Can i add another 500gb hard drive in my compaq 5450f desktop?identical hard drive.if so will it just recognize it when installed?thanks*
    Problem Solver:
  • 4 Answers
If you have unused usb ports, you can get a usb-hub device so you can connect more usb-devices.
as for usb-hd, you are only limited by the number of open ports. size doesnt matter :)
Posted on Nov 18, 2009
How to piggyback a larger hard drive on my dell dimension e310 computer
I think you are talking about adding the 500GB Hard Drive to your system. It will give you more Disk Space, but not more memory. If you want to add the drive just Remove the Power Cord, Remove the Case then notice how the hard drive that is already on your system is in the drive bay and the cables going into it. There should be another empty bay above or below for you to place the 500GB Drive. There are also some extra cables that will plug into the drive. Once you have the drive in place and the two cables plugged into it, put the case back on then plug the power cord and plug it up.
Your system will recognize the hard drive once windows boots up. Click Start/My Computer and you should see your Local C Drive and the new 500GB Drive. If not, shut the down then restart it and notice what key it says to hit to get into the Bios or System Setup and hit that key. Once you get into the setup look for the hard drives. You will probably see your old drive listed as Sata 0 or Sata 1. You want to take the next Sata that is available and set it to Auto so that it can automatically get your new drive's configuration. Once you do that, save it and exit out of the Bios then Reboot.
Once the system recognizes your new drive you can copy things from the old drive to it. You can't just copy programs, programs have to be installed to the new drive. But you can copy things like your documents, music, pictures and videos to free up space on your original drive. Also when you download and install things, it will default to going to drive c which is your old drive. You can change it to go to your new drive by just changing the letter c to whatever is assigned to your new drive. Most likely it will be drive d, but you can click Start/My Computer and see what the 500GB drive's letter is.
Maybe you friend had some cloning software where he could just clone your old drive onto your new 500GB Drive, then you could make the 500GB drive your Local C Drive by switching the cables.
May 06, 2012 | Dell Dimension E310 PC Desktop
I have two identical drives one external hard drive 500gb and one hard drive 1tb both have same files but jpeg on 500gb not recognized
hi there, it could mean that that section of the hard disk may not be readable. My suggestion is to back-up all files on the hard drive just because it sounds like a hard disk is going to die soon.
Dec 29, 2009 | Pioneer DV-440 DVD Player
Not recognized
A Network Drive, that which is connected via an Ethernet cable will not appear as new hardware. You should have connected it to the router on your network, then seen it as a network device.
Check My Network Places.
You will need to Map a drive to see it every time you boot.
Nov 29, 2009 | Western Digital 500GB My Book World...
External no longer recognized
Right click My Computer, Properties, then click on Device Manager.
Select Disk Drives then on tab menu Action, Add legacy hardware. Go through the setup and use CD's that came with Hard Drive otherwise search company site for drivers.
Oct 05, 2009 | SimpleTech 500GB SIMPLEDRIVE EXT HD-USB...
WHATS THE HARD DRIVE LIMIT OF A COMPAQ PRESARIO SR1315CL
The motherboard of your computer has two IDE and two SATA connections.
There is no upper limit of the drive size (at least nothing you have to worry about if you have WInXP, Vista or Linux installed)
Attention!!! - I heard from many people that HP (Compaq) has disabled the SATA connectors on your motherboard (ASUS A7V8X-LA)!!!
If you want to be on the safe side (and I would definitely recommend that) go and get an IDE drive. There are many good drives around with 500GB of storage.
If you have any more questions, just come back here and leave a comment - I'm happy to help.
Apr 19, 2009 | Compaq Presario SR1313CL PC Desktop
Problem with recognizing 2nd hard drive in Compaq EVO D510
you need to initialize the newly added drive in disk management, then format the drive once disk management assigns a drive letter.
CONTROL PANEL, ADMIINSTRATIVE TOOLS, COMPUTER MANAGEMENT, DISK MANAGEMENT
There you should be able to see the 2nd drive, Right click and INITALISE it, once it is initialized, it will be assigned a drive letter and you can format the drive
Feb 05, 2009 | HP Compaq Evo D510 e-PC PC Desktop
Dimension 4700 with Barracuda 500Gb SATA HDD
You have to go online and search then download the drivers for preparing SATA laptop harddrives for installation of Windows XP otherwise during installation it will tell you there is no hard drive found.
Dec 12, 2008 | Dell Dimension 4700 PC Desktop
REINSTALL XP HOME EDITION ON Compaq Presario SR1350NX Desktop PC
Files copy errors during the XP installation process are often an indication of BAD RAM.
If you have dual RAM modules, try install with 1 memory module installed
May 19, 2008 | HP Compaq Presario SR1350NX (PP196AA#ABA)...
Computers & Internet Logo
65 people viewed this question
David Payne
David Payne
