Question about Kenmore Sewing Machines
Does not go in reverse when pushing in the reverse button.
  • 96 Answers
This is an internal problem with the dial or reverse button
Posted on Dec 13, 2009
Does my Brother SQ9185 sew backwards other than the push button backstitch?
Use the reverse button. That's what it is for. Sew forward and then push the button and sew in reverse.
Machine Darning Jeans Shirt
If you have a darning foot, you can use it (drop the feed dogs) and then you manually move the fabric around while stitching.
Learn How To Mend Clothes with Machine Darning
Oct 01, 2016 | Brother Sewing Machines
Will not sew in reverse when reverse button pushed
my kenmore 385.17526 will not go in reverse when I push ...
www.shopyourway.com > Manage My Life > Questions
my kenmore 385.17526 will not go in reverse when I push the button ... Having asewing machine that doesn't reverse can be a bit disappointing, especially ...
Sewing Machine Repair ' ThriftyFun
www.thriftyfun.com/tf/Home_and_Garden/.../Sewing.../index.html
Sewing Machine Won't Sew in Reverse. My Elna 3007 became temperamental atsewing in reverse some years ago. On occasion, I will need to push the button ...
Bernina 1230 Reverse Button Fix ' Temecula Valley Sewing ...
https://tv-sewingcenter.com/bernina/bernina-1230-reverse-button-fix
Aug 30, 2010 - The reverse button of the 1230 had been pulled or popped out of ... All I had to do to fix the button was to hold the button in, and then push the cap forward. ... My 1120 Bernina reverse button will not work and the person who ...
Dec 28, 2015 | Sewing Machines
Operates only in reverse-How to fix
Isn't there a button that you would push to make machine go in reverse? You may have used this button and it got stuck in the reverse position or the button may be broken or disconnected. Pull the button outwards, put some penetrating oil on button to loosen up and see what happens or check for broken piece or check for bad contact. I hope this will fix your problem. GOOD LUCK FRIEND.
Feb 24, 2015 | Sewing Machines
My reverse button is stuck and the lights on the stitch panel keep flashing, how do I fix it?
Meybe if you reformulate your questin telling WHAT brans and model of sewing machine are you using, someone might give you a straight answer
Feb 06, 2015 | Sewing Machines
Buttonhole
Set the machine to button hole and use the "C" foot. The machine sews backwards first. When it reaches the correct length push the reverse button. Then when it has sewn the left side even with the right side push reverse again.
Dec 23, 2013 | Husqvarna Viking 1
I have a husgvarna Designer1and the reverse botton is not lighting up and is not going in reverse
The reverse button doesn't light up until the feed dogs reverse their rotation (feed rearward). The problem probably relates to the drive thats shifts the linkage to reverse the feed dogs (although it could be the linkage itself is out of wack). In any case, I doubt that you are doing anything wrong or that this is something you can fix yourself.
Jan 27, 2013 | Husqvarna Viking 1
V/74088/620
I am having the same problem. Initially it did sew forward, but now only sews in reverse. The large grey lever on the right front of the machine should make it sew in reverse only as long as it is held down, but mine sews in reverse only. Hmmmm....think there are many people with this problem.
Jan 30, 2012 | Janome 2049LX Mechanical Sewing Machine
The push down button for reverse is stuck and will not reverse. How can I fix this?
Just buy a replacement push button from Brother
Sewing Machine dealer.
Nov 08, 2009 | Brother LS2020 Sewing Machine
Husqvarna Viking Sweden Model 6030
On all sewing machines there is a button or lever which makes the machine go backward. The button could be stuck, if so put a drop of oil on it and try to release it. If there is a lever that has been raised which puts the machine in reverse, simply lower it to the lowest position. This should solve the problem.
Zelma
Nov 29, 2007 | Husqvarna Viking 1
Reverse only?
I too just aquired a husqvarna viking 6030 that was stuck in straight-stitch reverse. No forward, no zig zag, no button hole, no cam stitches. I also suspected a broken spring, since the reverse button was slack and had no resistance. But after inspecting every moving part, I realized it was just stuck from many years of non-use. I finally got it free today! I had used some Tri-Flow oil and applied it sparingly to all moving points (but not belts or motor). I exercised all the buttons and like another poster (either here or elsewhere, not sure) I used my hair dryer to apply heat to the inside of the machine through the cam slot. After you remove the white cover on back of machine that holds the two spool spindles, you will see a formed aluminum part just behind the reverse dial that has a rounded-pointed protrusion which sort of looks like a fat flat head screwdriver. It is supposed to travel in an up-down motion when reverse button is pressed. I used a flat head driver to coax its movement, and once it began moving, I continued with heat and drops of oil. Good luck.
Nov 11, 2007 | Husqvarna Viking 1
Sewing Machines Logo
82 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
SewTechWayne
SewTechWayne
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
