Question about GE Refrigerators
Have Ge Profile and the fan in ice box is hitting the front shroud. How do I fix
    Problem Solver:
  • 13 Answers
You might bend the shroud out a little so it doesn't hit the fan blade. If the fan was replaced and was not hitting the shroud before replacement, you might add spacers (washers will work) to move the fan away from the shroud.
Posted on Nov 20, 2009
GE Profile refrigerator Model # PFSF6PKXCWW motor is noticeably louder
if you are talking about the motor in the freezer the ice build up could be causing the fan to beat against the ice... could be a defrost cycle problem,,,, if ice is building up on rear freezer wall you have a defrost cycle problem and the ice is forminf around fan causing fan blades to hit the ice (loud noise)
Aug 28, 2014 | Refrigerators
I have a GE Profile fridge, top freezer. Ice buildup keeps blocking thew evaporator fan. I've defrosted 2x, checked evap drain for blockage. But ice buildup reoccurs after 2-3 days. Turning up the
You have a defrost problem. Locate your defrost timer while the unit is iced up and turn it until you hear a defined click. At this point open the freezer and listen for ice cracking. If Ice starts cracking then it's your defrost timer bad. If ice doesn't crack, then you have a defrost component bad ( heater and Bi-Metal) Ohm out your heating element and replace if there is no continuity. You can usually find defrost timer either under the front of the box, in the fridge around the light or thermostat or sometimes in the back at the bottom. The dial on the timer can only be turned one way with a large flat head. You will hear the difference in the way the clicks sound for the defined click. Good luck.
Mar 09, 2013 | Refrigerators
How to fix knocking sound
It really depends where the sound is coming from. You will get a knocking sound when the fridge makes ice, and a knocking should when the compresser starts land stops, or your fan in the freezer may be hitting some ice build up in theevaperator
Sep 06, 2012 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Fridge side of side by side 25.6 cu. ft. iced up to where fan was hitting
un plug it and let is de ice..or put a hair dryer on the frozen park
Jan 31, 2012 | GE Profile 25.6 Cu. Ft. Side-by-Side...
My GE Fridge PSS26SGRD has a moaning howling
The fan is hitting on ice buildup...unit is not defrosting...
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jul 12, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
PDS18SBMRBS model GE Profile fridge. The fan
the heater unit might be weak and usualy it is a hlogen light that need to be replace , so the defrost will be better
Jan 01, 2010 | GE Refrigerators
GE fridge is warm and broken; the freezer is cold though.
Air circulation problem. Evaporator fan in freezer moves some air to refrig. Either fan is not working or air passages are blocked with ice. If ice found, then a defrost component failure has occurred. Fix what you find.
Sep 19, 2009 | GE Profile PDS20MFS Bottom Freezer...
Fan in freezer under ice maker won't stop running.
Hi yes the fan blade could be hitting the shield or ice, remove the fan cover & check
Dec 23, 2008 | GE Profile PSW26P Stainless Steel Side by...
Refrigerators Logo
57 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
