Question about Tecnik Washing Machines
Washing machine will not empty out not a year old yet tecnik 9909 no filters to clean in the front of machine. Any answers?
    Brigadier General:
  • 3,513 Answers
Hi
Before examining the fault, it is usually worth trying to empty the machine manually, this can be done by removing the outlet pipe and lowering it into a bucket, when gravity should allow the water to empty from the machine. This method will not work with certain German made machines where the mounting for the outlet hose is too high to allow a gravity discharge.
Often the reason for non-emptying is a blockage. This usually involves removing the pipe connecting the bottom of the tub to the pump, but be careful because dirty water will gush out. The blockage could be due to a lost item of underwear or a broken-up soap ball. The soap ball is a supposed to make the machine more efficient by keeping the soap in the tub, but it frequently jams and causes machine emptying problems. If there is no obvious blockage then you need to check the pump, which you can do by putting the machine on an empty cycle and listening to see if the pump is turning. However, even if the pump is rotating it is possible that the rotor has come loose or has broken vanes, so you really need to check that it can generate water flow. If the pump is not turning then check for an obstruction directly in the pump, such as a coin or bra-wire. If the pump is working fine, then the trickiest problem of all could be a coin in the outlet pipe. This is a hard one to diagnose because this kind of item is very difficult to find. The best cure for this is to have a pole which is close to the internal diameter of the pipe and shove it from one end to another.
Thanks for contacting fixya.com
Posted on Nov 18, 2009
Washing machine doesnt empty or final spin
You need to check the filter.
Remove lower rear cover of washer.
Remove large black hose on bottom of drum.
Remove and clean filter inside hose.
Fit back and test.
Mar 12, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Bosch washing machine not emptying
There should be a filter located at bottom right front of washer.
To clean it ,unscrew anti-clockwise, remove and clean it.
If you cannot see the filter, it may be behind a removeable plastic cover at bottom of washer..
Hope this helps you
Dec 08, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Zanussi ZWF1437W E23
E23 indicates Drain pump faulty; Wiring faulty; PCB faulty.
The service information also says it should stop with the door open.
Unplug the appliance and manually remove the water via the filter or front drain point if it's fitted.
Drain it into a shallow dish, tighten the filter when you need to stop the water (or plug the hose if draining via a hose) while you empty the container.
Once empty, try the door again.
Take the filter out and clean out any debris in it.
Plug the appliance in and put the machine on a drain programe.
Listen/look at the open filter to check that the drain pump is running.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 27, 2009 | Washing Machines
Washer won't empty
definatly a pump problem check filter if it is clean you will need a new pump maybe just a coin or hair clip
Oct 27, 2008 | Tecnik TKL9260 Front Load Washer
Tecnik washer/drier
Leave the door open after using to prevent mold problem.This should help alot.And needs to be left open just partially.
Jan 14, 2008 | Tecnik TKL9260 Front Load Washer
Bosch exclusiv f 1100
I would check your hot fill hose if it has one, put the programme on a number two and listen to hear any water coming in.
Dec 04, 2007 | Washing Machines
Washing Machines Logo
Top Tecnik Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Tecnik Washing Machine Expert? Answer questions, earn points and help others
