Question about Brother IntelliFAX 2800 Laser Fax
Black Streak A black streak is showing up (vertically) on each page.
  • 788 Answers
I would first try a diffent cartridge. If that doesn't work then you might have a bad transfer roller, the printer may need service.
Posted on Jan 10, 2008
When I scan two-sided to pdf, the back page has a large black vertical streak down left side.
If that is the last page that has the streak use a blank page in the original scan as the last page and then the dark line wont cover the image.
Aug 19, 2016 | NEAT Office Equipment & Supplies
Printing a black streak
replace the black image unit and or the fuser
Apr 04, 2014 | Konica Minolta Office Equipment & Supplies
Canon NP6221 copier makes copies with black streak down middle.
I suggest You Go to Official Canon Printer Page For You Canon Problem On Below Canon Page URL:
Copy Has Vertical Black Streaks In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On : Canon Printer Support
Feb 16, 2014 | Canon NP6221 Fuser Thermofuse
My brother MFC 8500 is receiving alright but everything I send out has a big black streak going down the right side of the page. Confirmation page also has big black streak.
Let me see if I got this right.
The received fax is clean but when you send one out it has a black streak on it.
Cool! So far so good.
Makes sense because for sending, the fax scans the original document and parts of the scanning area could be dirty and so on. Therefore a black streak may appear.
The same black streak would also appear when you make a copy, because the original document must also be scanned.
However for receiving faxes, the machine uses the internal memory and the print engine only, and the same applies to printing the transaction report, which comes from inside via the print engine.
The scanner has no rol in either situation.
Now I'm lost!
May 31, 2011 | Brother Office Equipment & Supplies
Wide black streak
Yes, you have a burned out scanner block element. It's cheaper to buy a new fax machine
Mar 30, 2010 | Brother BRTPPF4750E...
Printing a large black streak of toner on rt side of page
Hello! Malik Muhammad Mehran Here... your problem solution is that you must replace the cleaning plates in the cartridge...
Mar 28, 2010 | HP LaserJet 6L Printer
There is a white vertical streak on pages I print.
You can pull out each cartridge and shake it gently to redistribute the toner. Try a half page test to eliminate the various stages of the image formation. The timing on this is not easy but through trial and error it can be helpful.
Jun 25, 2009 | Cannon MULTIPASS C530 Printer
Prints black vertical line at bottom of page on every print. HP 8550gn
This should help -
Developer streak
Developer streak is characterized by a line of dark or missing toner
that stretches from the leading edge to the trailing edge. Replace the
toner cartridge corresponding to the color of the developer streak (for
example, if the streak is magenta, replace the magenta toner
Repetitive defects troubleshooting
Repetitive defects are defects that occur in the same vertical position
on the page, but not necessarily on every page. Most repetitive
defects are caused by problems with one of the following, and are
indicated by the positioning of the defect on the page:
 developer roller (at 38 mm)
 charging roller (at 44 mm)—see additional information under
“Charge roller set” on page 454.
 cleaning roller (at 56 mm)
 developer DSD wheels (at 65 mm)
 transfer roller (at 66 mm)
 transfer drum (occurs once per 11-by-17 inch or A3-sized page,
or every other letter- or A4-sized page)
 fuser (at 150.5 mm)
 imaging drum (at 195 mm)
 transfer belt (at 222 mm)
May 21, 2008 | Office Equipment & Supplies
Black smudgy streak in middle of printed page
if you need any parts for that machine a have 4of them
Thank You,
Feb 26, 2008 | Ricoh Aficio AP3800C Laser Printer
Blank Streaks
streaks are caused either by the toner, drum, lamp or fuser.
If you make a copy and it does not show a streak then it was done by the person sending the fax. BUT, check this,
open door and take out toner cartridge. look for a thin glass that is on the bottom of the machine and wipe it. Toner spills will cause a black streak.
Nov 15, 2007 | Brother IntelliFAX 2800 Laser Fax
Brother IntelliFAX 2800 Laser Fax Logo
176 people viewed this question
James Cagle
James Cagle
Jim Keysor
