Question about Hitachi 43F300 43" Rear Projection Television
Color Issues with red ghosts on screen
Issue started suddenly from one use to the next. images have red ghosts, and text is nearly unreadable. I tried the auto-focus feature but it did not help.
    President:
  • 4,402 Answers
The suggestions listed would be relevant for 'Ghosting' by itself, however you mentioned you tried to use the crosshairs to line up the imagesColor Issues with red ghosts on screen - 4.gif, which implies convergence - red/green/blue image separation and/or distortion. NONE of the solutions mentioned were anywhere close to the fix for this problem - this us usually cut and dry; convergence circuit failure. Generally, STK ICs are used. (Common parts are STK392-010/020/040, STK392-110/120/150/180, etc.) Most times replacing BOTH of these chips will be enough, sometimes there will be a blown fusible resistor and/or burnt resistors near the chips themselves. If you don't implicitly know exactly what I'm talking about, don't attempt it - take it in to a repair shop. For in-shop repair, this would NOT exceed $250 (EVER) at our location, unless there was more damage done, which is a one in a hundred situation. Good luck!
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Posted on Jan 10, 2008
WD 73835 has ghosting images during dark or red scenes
Make sure your contrast isn't set too high. Most ghosting is caused by either contrast, brightness or tint issues. Try adjusting these settings. Also check if there is a Dynamic contrast setting for your TV as well as this can cause ghosting also.
Apr 06, 2014 | Mitsubishi Diamond 835 Wd-73835 73" 1080p...
Composite output has ghosting around the video (sort of an auro around all images on screen, including text and video). dvd menu also has this problem, so i verified that it is the output of the recorder...
Try reducing your sharpness value on either your TV or the player if applicable. Also disable any edge enhancement or "DVE" modes on the TV if applicable.
The easiest way to adjust sharpness control by the naked eye is with a calibration disc. Alternatively however, just for sharpness if you have a screen full of text and/or lines do the following;
Reduce your color/saturation value all the way down...this will make the picture black and white.
Then reduce your sharpness control until the "ghosting" effect or any additional white lines on text edges and line edges disappear.
Then you can return your color/saturation value back to normal.
Hope this helps!
Jan 12, 2011 | Toshiba DR4 DVD Recorder
Screen image turns red after 15 minutes
Ur backlight video board it,dying.Micro processor have shorted,must change the backlight board.
Nov 24, 2009 | Polaroid FLM-3232 Television
Polaroid FLM-3232 Screen image turns red after 15 minutes After about 15 minutes the image on the screen will start turning red. After about 5 more minutes the images are nearly all black with highlights...
pick up a can of freeze spray at staples and run you set till it breaks down with the back ooff so you can get at it fast when it fails spray your t-con board locates at the top middle see if it stops doing the symtom you saw. if not spray the mainboard this way you can deturmine which board it failing
Nov 24, 2009 | Televison & Video
Color red is warping or ghosting
You need to have the convergence chips replaced.
It liiks like 3D?
Thanks for using FIXYA
Oct 26, 2009 | Televison & Video
The picture on my Vizio 42" flat screen suddenly shifted to a whitish pale color with ghostly looking images that look like negative film.
This is the fix for the Main board repair :
Locate IC 32 small 8 pin surface mount near top of Main Board and remove. Short pin 2 to pin 5. (pin 5 through 8 are together and pin 2 and 4 are together)
You will need a good TV Tech to do this for you.
Aug 04, 2009 | Vizio VO42L 42 in. LCD TV
Westinghouse LCM-22W2 has "ghosting"
Usually, LCD monitor ghosting appears when the cable isn't tight, the cable is faulty, or low quality. The cable should be less than 8-10 feet long. Try using a different monitor cable (they're mostly interchangable) and see if the problem goes away. I'd put my money on the cable or a loose cable connection.
May 13, 2009 | Westinghouse 22" Widescreen LCD Flat Panel...
Pixeled picture, Red color, blurry and smeared images
Ghost image and snowy colorful pixelation with vertical black bars? You can try a hard reset by unplugging the unit completely for 4 hours. However you may have a prob with the YSUS and the YBU-L (YBuffer Upper-Lower.) Perhaps even the Logic Main may be defective. If you are still under warranty take it to a service center ASAP. If not Get out your Voltometer. You can email me for some help...
gysgt2u1@yahoo
May 08, 2009 | Philips Televison & Video
We are getting ghost images and the color is not correct
I have red concave lines going across the screen, plus wording appears double like a ghosting effect, this is ongoing from the time the tv is turned on until it is turned off. This started 3 days ago. Is it time for a new tv, its 9 or 10 yrs old now.
Mar 29, 2009 | Hitachi 43UWX10B 43" Rear Projection...
Ghost Images - Pastel colored images
There are 3-4 issues in here,one of them might be a bad convertion part in there. It is not worth your time and money to guess the issue,if it is under warranty,you should take it back.If not,repair tech. would be the way to go!
solutiondoct
Nov 07, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Hitachi 43F300 43" Rear Projection Television Logo
113 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
