Question about Pioneer AVIC-F900BT Car GPS Receiver
Connection passcode for Bluetooth - Pioneer AVIC-F900BT Car GPS Receiver
    Guru:
  • 395 Answers
Pin (pass key) should be 0000 (4 Zeros) or try 1111, 1234, 9999
Posted on May 06, 2010
Cant pair device without passcode
Hi, to set up Bluetooth on your phone
1. Go to Menu, select Connect or Connections or Connectivity:
Note! If the above steps do not work, please consult the user manual.
2. Bluetooth - Select On to enable Bluetooth.
3. My telephone's visibility - Select Shown to all if you want your device to be found by other Bluetooth devices. If you select Hidden, your device cannot be found by other devices.
4. My Bluetooth name - Define a name for your device. After you have activated your Bluetooth service and changed My phone's visibility to Shown to all, your phone and this name can be seen by other Bluetooth device users.
Sending data via Bluetooth
If your phone supports the Bluetooth 1.1 specification or earlier, you can only have one Bluetooth connection running on your phone at any one time.
1. Select or open the file you wish to send. For example, to send a photo to another device, open the Gallery application.
2. Select the file you wish to send, then select Options > Send > via Bluetooth.
3. The phone starts to search for devices within range.
Devices using Bluetooth technology that are within range will appear on the display. You should see a device icon, the device's name, the device type, or a short name. (A paired device is one where a Bluetooth connection already exists between your phone and the other device.)
• To interrupt the search, press Stop. The device list freezes and you can start to form a connection to one of the devices already found.
If you have searched for devices earlier, a list of the devices that were found previously is shown first. To start a new search, select More devices. If you switch off the phone, the list of devices is cleared and the device search needs to be started again before sending data.
4. Scroll to the device you want to connect with and press Select. The item you are sending is copied to Outbox and the note Connecting is shown.
5. Pairing (if this is not required by the other device, proceed to step 6.)
• If the other device requires pairing before data can be transmitted, a tone sounds and you are asked to enter a passcode. • Create your own passcode (1-16 characters long, numeric) and agree with the owner of the other device to use the same code. This passcode is used only once and you do not have to memorise it. • After pairing, the device is saved to the Paired devices view.
6. When the connection has been successfully established, the note Sending data is shown. Data received via Bluetooth can be found in the Inbox folder in Messaging. Tip: Pairing is a means of authentication. The users of the devices using Bluetooth technology should agree together what the passcode is, and use the same passcode for both devices in order to pair them. Devices that do not have a user interface have a preset passcode.
Checking the status of the Bluetooth connection
• When the Bluetooth icon is shown in standby mode, Bluetooth is active.
• When the Bluetooth icon is blinking, your phone is trying to connect to the other device. • When the Bluetooth icon is shown continuously, the Bluetooth connection is active.
Receiving data via Bluetooth
When you receive data via Bluetooth, a message alert tone is played and you are asked if you want to accept the message. If you accept, the item is placed in the Inbox folder in Messaging.
Disconnecting Bluetooth
A Bluetooth connection is disconnected automatically after sending or receiving data.
The phone will search for a couple seconds. If your headset is in paring mode, it will show up on the phone either with the name of device or something like this [unknown headset] or [b2.c3.f4.56.a1] (called a MAC address).
Either way, select it, and hit OK.
The phone will now ask you for a "Pin" or "Passcode", which is a 4 digit number. Headsets will ALWAYS have 0000 (four zeros) as a pin or passcode. I have never encountered a headset with a different number as a passcode. I have been in wireless for 10 years, and still have not found a headset that has any different numbers.
Enter these four zeros and select "OK"
Hope that helped...
Thanks for using fixya...
Feb 07, 2011 | Cell Phones
How to on or off bluetooth on w508i. even how to change setting of bluetooth
Hi, To set up Bluetooth on your phone
application.
Hope it helps .
Fill free to pass your comment.
Jan 08, 2011 | Sony Ericsson W508i Cell Phone
Acer Extensa 4630Z passcode for bluetooth
Passcode is the temporary code for wireless devices when pairing with each other to establish a secure connection. You can assign any numbers or codes you like for the connection to take place. Suppose when you are asked to enter the passcode, enter 123 on the computer's passcode box and then same 123 on the cellphone. It'll automatically accept, but you need to assign the passcode everytime you connect the devices (as I've mentioned for once connection only).
You can assign any numbers or letters as passcode, but it should be set the same code on both the devices.
Good luck.
Thanks for using FixYa.
Jul 12, 2010 | Acer Computers & Internet
I need the passcode for my aeon smartduo bluetooth
Check the manual that came with your aeon smartduo bluetooth device, it should have a section that shows how to connect to other devices and if there is any passcodes that need to be entered on the connecting device in order for a connection to be made.
A common code for bluetooth passcodes is usually 0000.
Hope I was of any assistance,
Cheers :)
Apr 22, 2010 | Cell Phones
I have a bluetooth sgh-E251 and lost the passcode, is it possible to re-set the bluetooth?
Try the default passcode for many devices that is 0000, this could work for you. Much headsets have the same default passcode that is 0000. Remove the pairing with the device prior to make a new connection.
Feb 27, 2009 | Nokia Radio Communications
Forgot my passcode for my bluetooth
base on my experience on using the bluetooth on any mobile phone.. there is no permanent passcode in it.. you can set any passcode everytime you make a connection to another phone.. if someone you know sent you a file thru bluetooth the connection will ask a passcode from then you type any passcode then make sure you tell the sender what password you set on your bluetooth to make the connection..
Sep 23, 2008 | Motorola Cell Phones
Bluetooth passcode
When pairing two phones, you need to set up the connection on both phones. One will ask you to enter the password when you are creating the new connection, which you will then need to enter on the second phone to complete the connection. This ensures that only people you allow to connect (people you gave the code to) can connect to your device.
As for pairing your headset, try this link:
http://www.phonedog.com/cell-phone-research/blog/how-do-i-pair-my-bluetooth-headset-to-my-phone.aspx
Jun 11, 2008 | LG VX9400 Cellular Phone
IT is actually a problem with the phones Bluetooth acessory
The passcode for your Prada HBM-510 bluetooth headset is '0000'
Feb 09, 2008 | LG Prada KE850 Cellular Phone
Pioneer AVIC-F900BT Car GPS Receiver Logo
114 people viewed this question
Top Pioneer GPS Experts
David Burbee
David Burbee
Are you a Pioneer GPS Expert? Answer questions, earn points and help others
