Question about LG VOYAGER VX10000 Cellular Phone
HI for that waching mashin 5 kg model WD-80264NP the spin program have been stoped sudenly the washing machin is working but on the spin time it dosent continue ,only runing and the displayng time will be on hold .exemple ,it will stop on the nb 14 and it will not continue. what shoul i do thank you
Whirlpool 360 bloom wash 8 kg top loading full automatically washing machine. Model 13712 is a not spin
check for unbalance activation or lid lock malfunction
if you can get past the spin cycle then it will be a problem program board
Dec 16, 2015 | Whirlpool Washing Machines
What is OE in lg wd 80264np error code
Sorry but I do not know your particular machine but on some models it means 'no drain'.
So- here are my generic/general guidance notes ;-0)
I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
If you are unsure where the filter is, it is normally behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Feb 19, 2011 | LG WD-1295FB Front Load Washer
I have an lg 5kg washing machine WD-80264NP which stops after washing for while.it doesn't spin. what could be the problem?
Ur timer switch for washing/spinning is broken, there are contact points on that timer switch, the part of SPiNNiNG is not functioning!
Let a technician check on that, and might as well replace it!
Nov 29, 2010 | LG Washing Machines
Hi i want to know that a waight of 6 kg washing maching is a small one for cloths or it is ok . should i go for more than 6 kg. for 4-5 persons family. thanks.i just choose a whirlpool compact model of...
Your question is not easy to answer. An average washing machine is 8 kg. The smaller 6 kg will use less water and detergent, but you will be limited to 4 or 5 pair of jeans at one time...unless your children are small. A front loading machine may be a better choice for you. It can do very large loads, 12 kg, and still use less water and detergent than most top loaders, but be prepared to pay three times the price of a top loader.
Sep 20, 2010 | Whirlpool Washing Machines
Rinse and spin
there is a safety switch on the top...and when you close the lid it pushes down on that switch. investigate that switch and see if its just corroded or needs replacement...i have that same problem when i leave the lid open on my washer...then it works fine when i close it...so im figuring that your's thinks its still open. I hope this helps you out ! and give your wife a hug 8-)
Jun 05, 2009 | Washing Machines
SAMSUNG waching machine doesn't want to drain and spin.
drain pump blocked. remove bottom bung filter where hose comes out. will be a hair pin, bread tag stuck in fan blades
Feb 22, 2009 | Kenmore 24032\24036 Top Load Washer
LG VOYAGER VX10000 Cellular Phone Logo
47 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
