Question about Mmats Juggernaut 15'' Car Subwoofer
I need the corrects specs for my 15 - Mmats Juggernaut 15'' Car Subwoofer
  • 32 Answers
Heres all the specs you could ever need: http://www.shopping.com/xPO-Mmats-Juggernaut-15
Posted on Jan 27, 2010
I need to know what the recommended box spec for a audio Bahn dJones special edition 15 woofer 500 watts is trying to build a box for it
These subs are the (AW1251SE). Go to the Audiobahn website and look up the specs. I have included a hyperlink that will take you to the correct page. Find the model number and download the PDF. Inside the PDF file it will have every parameter listed, I already looked at it and made sure. It also has different enclosure options and gives the specs for each one.
http://audiobahn.com/index.php/help/tech-support/manuals/category/6-subwoofers.html
Aug 18, 2015 | Car Audio & Video
What the torque specs. For a 2002chevys10 4.3vortex mains and rod bearing
Torque Specs Database
Type: Dim: Length: Head: Nut Grade: 20 Ft-Lbs 240 In-Lbs 27.12 N-m Connects: Connecting Rod To Engine Block Years: All Vote Record: Vote Note: Vortec - Rod Cap Nuts - 2 Steps: 20 FtLbs; +70degs
http://ww2.justanswer.com/uploads/ZZdaryl/2009-06-14_153454_torque.pdf
Main Bearing Cap Bolt 4.3L Step 1 15 ft lbs (20) Step 2 Additional 73 Degrees
i don't know if that's correct for main bearing caps since another link states it's much higher
4 3 Vortec Piston Specs eHow
hopefully a GM guy will chime in to confirm the main bearing torque
the rod bearing torques are the same on all the other links
Mar 25, 2015 | 2002 Chevrolet S-10
1994 Kawasaki ZX-6R Ninja firing order
Hi, Anonymous for this scenario you will need your service manual that has all fastener torque specs and a wiring diagram on the back pages, parts fiche, and owners manual if you can't find the best tool you ever bought for your Kawasaki, despair not, for a mere $15 you can download another one.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
correct firing order with wire correction
1994 Kawasaki ZX 6R Ninja firing order Google Search
Kawasaki Ninja ZX 6R 1995 2002 Service Repair Factory Manual Download... $15
OEM Parts for Kawasaki
Kawasaki Ninja Owners Manuals
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Aug 13, 2014 | kawasaki ZX-6R Ninja Motorcycles
2011 Kawasaki Ninja 250R fork stem lock bolt torque spec
Hi, Clhamon for this scenario you will need your service manual, parts fiche, and owners manual if you can't find the best tool you ever bought for your Kawasaki, despair not, for a mere $15 you can download another one.
EX250 Torque Values
Tighten the steering stem nut please tell me how ninjette org
Kawasaki Ninja 250R 2008 2012 Workshop Service Repair Manual Download... $15
2011 Kawasaki Ninja 250R Owner Manual
Jul 26, 2012 | 2011 kawasaki Ninja 250R
1998 Kawasaki ZX-6R Ninja sprocket torque specs
Hi, Mouserider19 for this scenario you will need your service manual that has all fastener torque specs and a wiring diagram on the back pages, parts fiche, and owners manual if you can't find the best tool you ever bought for your Kawasaki, despair not, for a mere $15 you can download another one.
http://zx6r.com/zx6r/7051-torque-specs.html
Sprocket Torque Specs
May 30, 2011 | 1998 kawasaki ZX-6R Ninja
1998 Kawasaki KLX 300 front fork torque specs
Hi, Rpatritti for this scenario you will need your service manual that has all fastener torque specs and a wiring diagram on the back pages, parts fiche, and owners manual if you can't find the best tool you ever bought for your Kawasaki, despair not, for a mere $15 you can download another one.
KLX 300 torque specs
fork torque specs Kawasaki Forums
Kawasaki KLX300R service manual repair 1997 2005 KLX300 Download Manuals... $15
Download Manual 1998 Kawasaki KLX300R Owner Manual
Aug 18, 2010 | 1998 kawasaki KLX 300
Engine Specs.
you should ask for the advance tool if you are buying one . i had 8 of the screaming boat anchors and i can't recall if it's a 1771 or a 1441 and be sure you don't split the rack or it will not pull the hat off your head
Apr 06, 2009 | 1990 GMC S-15 Jimmy
Need the correct torque specs for 2004 silverado 1500 calipers
  • Tighten the 2 brake caliper mounting bolts to 108 Nm (80 ft. lbs.) . Caliper Mounting Bracket to Knuckle, Front (15 series) 175 Nm (129 ft. lbs.) Caliper Mounting Bracket to Knuckle, Front (25/35 series) 300 Nm (221 ft. lbs.) Brake Caliper Mounting Bolt Rear (15 series) 42 Nm (31 ft. lbs.) Brake Caliper Mounting Bolt Rear (25/35 series) 108 Nm (80 ft. lbs.) Caliper Mounting Bracket Bolt Rear (JC5/JH5) 200 Nm (148 ft. lbs.) Caliper Mounting Bracket Bolt Rear (JH6) 165 Nm (122 ft. lbs.) Caliper Mounting Bracket Bolt Rear (JH7) 300 Nm (221 ft. lbs.) Caliper Mounting Bracket Bolt Rear (NYS) 200 Nm (148 ft. lbs.)
    hope this helps
  • Mar 28, 2009 | 2004 Chevrolet Silverado
    Correct settings
    I am not familiar with your amp, but any amplifier performs best when the output stage effective resistance exactly matches the load resistance. So, read your 15" subs and find out number of ohms, then set the amp to that number. according to your amp's specs: if you have 2 ohm speakers, you can draw 350 watts from your amp. so purchase 2 ohm speakers
    May 31, 2007 | Alpine MRD-M301 Car Audio Amplifier
    Mmats Juggernaut 15'' Car Subwoofer Logo
    278 people viewed this question
    Top Mmats Car Audio & Video Experts
    xxxxxx xxx
    Are you a Mmats Car Audio and Video Expert? Answer questions, earn points and help others
