Question about Frigidaire AEQ7000ES Dryer
The dryer gives E68 it starts running dor 30
The dryer gives E68 it starts running for 30 seconds and stops with the E68. it will not shut off
    Problem Solver:
  • 5 Answers
The code 68 on the aeq7000es series is indicative of stuck buttons [your control buttons on the front]They sometimes stick in the closed position or go open [fail] and I have found the bad switch and replaced just the bad switch[ there should be a series of test to determine which switch button is bad] and if the switch buttons are testing good ,then it's control panel time. The control panels are about $150.00 on ebay ,sometimes you can find a "make offer" deal,but their few and far between.
Posted on May 24, 2010
E68 ERROR CODE FRIGIDAIRE DRYER MODEL NO GLEQ2152EE0. CAN YOU DIRECT ME TO A SPECIFIC PART NUMBER?
E68 for this model number says in manual that this is for a "button stuck" or held down for more than 30 seconds
ck all your buttons for one that just doesn't "feel right" when its pressed , this one will be your problem
Oct 29, 2015 | Frigidaire Dryers
Dv218aew Samsung dryer shuts off itselft after 30 seconds
Bad venting causing overheat? bad thermostats hi limit and cycling? thermal cutt off. bad moister sensor in the drum? giving wrong reading and cuting it off?
Sep 04, 2014 | Samsung DV218AEW Electric Dryer
Frigidaire affinity LEQ6000ES2 error code e68...dryer will not start
Good Afternoon David,
I understand that your Frigidaire Affinity dryer, model# LEQ6000ES2, is showing you an error code of E68 and will not start. I also see that you have changed the thermal limiter. Looking at what the E68 error code means, a key or button stuck, there could be something else causing the code to come up. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance, determine what is causing the E68, and repair your dryer. Hope this is helpful.
-Best Regards-
WP
Jul 04, 2014 | Frigidaire Dryers
What do i do when my fridgidair electric dryer displays error code e68
Good Afternoon Friend, this is Z. Thank you for your post!
If you are getting an error code E68 on your Frigidaire dryer, it usually indicates that one of the keys (buttons) is stuck closed (active). Let's try entering a "Function Test Mode" and perform Key Test to determine which button is at fault. To perform the "Function Test Mode": Press and hold the START and CANCEL button at the same time for 10 seconds. The stuck key should blink. Carefully free the key and perform the test again after proper diagnosis. If button is free but the error code still exists, the electronic control will more than likely need replacing after proper diagnosis. If you do not have a professional connection, you have the option to visit the manufacturer website to find a service provider in your area. Hope this helps!
May 22, 2014 | Electrolux Dryers
Aeq6700fso dryer dryness button won't change the
E68 is a stuck button on th control panel
Nov 06, 2012 | Dryers
PLEASE HELP! Dryer cuts off and gives an E68 code.
e68 code
this is a fault code that means there is a stuck key on the board you may have to remove the control panel and check the keys if this does not work you may have to replace the panel or control board
Good luck
Oct 05, 2009 | Frigidaire Dryers
Dryer runs for a few minutes, the shuts down. Display say E68. This is defined as current leakage. Any suggestons as to where this leakage is occuring?
I would contact customer support for Frigidaire. They will porbably be able to give you an idea. I would bet it is the dryer cord that could be bad.
Apr 08, 2009 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
Error Code
E68 error code, according the manufacturers operations manual found at this link: ftp://ftp.electrolux-na.com/ProdInfo_PDF/Webster/134431300esa.pdf
Says the the button used to start the machine has either malfunctioned or is "STUCK" in the start postion. Read this link I found and see if it helps. Best of luck to you.
Mar 18, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Dryers Logo
293 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
