Question about Garmin Nuvi 750 Car GPS Receiver
Need wiring diagram for garmin nuvi 750 car charger and windshield mount.
  • yadayada
    yadayada May 11, 2010
    there are no wiring diagrams avil to the public. sorry
4 Suggested Answers
SOURCE: Garmin Nuvi 200
Guys go to
http://www.gpspassion.com/forumsen/topic.asp?TOPIC_ID=104952
http://pinouts.ru/GPS/garmin_nuvi_power_pinout.shtml
they have the answers
it seems a standard or phone USB cable will not work to charge and use the maps at same time
Good luck
Posted on Nov 15, 2008
sharcnet
  • 2130 Answers
SOURCE: Garmin Nuvi 750 will not turn on. Any ideas on
Hi Jessica,
Move the on/off power switch to the left and hold it there for at least 30 seconds and see if it comes back on. I know there was a bug in a firmware version that makes the unit "bricked" after a certain date. The only way to fix it if the reset didn't fix it is to disconnect the battery inside, reboot the unit and install the firmware fix.
- Jim
www.sharcnet-usa.com
Posted on Aug 20, 2009
emissionwiz
  • 80346 Answers
SOURCE: when pluggin to the car
the battery is defective and needs to be replaced, if the battery is not any good then it won't work even when plugged to an outside power source, that is how this are set up, the battery is not user servicable, u must send it back to Garmin for replacement.
Posted on May 26, 2010
Garmin Nuvi 750 car cradle/charger does not charge the unit. USB charger works, so not the battery. Replaced the cigarette lighter jack and still does not work. Problem must be in the dash mount cradle...
Hi tbrick
if you dont have the original charger, the 750 take a special car charger because of the traffic feature...it has a flat end about 3/4" to 1" long that fits in the cradle, but you can use a garmin usb charger, you just wont be able to use the traffic feature.
if thats a little confusing ( i tend to do that) i try and explain it another way.
if you think you need or want one of those chargers, just post back to me.
bill
Nov 01, 2010 | Garmin nuvi 750 GPS Receiver
I've been using after market chargers in car and on ac. They worked fine for a long time. Now, my Garmin NUVI 660 seems to turn off (goes into "charge mode" or something) when I plug my car charger into...
Yes, many aftermarket chargers are not wired the same as a Garmin charger and will cause your Nuvi to think it's connected to a PC. What happened to the original charger that plugged into the cradle (the part your Nuvi snaps into?)
Please see this link:
http://www.sharc.net/gps_charger_repair.htm
- Jim
Jul 15, 2010 | Garmin Nuvi 660 GPS Receiver
Where do i mount my garmin nuvi 1300t in my 08 ford focus apparantly the windscreen can interfere with the signal
Windshield should not affect the signal. However if you are mounting it high up and there is a grid antenna in teh windshield that may cause a problem. try mounting it low down
Dec 10, 2009 | Garmin nuvi 1300 Car GPS Receiver
How to charge a garmin nuvi 750
Connect to your computer and /or to a car type charger provided by Garmin
Oct 10, 2009 | Garmin (010-00583-00) for nuvi 750/760/770
Where on the windshield should I mount my Garmin?
you can put it anywhere you want as long as it is not obstructing your view. most people prefer the middle but close to the dashboard or to the left side of the windshield. bill
Aug 24, 2009 | Garmin nuvi 750 GPS Receiver
I need help downloading my music from comp.to Gps Garmin Nuvi 750
If you open the Nuvi folder in My computer, it could be a mounted drive.
supported file types are MP3, M3U, M3U8
Copy and paste to the folder.
then go to
Menu,tools,media player, source,browse.
In here you will have options too, fwd,rewind,skip, repeat,shuffle etc...
Hope this helps
Regards
Richard.
Apr 09, 2009 | Garmin (010-00583-00) for nuvi 750/760/770
I'm not sure where I should plug the recharger.
The charger plugs into the mount. You should be able to download the manual in English from the Garmin website.
Dec 15, 2008 | Garmin (010-00583-00) for nuvi 750/760/770
Garmin car charger
There are thee ways to charge the Garmin 750, 1: thru a car cord that plugs into the base that your unit mounts on. 2. Thru an AC charger. 3: thru the USB port on the Garmin unit itself. In your case the car cord plugs into the base that mounts your unit to the window. If that is not working, check that you are getting power from your car receptical. Check by plugging your Phone in or buying an adapter at Radio Shack that checks it. Also check the plug that goes into your car recepticle. Your manual tells how to check the fuse that is located in the end of the plug. If neither of these work your mount connection is bad. Hope this helps
Aug 02, 2008 | Garmin (010-00583-00) for nuvi 750/760/770
Garmin Nuvi 750 Car GPS Receiver Logo
296 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
