Question about Whirlpool LAB2700ML Pedestal Drawer for Duet Washers & Dryers
Clothes don't dry in my 4yr old whirlpool duet electronic dryer
I will put a medium size load in my 4 yr old duet front loading dryer for 70 minutes and the clothes are still damp...
    Problem Solver:
  • 5 Answers
If it is heating , check for a kinked or stopped up vent
Posted on Nov 18, 2009
How do you dry clothes in this machine please
A fairly common problem! The official instructions are
Before using your dryer, wipe the dryer drum with a damp cloth to
remove dust from storing and shipping.
1. Load clothes loosely into the dryer and close the door. Do not
pack the dryer. Allow space for clothes to tumble freely.
2. Turn the Cycle Control knob to the recommended cycle for the type of load being dried. Use the Energy Preferred Automatic Setting (,) to dry most heavyweight and medium weight loads. See "Drying, Cycle, and Temperature Tips."
3. Select a temperature setting on models with a Temp/Fabric selector. The cycle descriptions include temperature setting suggestions.
4. Push the START button.
Stopping and Restarting
You can stop your dryer any time during a cycle.
To stop your dryer
Open the dryer door or turn the Cycle Control knob to OFE
NOTE: The Cycle Control knob should point to an Off area when
the dryer is not in use.
To restart your dryer
1. Close the door.
2. Select a new cycle and temperature (if desired).
3. Press START
Extracted from
http://www.manualslib.com/manual/511763/Whirlpool-Lte5243dq.html?page=10#manual
Nov 14, 2015 | Whirlpool AWZ410 Front Load Washer/Dryer
Permanent press cycle keeps shutting down and doesn't finish.
Hello. I don't know what make/model dryer you have but the problem could be with load size and type of clothing. The sensor bars are usually located on the front of the lint screen housing(you have to put your head in the dryer and look back to see them--they are 2 metal strips, approx 1/2" apart and at least several inches long). The damp/wet clothing keeps shorting across the strips, telling the main board to keep the dryer running. If there isn't enough of a load, the dryer may think that the clothes are dry prematurely and count down too quickly. The sensor bar technology *is not* an exact science--it works best on large loads with like clothing. For smaller loads, use time dry and adjust the temp setting accordingly. I hope I helped you.
Aug 22, 2015 | Dryers
My whirlpool duet dryer works but it appears that the air is not evacuating from the baril. The heat and humidity built up and the clothes don't dry. Do I need to replace the fan and if so, how
YOU NEED TO CLEAN THE VENT ON YOUR HOUSE IF THE BLOWER WHEEL IS BAD ON THE DRYER YOU WOULD HERE THE NOISE AFTER THE DRY STOPS THE BLOWER WHEEL WILL STILL TURN AND MAKE A NOISE
Oct 29, 2012 | Whirlpool Duet Steam WFW9700V Front Load...
My dryer is making my clothes soaking wet every time I put clothes in. How do I turn the warer off on the steam mode (I guess)
Same problem here....I have had my brand new Whirlpool Duet Steam front load washer for a whole 4 days... It has worked perfectly until now. I checked on the clothes because it seemed like they just kept going and going... they were soaking wet!! When I took the clothes out the dryer had a huge puddle of water in it..Can anyone offer any help?
Sep 30, 2010 | Whirlpool Duet Steam WFW9700V Front Load...
Whirlpool Duet Sport Dryer front load leaks water underneath the dryer when drying heavy duty clothes
The clothes then are too wet for the heat to evaporate. Spin extra time to get rid of as much water as possible before putting them in dryer.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 13, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My whirpool dryer (Duet) seems to always take (2) cycles to dry...After the first cycle the clothes are still very damp.
Your dryer may be pushed too far back , causing the vent hose to kink , behind the dryer . Also , check the outside vent airflow , and check the lint screen holder , for any peeled off lint , which could also be blocking the outside air flow .
Oct 25, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Dryer keeps drying and getting too hot
Check the dryer vent .The vent is stopped up,in the vent,or in the inside of dryer,in the lint hopper.Clean it out and unstop the dryer,and the vent.
Oct 10, 2009 | Whirlpool LER5636P Electric Dryer
Trips breaker: Whirlpool Duet Sport front load dryer
could be a faulty stat or element,get an engineer to test the dyer, he will check insulation on the element, could try replacing the element that just might sort it
Sep 21, 2009 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
Dryer twists and knots up clothes
Many times, many types of Dryer have a variety of paddles. There are so many different ones, without your model, it's hard to know which your has, however, I have known many people that have had these problems.
  1. knots clothing;
    Solution: I have heard and seen a couple tennis balls or even a soft pair of tennis shoes used in the dryer whilst drying clothes keep this from happening. (again, the paddles make all the difference) I myself have always had Maytag, but even they are not what they used to be, however, the shoe trick works when we dry our large blankets and comforters.
  2. Length of drying time;
    Solution: Gosh, there could be many issues, but the first, I would think you either have too small exhaust tube, or it is kinked, smashed or the wrong type. Even the smallest of kink or flattening on many exhaust tubes will greatly effect the output of the exhaust. The only other thing could be overall length of exhaust, and possible clogging in the tube. Have a idea for a fix there as well. (if this is the rpoblem.
If you would like further discussions or ideas, please post here, and be sure to add as much info on dryer as you can, including year purchased and model number.
If the drying time has anything to do with my immediate thoughts (had similar problem when I just moved and reinstalled my own Maytag) I have a great fix to keep it from happening.
Whirlpool has been a good name for some years, in fact, they own Maytag now, so I am sure we can solve your issue as long as it isn't a problem with your particular unit itself as they do make a lemon evey now and again.
Aug 31, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
684 people viewed this question
Dan Webster
Dan Webster
Sal De
