Question about NRS Hand Crank Flashlight
I didn't remember to keep it cranked up, and now it won't work unless vigorously and continuously cranking during use.
    Guru:
  • 302 Answers
Replace the small battery in your unit. It should work fine again.
Posted on Feb 12, 2010
HOw many crank positions sensors on a 2000 GMC 2500 savana. I replaced one and the same code keep showing up. Crank but won’t start.
There is crank and cam sensors.If you changed the crank sensor at the front under the front crank pulley and it is in the correct installed position, you should not have a code for that,unless the wiring is defective or the crank sensor is defective.
Mar 01, 2018 | GMC Cars & Trucks
Why no crank, no start after driving?
The ignition try and wiggle vigorously and see if it allows it to work if not you need to drop the starter and clean all the terminal ends of wires and reconnect
Dec 03, 2015 | 2005 Chevrolet Cavalier
Engine cranks vigorously but wont start in wet weather or during temperature changes
Remove the gas cap, to equalize the air-pressure.
As gasoline is consumed from the tank, a partial vacuum is left behind, making it more difficult for the fuel-injection pump to suck gasoline out of the tank.
Oct 15, 2014 | 1997 Dodge Dakota
I have a 05 trailblazer. It won't start. Thought
Are you saying it will not start, or will not crank ?
Jul 07, 2013 | Cars & Trucks
Why won't my 2012 Suzuki Grand Vitara start?
ill answer for NO ELECTRICAL POWER :
sure and is easy with any DMM meter, got one? any $20 DMM.
my guess;1
engine will not crank
dash lamps out.
head lights out. dead.
post systems of electrical system , all parts that work and those that dont work, and problem is easy.
cleaned battery terminals.
tried borrowed battery that reads, 12.6vdc ? (charged is 12.6)
2012 that is in warranty car.... ?
my guess on 2012
jumping a car, that is battery jump starting.
a battery can short, and no jump start on earth will start shorted battery in car. but does lay down some big sparks, or burns up cheap walmart cables.
if the car will not crank, say just that, my starter motor will not crank
jump started from live running other car.
if true then make sure headlights work , if they dont work fix that first.
HL must always work, even keys in pocket.
best is to put a fully charged battery in the car, jump starting can cause
surges that can damage sensitive electronic$$$, do jumps as a desperate measure,
with a charged battery,
1: Head lights work, no fix that , use voltmeter
2: cranks robustly.
no , wiggle shifter lever, (on A/T cars the park switch blocks cranking) On M/T the clutch blocks cranking.
with any dMM
measure battery voltage before crank and during.
12.6v good. reseted.
cranking.
0 to 10v bad (weak battery or shorted starter motor)
11 and above good. and must crank, if not , starter is bad.
to prove starter is bad, check voltage at starter solenoid coil wire lug.
it must be at 11v cranking , below 8v it chatters, and fails.
if at 0v cranking this lug that means the Key start line is failing.
A/T switch not closes, or bad ignition switch.
May 25, 2013 | Suzuki Grand Vitara Cars & Trucks
How do you test the fuel pump relay on a 1991 Toyota Celica 1.6 Car just died and won't crank. We changed the ignition coil and still won't crank. Fuel pump is working. Toyota place does not check...
If the car will not crank then you have a battery, cable or starter issue. If the car will crank but not start then the problem may be the fuel pump relay. There should be an electrical diagram on the side of the relay. Apply 12v to either side of the coil and you should here a click. Then check for continuity between the other two terminals with voltage applied. If you have no continuity then the relay is bad.
Aug 30, 2011 | Toyota Celica Cars & Trucks
Car starts poorly during cold mornings. The idle
Sounds like a cold start valve (which is actually an additional injector in the intake to assist in cold starting) If you can get it to your local prts store while the light is on they will read the codes for free and tell you what the car thinks is amiss.
Nov 13, 2009 | 1992 Acura Vigor
NRS Hand Crank Flashlight Logo
103 people viewed this question
Top NRS Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a NRS Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
