Question about Homelite Consumer Products Backpack Blower/Vac, Carb
Ajust carborator which scruew to adjust idal speed which screw toadjust high speed ke.lee@embarqmail.com
  • 169 Answers
H = high speed l=low speed
Posted on Nov 18, 2009
My generator runs at too high a speed
screw anticlock wise speed regulater on the carborator
May 10, 2014 | Champion 3500/4000 Watt Portable Generator
Echo LT-200P Weed-eater Carborator problem
1. Carb is dirty and should be cleaned correctly
2. low speed/high speed carb screws incorrectly adjusted
3. incorrectly put together or rebuilt
Jan 21, 2013 | Garden
PLEASE, Need carborator. Lo/hi adjustment for Mac #600038-20 18" Chain Saw
Hi mkyhl...
Before you remove or try to adjust your low and high speed jets you should always count the number of turns it takes to lightly seat the idle mixture screw and high speed needle adjusting screws.
Be sure to write the number of turns down on a piece of paper so you will know how many turns from the seated position to open the jets when you go to reinstall them, or if you remove them for cleaning or replacement.
If you have aready tried to adjust them then the adjustments below should get it running for you for final adjustment when warm.
Normally you will adjust your idle jet to 1/2-3/4 turn open from the bottom seated position.
Then you will re-adjust the low speed of the engine when the engine is warm by turning the idle screw in or out till the engine runs smoothly at idle speed, around 1200 RPM.
The high speed jet is adjusted to 1 1/2- 1 3/4 open from the bottom seated position, after the engine is warm.
Then re-adjusted by turning the High Speed jet adjustment screw in or out till the motor runs smoothly at high speed.
Alway use the "lightly seated" method if you have not changed the screw settings.
Please take time to rate me
Sep 05, 2011 | Garden
Homelite st100 string trimmer carb ajustment with one ajustment highe and lowl
Hi lloydlavalla...
Free Answer...Please take time to rate me
Jun 07, 2011 | Homelite Garden
Fuel mix and slow/fast running jet ajustment Dolmar sach 119. starts easy wont pull under load.
Set both the high and low speed screws from lightly seated to 1 1/4 turns out. This will give you a rough setting that will allow the saw to start and idle. Set the idle screw to where the chain just stops moving at idle.
With the saw warmed up adjust the low speed screw out until the saw smokes a bit and acceleration is sluggish. Bring the screw in small steps until the hesitation is gone from the acceleration...you may need to adjust the idle again after this.
Now hold the throttle wide open and while it is wide open adjust the high speed screw in until the noise becomes smooth and the saw "sings". Do not leave it at this setting as it will burn down in short order. Once the saw is singing back the screw out until you can hear the saw's tone "roughen"....then back the screw out a tad more for good power / fuel under load.
That's it in a nutshell...here's a good link also...
http://www.youtube.com/watch?v=3Lw0pJcEPYo&feature=player_embedded
Dec 08, 2010 | Garden
How do you adjust the carborator
If this is a late model saw, the adjustment screws have 'D' heads that need a dealer-only 'D' screwdriver. If the screws have slotted heads, then turn both screws CW to stops (lightly), then back each 1-1/2 turns CCW. This is a basic setting, so the engine should start and run. Start the engine and allow to warm up, then pull the throttle full on. Turn H CW until the engine speeds up, but still 4-stroking. When properly adjusted, the engine should 4-stroke, but immediately 2-stroke when cutting. Allow to idle and adjust L CW for fairly smooth running, yet allow the engine to 'follow the throttle'. Adjust idle speed screw to stop the chain from turning, yet the engine keeps running. Hope this helps!
May 20, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
How do i adjust the idle speed on my 2003 crf450r?
there should be a big aluminum screw that is on the side of the carburetor turn to the right is higher idle to the left or counter clockwise is lower idle
Apr 04, 2010 | 2005 Honda CRF 450 R
How to set carborator adjustment on Poulan Wild Thing 2375?
hello,the starting point for adjustment screws is 2 turns out.turn in til lightly seated so as not to damage them. there are 2 or more style carbs used on saw,some have plastic caps that need to be removed(a small metal screw used as a corkscrew or pry off) or you need a special tool -splined.set high spped til runs good and back off an 1/8-1/4 turn so you dont burn it up. fine tune low spped so it accelerates when trigger squeezed and re check high speed adjustment.single screw is for idle spped-raises or lowers-if chain turns while at idle back off screw.
mowerman33@verizon.net
Oct 05, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
My eager ****** chain saw will not stay running ?
The 3 adjustment screws are Idle, high and low.
First figure out which screws are which adjustment. Tighten the screws then turn them 1 full turn.
Then start the saw and get it warmed up. Work on the high adjustment. This does take a little while. after you get the saw running at high speed work on the low speed.
Apr 25, 2009 | McCulloch MC1275 Steam Vacuum
Need high and low ajustment procedure
Hi carlayoung
Start the engine and turn the high speed screw "H" in(clockwise)until the engine starts to slow down(the fuel mixture is to lean,not enough gas).
Slowly turn the screw out(counterclockwise)until the engine begins to run smoothly,keep going very slowly until the engines just begins to run rough again(rich condition,watch for black smoke from exhaust).
Then turn the screw in again(clockwise) to a point about half way between lean and rich condition.This is the properly setting.
The low speed screw"L" adjust in the same manner.
The idle speed "T"adjust accordingly.
best regards savumihai71
Dec 14, 2008 | Echo 30.1CC Chainsaw With a 14 In.bar and...
Homelite Consumer Products Backpack Blower/Vac, Carb Logo
140 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
