?
The Kindle Fire HD, if completely discharged, may take several hours to begin to accept a charge again. Simply leave it plugged in long enough and the on-board system will sort it out.
Feb 01, 2015 | Amazon Kindle Fire HD
Haven't used my m505 for several years. It won't charge/start. Can it be revived, perhaps w/ new internal battery?
If it won't take the charge it is definitly the battery. You can try to cycle it a few times by charging and discharging it a few tmes and it might revive. If not time to replace. Batteries can be $14 and up so google and look around for the best deal.
Mar 01, 2010 | Palm Pilot Professional
I have trouble starting it. after long time not useing [ie month]seems like battery is not powerfull enough to turn motor fast enough.if jumped off a car it starts first time very easilly
The battery needs to be charge on a 2 amp charger.If you use a larger amp charger it wears hard on a motorcycle battery. I have a 2 amp with a gauge.When I put a weak (stored) battery on the gauge reads 2 then after about 8 hours in drops to 0. This is the reading you want. It means the battery wants 0 amps, its fully charged.
Motorcycle batterys need to go on a charger once a month if you are not rideing the bike.
Sep 27, 2009 | 2001 Triumph Legend TT
Screen not responding following extended period of storage...
The digitizer is very thin and paired with the screen. Sometimes they can get so pressed together with time and storage that can cause it to fail. Some people believe that you can put a spacer in there to separate them and try to "unstick it". This involves taking your screen apart and it might not even fix your issue. I would look on eBay or other sources for a replacement screen and just replace the whole thing personally.
Aug 21, 2009 | Palm m505 Handheld
My garmin 340 suddenly stopped working
Ummmmm "Low battery"....... not too hard to figure out. You need to charge it for several hours. If the battery is low it WILL go out on you and during that time, the battery may recover enough to come on briefly then go off again. Please charge your battery!
- Jim
Sep 13, 2008 | GPS
It has only been 2 and a half months sinse i bought my toshiba equium A300D series laptop. Once i have fully charged my laptop i only have a hour to use until it needs charging again. I never had this...
this happens to every laptop after a while, although after only 2 months it should be ok, you may need to send it back under guarantee, but remember you will have more things running now then when you first had it, using more processor power and also any usb peripherals youve added also shorten battery life.
Sep 01, 2008 | Toshiba Computers & Internet
Battery Charge - First Use
My experience was similar to yours. The LED turned green after about only 2 hours. Because I didn't want to stay up until midnight to start playing with my Axim, I took it out of the cradle after the 2 hours and everything was fine. Besides, having downloaded and read the user's guide 2 days before receving my Axim, I knew that a green LED meant it was ready to go. 3 days later, everything is still fine and seems normal. A year ago, I received a Palm with similar initial charging requirements, and it also didn't take as long as the directions said it would.
Sep 13, 2005 | Dell Axim X5 Pocket PC
Palm m505 Handheld Logo
128 people viewed this question
Top Palm Computers & Internet Experts
JC Meredith
JC Meredith
gary433
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
