Question about Cell Phones
My dishwasher is not completly draining, theres standing water and around the door edges there is black mold like sustance?
  • 71 Answers
I had a similar problem. Clean out the drain - you'll have to remove some sort of screen - & replace the impeller. In mine it was an inexpensive plastic part. Once your dishwasher is draining you should remove any mold. Try vinegar or dishwasher detergent & a brush; avoid anything toxic or damaging to the inside & gaskets.
Posted on Nov 18, 2009
GE dishwasher PDWT480R10SS does not fully drain at end of cycle
you need to clean the outside edge of the disk at the bottom of washer and put high heat silicone around the outside edge and let it dry 24 hours before use, if it still doesn't drain all the way ,you will have to replace the disk. I have repaired many of these . good silicon should do it.
Sep 14, 2014 | GE Dishwashers
The loading door gasket-- the big rubber liner doesn't drain
Some front loaders have a door boot drain hole, most do not and it is normal for some water to accumulate at bottom of boot. To help with mold and mildew use a washing machine cleaning solution, follow directions. Also a bleach solution of 2 parts water 1 part bleach sprayed on area helps. If mildew is really bad, nothing will completly remove it. Make sure you use only a high efficiency detergent.
Feb 03, 2010 | Washing Machines
LG WM1814CW Front Load Washer rubber seal on front door collects water underneath and now has black mold, and a strong odor, like cigarette smoke.
Use some detergent plus baking soda and mix it in with the water--rub it around (with an old toothbrush) to loosen the mold. Let sit for a while, then wipe water, mold, and cleaner away. Finally, rinse with clean water and wipe dry. Leave the door ajar to air out after each wash. It will help to remove the standing water each time. Don't poke a hole in the seal to drain the water out, because water will then run out of the bottom of the washer.
Sep 28, 2009 | LG WM1814CW Front Load Washer
Maytag MDB5100AWB Dishwasher not draining
More than likely the filter is clogged,remove the spray arm(there is a threaded cap in the center of the arm twist it to the left,then remove the # 15 or 20 torx(star shaped) screws out of the filter cover(around the edges)The filter is round and runs around the outer edge of the pump housing it lifts right out,clean it and reverse the process.It's the most common issue with not draining on this model.
Sep 26, 2009 | Maytag MDB5100A Dishwasher
What causes an orange stain in the tub of the dishwasher and around the edge of the door?
Dishwashers are prone to mold and mildew this time of year. Clean all of the orange stains with a solution of one cup of clorox bleach in two quarts of water. Then run the dishwasher on its hottest and longest cycle adding only two cups of vinegar through the door opening. That will clean up the entire insides and remove the clorox smell.
Aug 02, 2009 | Dishwashers
Mold in the rinse aid compartment.
You should check your pump located in the back of the machine to make sure that it is pumping water out. Also see why the fan is making noise and replace the fan. Also check your hot water supply. Mold wont grow if the water is the temperature it is supposed to be and seems like youa re just washing with warm water or even cold
Feb 16, 2009 | Miele 24 in. G646SC Plus Free-Standing...
Water not pumping into dishwasher
I first checked the water valve in the dishwasher. It was working properly. The overflow or water level sensor had become stuck in the 'high level' position, thus telling the washer that it was already full of water. I corrected that and it began working properly. As for water in the bottom of the dishwasher that didn't seem to be draining completely - I turned the timer to a point in the cycle where it would drain, making sure I turned the washer off before it cycled back to the 'fill or rinse' cycle. I think the water had accumulated because of the timing of the cycles getting out of sync with the water level in the washer.
Jan 06, 2009 | Dishwashers
Black Mold growing inside dishwasher
this is an easy fix use 1 part bleach to 10 parts water and wipe down this will kill the mold you may need to do this several times
Dec 08, 2008 | Dishwashers
Leaks while running
The water at the bottom is normal if you open it during the cycle. Leak means you need to replace the L-shaped black, molded gasket that is in the lower left or right of your door opening. Replacement is easy - requires no tools. Part can be purchased for about $10 each at Sears parts department.
Sep 07, 2008 | GE Nautilus 24" Built-in Dishwasher
GSM2100G02WW/SH791112B
cleaners are available from Lowe's home depot appliances parts stores etc but it sounds to me like you have a drain problem check your drain line where it attaches to your sink and where it goes into your sink for blockage take off the bottom kick plate and you will see a black solenoid with a silver shaft and a white plastic rocker and spring make sure that the silver shaft moves up and down freely if not replace that seloinoid or call for service
Jan 09, 2008 | GE DBSR453EBWW Electric Dryer
Cell Phones Logo
82 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
