Question about MicroBoards PF-2 InkJet Printer
I cannot print despite new ink
My PF-2 is indicating the ink amber color but the ink is a new one. what could be the problem?
    Genius:
  • 1,011 Answers
Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Posted on Nov 18, 2009
My printer Micorboards PF-PRO not print the yellow color, same with new ink cartridge
please follow the troubleshooting software with the printing. and make the test for clean it. etc.
Otherwise, the cartridge can be faulty.
God bless you
Nov 24, 2013 | MicroBoards PF-Pro Autoprinter Optical...
PF Pro printing pale blue instead of black
you are printing composite black instead of pure black.
Still problem is the print head not getting all inks (may be air, or you didn't remove some seals on the inks/print head.
Nov 07, 2013 | MicroBoards Office Equipment & Supplies
I have artwork that is mostly black text with a logo After printing only 1 or 2 discs the print factory 3 starts making the black red. On another disc that has multiple colors it prints nothing in the...
Welcome to FixYa!
Solution 1. You might want to check the ink levels of your printer. One of the ink color might be out. Your printer uses the C,M,Y (one cartridge) and K (another cartridge). The printer mixes this colors (C,M,Y,K = cyan, magenta, yellow and pink) to produce the right colors including black.
Solution 2. Please do a printer head cleaning. You can do it using your printers software maintenance option.
Thank you for using FixYa.Have a great day.
Dec 23, 2011 | MicroBoards PF-3 InkJet Printer
Print head failure signal
Error 5 is an ink cartridge error. Cleaning the print head and electrical contacts on the cartridge does not fix this error. You need to get a new cartridge to fix the problem.
Feb 09, 2010 | Canon BubleJet i965 InkJet Printer
My Microboards PF2 does not print color properly.
The next to last cartridge I installed did not print properly. It seemed like all the colors were not there so I weighed it on a postage scale and it weighed less than another new one I had. I called Microboards. They said to send it to them and they replaced it. It may not be that, but weighing it should give some indication if it is.
Dec 07, 2009 | MicroBoards PF-2 Disc Printer
Brother MFC5440CN - Yellow cartridge does not print despite being
Print head will have to be replaced. Whenever one or more colors won't print and you've gone through the cleaning process, the printhead is bad!
Jan 02, 2009 | Brother MFC-5440CN All-In-One InkJet...
Ink button flashes,with new ink cartridges, doesn't load or print
You may have damaged or punctured the Print Head. Please remove the cartridge and inspect. i think Replacement of the damaged cartridge is the resolution.hope this helps .Goodluck thanks and Godbless
Dec 15, 2008 | MicroBoards PF-2 InkJet Printer
Standard black printing has faded to grey.
Could just be a faulty cartridge?
My hp printer developed a similar fault, and despite all my attempts to clean, realign, whatever, the problem wasn't solved till I fitted a new ink cartridge. It's worth a try.
Nov 15, 2008 | HP Officejet Pro L7680 All-In-One Printer
PF-2 Won't detecd cd
First try re-installing the PF-2 print drivers. If that doesn't work, then try a different ink cartridge. If you have printed more than 5000 discs in the printer, it just may need a good cleaning as the sensors would be full of dried ink.
www.techwaredist.com
Nov 07, 2008 | MicroBoards PF-2 InkJet Printer
I have and hpdeskjet 960c printer. The amber light over the symbol for the ink cartridges is blinking. I replaced both the black and color cartridges. The light is still blinking and the printer won't...
open the top cover and allow the print cradle to move to one of the icons this indicates what the problem might be
it either shows that the cartridge is not inserted properly or the incorrect cartridge
or may be low on ink.
remove the cartridge and reinsert
if all else fails replace with new cartridges
Oct 02, 2008 | Office Equipment & Supplies
MicroBoards PF-2 InkJet Printer Logo
171 people viewed this question
Top MicroBoards Office Equipment & Supplies Experts
isaac johny
isaac johny
Tom Chichester
Are you a MicroBoards Office Equipment and Supply Expert? Answer questions, earn points and help others
