Question about ASUS P4B533-E (P4B533-E/L/1394) Motherboard
When I load a cd or even open up a word document, my pc reboots. Will an overheated cpu cause this problem? If not, any ideas in how to fix this problem.
A faulty memory board OR failing memory slot can also cause spontaneous rebooting. Try removing/swapping memory boards, so that all combinations of the (up to) 3 boards to the 3 slots are fully tested and yo ucan isolate whether the problem moves with the memory board or stays consistent to the slot(s - you may have multiple problems with more than one card and/or slot!).
A useful approach is to make a grid chart with the cards (labeled A, B, C) across the top and slots (listed as 1, 2, 3) along the side, and track your test results consistently. Be sure to complete all possible permutations so that you have the most information to determine your results by, as a premature decision can lead you to a incomplete and possible more expensive conclusion!
Good luck.
Posted on Feb 12, 2010
    President:
  • 1,015 Answers
To me it does not sound like an overheated CPU...but could be. My best guess would be the powersupply shorting out. I had repaired a computer that was doing something similar to what you are describing and it turned out to be the power supply unit. I would try swapping out the power supply from another computer if you have one and see if it still has the same problem. If it does then you can disconnect the cd-rom drive and see if it stops the problem. It is possible that one of the hardware components is the cause. Also check the motherboard screws that hold the board to the case are tight. If they are loose this can cause a grounding issue with the computer. Also use a can of compressed air to clean out the inside of the case of dust and dirt...this can also cause problems.
Posted on Nov 18, 2009
Computer goes off and reboots
Probablt the CPU is overheating. Clear all dust from the CPU fan and vents
Dec 27, 2013 | Packard Bell Computers & Internet
I've got an Acer Travelmate 292LMI. My problem is: the notebook starts (leds on) for only a few seconds (I can see the acer display that preceeds the boot) but immediately it is dead. Only the AC leds...
It could be an overheating CPU problem.
When the CPU in the computer or laptopoverheats then it will shut down (i.e. thermal overload) and won't boot upagain until it has cooled down. If this is the problem is not fixed then theCPU will eventually fail.
A faulty fan causes this problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan. If the fan and heat sink is clogged withdust the remove the dust and make sure the vents are clear and dust free. Use acan of compressed air to do this.
Sep 06, 2011 | Acer TravelMate 292LMi Notebook
Old Hp Pavilion 763n PC, cleaned it out thoroughly, replaced power supply, redid heat sink with silver paste, and added RAM. It worked fine, little slow, but working for about three days and now nothing....
Here is a listing. From what I read, it seems to me the problem is in the CPU and that it is overheating. This can be caused by a multitude of issues but first ensure the CPU fan is running. Second, if you applied too much siver heat sink, this can cause overheating as well. Make sure you only have a thin layer between the CPU and the heatsink. Hope this helps.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph07107&cc=us&lc=en&dlc=en&product=90823#N3704
Jul 17, 2010 | HP Pavilion 763n PC Desktop
Pc hanging
Scan your PC with a good antivirus like avast which support boot scan;it will solve your problem if it is caused virus,worm or malware.
Sometimes system hangs when a porgram start to load during bootup too.
for troubleshooting this,boot your system in sfae mode during startup by pressing F8.Click "start" then "Run" type "msconfig" select "startup" tab untick all the program and restart your system.
PC hangs or reboots due to overheating of the CPU.It is caused by dust and dirt contamination inside.open the system and blow it with a small air blower.
Dec 18, 2009 | Acer Aspire One PC Notebook
GA-EP43-UD3L Reboots while loading Windows
its due to bios problem , upgrage bios from biostar web
Oct 26, 2009 | Gigabyte GA-EP43-UD3L Motherboard
Stepnote 1502
evrex laptop/stepnote/windows vista. While on it. my labtop froze up on me. i tried unfreezing it but it stayed frooze. so i turned it all the way off, but when i tried turning it back on my labtop seem to be coming on but nothing came up on the screen, and when it does come back on it freezes up again
May 23, 2008 | Everex StepNote NC1500 Notebook
Computer reboots
Hi cool,
Is your Computer keeps on recycling from booting and never finish to load your OS?
As far as i know you got a problem with you CPU, your computer processor is overheating inside that's why it keeps your PC recycling it's power.
Try to go to the BIOS setup menu, and go to the cpu temperature and you will that your PC is heating up.
Hope it helps & give you an exact reason.
Enjoy.
tnx
-micro
Feb 10, 2008 | Computers & Internet
Toshiba Satellite A105-S2141 Lockup
Have you checked the heat of CPU? It might be cause of CPU overheating.
Nov 20, 2007 | Toshiba Satellite A105 Notebook
Windows xp pro keeps rebooting after loading mup.sys
Can you boot into safe mode? If not then the reason it continually reboots may not be software. I've seen a number of laptops that exhibit the behavior because the CPU is overheating. Intel CPU's shut themselves down before they burn up. If you're comfortable opening the laptop you might try cleaning out the CPU cooling system. They tend to get clogged up with dust so that there is no airflow to cool the CPU.
Nov 20, 2007 | Compaq Presario V4000 Notebook
ASUS P4B533-E (P4B533-E/L/1394) Motherboard Logo
47 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
