Question about Texas Instruments TI-82 Calculator
TI-82 Screen Not Working or Black
I tried using my TI-82, which hasn't been used since I graduated in May, and the batteries were dead. I replaced all of them including the backup battery, and now, when I turn it on, all I get is a blank, dark screen (every pixel is at the darkest setting). Adjusting the brightness (2nd + down/up arrow) does not have any effect. What do I do?
  • 7 more comments
  • Armynavy Feb 16, 2008
    I have changed all batteries, and tried to adjust the brightness (with 2nd key and up down arrows.) Still no image on my screen. I do not have my manual.
  • ti82 Feb 26, 2008
    I have the same problem. I left my batteries there for over 2+ years, decided to use it once. There were battery acid everywhere. Cleaned it off. Put brand new batteries in it. Still no go. Just a dark screen.
  • jay211 Jun 02, 2008
    I have the same problem. I haven't used it in a while and my screen is black. What do I do?
  • Anonymous Aug 13, 2008
    I tried the "hard reset" and that did not work.
  • Anonymous Dec 16, 2008
    same problem here.
  • Anonymous Feb 17, 2009
    Hard Reset is not working either
  • Anonymous Feb 26, 2009
    same here
  • Anonymous Mar 04, 2009
    I experienced the same problem, I eventually found out that the "2nd" shouln't be held down while pressing the up/down arrows. Stupid but it fixed the problem...
  • Anonymous Mar 26, 2009
    hard reset worked for me...
    pulled batteries.
    held down DEL key, while replacing each battery.
    turned it on.
    contrast back to normal.
    thanks
Try a hard reset. Take out all the batteries, and while putting them back in, hold down the "DEL" key. Then, turn it back on and you can adjust the contrast by pressing the "2nd" key and the down arrow at the same time. I just got this info. online and it finally worked for me...good luck!
Posted on Apr 03, 2008
How do I reset my TI-86 after a long period of no use.
Every time you change batteries this will happen to you. First press 2nd then press and hold the down arrow. Hold until their is no black in the background but you can still see the numbers on the screen.
Sep 05, 2014 | Texas Instruments TI-86 Calculator
TI-82:blank screen like a dead battery. Just put in new batteries (all). Not used in years. Won't turn on -- anything I can do?
Hi
The TI82 is a bit old Technology and if you did not use for a few years the screen is dead its a common problem with this model and the TI83
sorry for not been a big help
Oct 21, 2010 | Texas Instruments TI-82 Calculator
I have replaced both the 4 AAA batteries and the cr1620 battery and the TI-82 will still not turn on. What else can I try?
TI calculators have an annoying habit of dimming the screen when the batteries are changed so that it appears as if the calculator isn't turning on. Turn the calculator on (or at least press the ON key). Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds and see whether the screen becomes legible.
Sep 26, 2010 | Texas Instruments TI-82 Calculator
I changed all of the batteries and tried to reset the ti-82
Turn it on. Press and RELEASE the 2ND key. Press and hold the DOWN-arrow.
Apr 07, 2009 | Texas Instruments TI-82 Calculator
Screen fully black
Black-Screen/Black-Pixel Fix for TI-Calculator
This will erase all memory and reset defaults.
1. Remove 1 AAA Battery
2. Press and Hold 'ON' for 30 seconds
3. Replace AAA Battery
4. Adjust Contrast to appropriate level
If this fails, try again with ALL Batteries removed including
the backup Lithium Battery.
If all else fails, try the following reset procedure:
1. Remove ALL Batteries (inc. Backup)
2. Let Calculator sit with no batteries for 2~4 hours.
3. Hold 'ON' for 30 seconds.
4. Replace all the batteries (May be good idea to use new batteries
just in case old ones were dead)
5. Turn on Calculator
6. Change Contrast to appropriate level
- Remember to use correct batteries or calculator may not work. The
correct batteries are Alkaline, Rechargable Batteries are TOO WEAK,
Heavy Duty batteries are TOO STRONG.
Oct 09, 2008 | Texas Instruments TI-89 Calculator
TI-82
try this, try reseting the calculator blind. hit 2nd then + then 7 then 1 then 2. That's how you reset it on an 83,84,89 and so on. if you have a friend see how he resets his 82 and try it the same way. It could just be that your screen is ruined. this can happen if it gets alot of pressure in a back pack. GOOD LUCK
Feb 01, 2008 | Texas Instruments TI-82 Calculator
HELP!!
Well, in most calculators, the action of taking out the backup battery practically clears the whole thing. Memory, everything. I myself have a Ti-89 and have not yet experienced this problem, but I have on an older Ti-82 and removed the backup battery and the whole thing is dead now, or at least nothing happens when I turn it on, even after replacing the batteries again. If you still have the manual, I would check out the troubleshooting. If you don't have it, try to find it online. And if you have done both of these things, try getting hold of technical support through Texas Instruments.
Jan 30, 2008 | Texas Instruments TI-89 Calculator
TI-82 WANT COME ON
If you haven't tried this already, adjust the brightness (2nd + Up Arrow). Also, the backup battery, which is removed by unscrewing a small plastic panel in the battery compartment, may need to be replaced as well.
Oct 27, 2007 | Texas Instruments TI-82 Calculator
Texas Instruments TI-82 Calculator Logo
4,910 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
