Question about HP LaserJet 2420dn Printer
HP Laserjet 2420 is printing ghost images - on the left side, from the margin to roughly 1" in, there is a lighter image of he text printed above.
  • 1,110 Answers
Your fusing unit is most likely causing this. You will need to replace the fusing unit or if you can find a reputable tech you can save a bunch of money and just have the fuser film replaced. I have done this on dozens of HP printers with excellent results.
This is a common problem.
Posted on Nov 18, 2009
2840 laser printer only prints on right side and nothing on left side
My Color LaserJet 2840 will only print on the right side of ...
h30434.www3.hp.com > ... > Scanning / Faxing
Apr 26, 2011 - 2 posts
I have a HP Color LaserJet 2840. If I am ... My Color LaserJet 2840 will only print on the right side of the page, how can I fix this? ... If I am copying or printing from the computer, the printer will only print the right side of the page. ... something obstructing the laser scanner blocking that side of the media path.
HP 2840 printing problem ' FixYourOwnPrinter
www.fixyourownprinter.com/posts/46992
Feb 1, 2010 - ... Apr 19, 2007 at 10:57am. 0. HP Color LaserJet 2840 ... I have the same issue as above-Not printing on the left side of pages.I went threw the ...
HP Laserjet 2840, various problems ' FixYourOwnPrinter
Dec 25, 2015 | HP LaserJet 2840 All-In-One Printer
Ghost printing preceeding page images and or text
1.Most likely is the fuser assy, depending on what your page count is. 2.Could also be your toner cartridge especially if it is a reman
Dec 08, 2009 | HP LaserJet 4345mfp Printer
My hp laserjet 2420 printer won't print out my bottom text of my legal size document. when i preview my print it cuts off all text at 9.5'' . what's wrong? my margin's are all set to 1'' and i customized...
Do NOT use customized paper. Set your paper tray to LEGAL paper. Set the tray as LEGAL in the printers setup-menu. Make sure you choose LEGAL in the printout-dialog-properties. Then it should work. Good Luck.
Aug 14, 2009 | HP Hewlett Packard LaserJet 2420 Printer
HP 3015 laser printer with ghost image
A fuser image should only be about 1 1/2 inches away, 3 inches sounds like a drum problem.
Aug 03, 2009 | HP LaserJet 3015 All-In-One Printer
Blurry text print with ghost image
Hey,
Your problem could be because of bad alignment. That means paper alignment and printer alignment don't match. There will be instructions in,your manual to properply align your printer.
Hope this helps.
Thanks
Apr 15, 2009 | HP DeskJet 3745 Printer
How to clean the print head
The problem you are having is either the cartridge or fusing assembly. One or the other will need to be replaced. There isn't a head cleaning function on this laserjet like inkjets. Here's how you can tell which it is. If the image is ghost repeating, measure the distance from the first occurance on the page to the place (ghosting) it appears again. Here are the most common spacings.
Measurements are Aproximate
75mm or 2-15/16th" = Fuser (replace fusing assembly)
94mm or 3-11/16th" = Cartridge Drum (replace toner cartridge)
38mm 0r 1-1/2" = Cartridge Primary Charge Roller (replace toner cartridge)
Hope the above helps you. If so please rate my answer with a FIXYA. If not send me more info and I help you further. Thanks.
Dec 08, 2008 | HP LaserJet 2420 Printer
My HP printer 2420 leaves "ghost" prints on the pages.
This can be caused by one of two things.
1. faulty wiper blade on your toner so that the previous image in not being wiped off the drum.
2. worn fuser sleve.
To work out which it is you will need to do a half stop test: print off a normal document then when it is about half way through the printer ( unfortunatly you may have to repeat this to get the timing right) open the front cover. remove the toner cartridge. if you can see the ghosting on the page the it is the toner. if its not there then its a new fuser. to save on money and if your confident enouh you may be able to just chane the fuser sleve depending on the state of the fuser on a whole.
hope this helps
feel free to email me if you have any other questions:
pete@wedotoners.com
Oct 21, 2008 | HP LaserJet 2420 Printer
HP LaserJet 1012 Printer prints ghost images
I ran the hp toolbox "cleaning" mode too and it did not help the problem at all. I still have a dark smear concentrated in the middle of the page, and ghost images repeated lighter all the way down the page.
Aug 21, 2008 | HP LaserJet 1012 Printer
HP LaserJet 2100tn prints ok but with 3 lines of strange characters over image
Is your transfer roller clean?
How does the drum look on the toner cart?
Is the fuser getting bad?
Would you consider this an old image that is ghosting?
Jun 24, 2008 | HP LaserJet 2100 Printer
Hp 2420 printing light on left side of page
take out cartridge and look at roller on bottom of printer, clean with clean cloth and try, also there is a slit ( or hole on the inside ( put your hand inside and try to touch the top of printer there is a hole there where the images go to the laser clean with clean lint free cloth.
Nov 01, 2007 | HP LaserJet 2420 Printer
HP LaserJet 2420dn Printer Logo
824 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
