Washer will not spin out after wash. Gives a code 02. Model GHw9300 PWO
Thank you for your response. We solved the problem. There were two of the new softener, he soap pads caught in the pump area. So much for using these ever again. I guess He machines have a problem with stuff getting into this area. My daughter's machine broke because of a pair of panties getting stuck. Wonder how they are getting out of the tub?
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin the door will be unlocked after 3 minutes.
Potential Causes
• Check wire harness connections between the Drive Motor/Tachometer and the Motor ControlUnit (MCU), and between the MCU and the Central Control Unit (CCU)
• Check the Drive Motor • Check the MCU • Check the Wire Harness
