Question about Dyson DC17 Animal Bagless Upright Cyclonic Vacuum
My DC17 suction hose doesn't have any suction occasionally.
Too often my DC17 suction hose doesn't ****. The beater bar unit always works but when in the upright position sometimes the suction hose will work but many times it won't. Sometimes there will be suction for a few minutes and then it slowly fades until there is no suction for the hose. Thoughts?
  • ggignac Nov 19, 2009
    I will clarify that when the suction for the hose is not working the power switch doesn't seem to function. Perhaps there is a short in the cord at the pivot point of the beater bar?
    President:
  • 1,486 Answers
Check the seal on the filter is not broken,And check for any blockage at the bottom of the pickup pipe.
Posted on Nov 18, 2009
  • Philip Long
    Philip Long Nov 20, 2009
    That could be quite possible check that if all else has failed.Good luck
Very little suction at beater brush.
Hey, this is Leland with Crucial Vacuum,
If the brush bar is not working properly there may be several reasons.
Firstly, the motor may be the problem. If you hear any noises while the machine is running, you should contact the original manufacturer for trouble shootingsolutions.
Secondly, your vacuum may be in need of new parts. By changing either the brushroll or belts, you should be able to increase the quality of the suction.
You can purchase replacement parts for the DC17 direct from Crucial Vacuum with freeshipping and an exclusive 10%coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/catalogsearch/result/?q=dc17
Feb 11, 2016 | Dyson DC17 Animal Bagless Upright Cyclonic...
Dyson Animal motor won't run but beater bar operates in the upright position
Hi there, it's Jack at Dyson.
The issue you've described with your DC17 sounds very unusual - it's possible that the main suction motor may have overheated and shut itself off for protection. However, the brush bar should never rotate when the vacuum is standing upright.
I would encourage you to contact us directly so we can take you through some quick troubleshooting checks to help diagnose the issue. We can also recommend the best course of action to resolve the fault. You can reach us by calling 1-866-693-9766 (US), or 1-877-397-6622 (CA).
Sep 08, 2014 | Dyson DC17 Animal Bagless Upright Cyclonic...
Poor Suction
The flexible hose between the beater bar housing and the connection to the dust bin might have come loose or has a hole in it. Check this hose for your low suction problem.
May 15, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
My dyson dc17 will not roll across the carpet, because their is too much suction.?
Turn on the beater bar with the gray button next to the red power button. The powered beater bar will "propel" the vacuum across the carpet.
May 02, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
Power only comes on when vacuum is not upright
Power or beater bar? Beater bar is supposed to turn off when upright, but suction motor should still run.
Nov 14, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
No suction for rugs but the hose works fine. Removed the canister and suction is at that point
Remove the base plate and beater bar. Clean the suction cavity behind the beater bar. That's where they almost always plug up.
--W.D--
Aug 19, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
My dyson dc 17 does not work when in the upright position
I had this same issue today, after not being able to find a solution, I took apart the brush area by unscrewing the three simple screws... my belt had a TON of dog and cat hair built up inside it so I cleaned that out and it did the trick.
Dec 06, 2008 | Dyson DC17 Animal Bagless Upright Cyclonic...
No suction
so the red hose isn't connected to a part on the vaccum so like it is connected to the connester but not to an opening just above the beater bar, this is the only idea i can supply you with. good luck, maybe i got lucky and helped you out.
Jun 12, 2008 | Dyson DC17 Animal Bagless Upright Cyclonic...
Dyson DC17 Animal Bagless Upright Cyclonic Vacuum Logo
1,361 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
