Question about Nokia 5130 Cellular Phone
Hi i have a nokia 5130 and it was working fine until suddenly it fails to give any reception or service and keeps saying sim card registration failed. but when i put the sim into my other phone it works fine. the 5130 is unlocked to all networks. is there anything else that could be causing this problem? thanks
Nokia 5130 sim card registration failed solution
As if your using nokia 5130 cellular phone your mobile is 100% fine as a new one you just have problem with your sim card the problem is your sim card as got damaged.The reason for sim damage is you have keep your sim card in your valet,or you used to change your sim frequently.The other reason is you have taken a new sim but the service provider company may not recived your address prof from your number or your not using that sim from three months. so you better forget that number and take a new number. var geo_Partner = '687b82b2-54e8-44dc-93c0-87c73f39cdb0'; var geo_isCG = true;
Jun 12, 2011 | Nokia 5310 Cellular Phone
I have nokia 5800 it worked fine all these years but suddenly last night when i tried to make it work it said sim card registration failed my friend asked me to try it in some other phone but the same...
If the sim gives the same error in both the phone, Please call the respective customer care from some other phone and let them know.
I can suggest, to get a duplicate sim - if the sim is damaged physically.
Jan 19, 2011 | Nokia 5800 XpressMusic Smartphone
Please contact the service provider. Ask them to give you a new sim
Jan 13, 2011 | Nokia 5310 Cellular Phone
My phone keeps saying sim card registration fail and i don't know what to do
hi...
I belive you got a new sim card.sim card registrations fails comes only when the delear from whom you purchased might havent gave your proff to the service providers. so please contact the delear from whom you got the sim card.
thanx
Jul 15, 2010 | Nokia 5310 Cellular Phone
My nokia 6300 is giving problem like sim card
your phone`s sim data is corrupted , unblocked it n enjoy
Apr 23, 2010 | Nokia 6300 Cellular Phone
SIM CARD REGISTRATION failed, N70
Factory resetting the phone will do absolutely nothing with this problem
There are 3 causes of Sim Card Registration Failed, when you first turn on the phone, the sim card attempts to connect to the network if it can not do this it gives a message like Sim Card Registration failed.
1, The sim card is turned off (is it Orange) if you have had the sim card for a while and it hasnt been used they will turn it off, you need to contact them from another phone to get it turned on or get a new sim card.
2, The phone has a hardware reception problem, when it attempts to register itself with the network it can not... There is a reception problem and it requires repairs, this isnt really an easy diy job on this handset.
3, The phone is blocked, i.e reported lost or stolen. Some networks when a phone is reported will allow it to get reception but will not let it make calls, however other networks will not give it reception at all and hence you get a Sim Card Registration failed message.
I hope this helps, these are the causes of the message.
May 08, 2009 | Nokia N70 Cellular Phone
I get an opening message: "SIM card registration failed" - what does this mean? then i can't receive nor send any msgs.
1, The sim card is turned off, if you have had the sim card for a while and it hasnt been used they will turn it off, you need to contact them from another phone to get it turned on or get a new sim card.
May 08, 2009 | Nokia 6300 Cellular Phone
Will not accept my sim ?
You should contact your mobile operator to get a new sim card.
May 09, 2008 | Nokia 7373 Cellular Phone
i have the sme problem
Feb 25, 2008 | Cell Phones
You might have filled up the memory to the brim and the phone doesn't have enough to switch on.
Try reformat to original settings. anything you stored on the phone will be lost.
How to reformat your phone, first turn it OFF. Press * 3 send at the same time and keep them pressed while you turn the phone on.
Give it time to work.
Remember, do not let go the 3 keys until you see the formatting screen.
After a few minutes when the process is over, your Nokia N70 will be back to the original delivered system.
Jan 03, 2008 | Nokia N70 Cellular Phone
Nokia 5130 Cellular Phone Logo
128 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
