Question about HP DeskJet 5550 InkJet Printer
Slot to insert the new transfer kit does not come forward. seems to be stuck straight up. How would i release it so i can insert the new transfer kit. the right side socket is still loose and goes up and down. just seems that the left side is stuck straight up.
  • 2 more comments
  • gary798 Nov 18, 2009
    its the front end of the printer unit, a very large piece. after x amount of prints it has to be replaced. very simple, clicks out, new one clicks in. the left hand socket just seems to be stuck straight up so i cant insert the stem of the transfer kit into it.
    how long will i have to wait in order to receive an answer?
    HP 5550DN
    slot to insert the new transfer kit does not come forward. seems to be stuck straight up. How would i release it so i can insert the new transfer kit. the right side socket is still loose and goes up and down. just seems that the left side is stuck straight up.
    I understand how to replace the transfer kit. but that is not the issue. the issue is the left hand cup recepticle that the transfer kit slides into seems to be stuck straight up. unlike the right hand cup that i can pivot forward to receive the new kit i can not do with the left hand cup. is there a button so that I can release the left hand cup so that it can come down and face out so i can slide the new transfer kit into it and snap it in.
The left cup is not rotating down because it is fixed by a pin to the left metal axle. There seems to be a mechanism on the left of the metal axle that keeps it from rotating towards the front.
I got the left cup to come down by shaking the cup and axle left and right while simultaneously applying gentle pressure to get the cup to rotate outwards toward me.
Posted on Oct 25, 2012
  • 15,935 Answers
Please explain "transfer kit"
Posted on Nov 18, 2009
  • HP Master
  • 19,396 Answers
Hi.
Try grasping the transfer unit with two hands on the side , after ensuring that the handle had been released, and try to remove the transfer unit out, do not force it in.
After removing transfer unit follow instructions on service document below to install new transfer unit without risking to damage the printer.
Instructions will start at page 67:
http://www.partshere.com/Models/C9656A/CLJ_5500%205550Installartion_n_configuration.PDF
Regards.
  • Ginko
    Ginko Nov 18, 2009
    Re: " left hand cup recepticle that the transfer kit slides into seems to be stuck straight up."
    I know, that happens only when you jump part of the procedure or do it in a wrong way, usually because you did not released both blue locks at sides of transfer unit.
    Now that the mess is done you have to play with the unit until it comes out , do not push it inside.
    The operation is quite practical, and there is not much that I can do from here. If the locks at the sides went already inside the rail and one is not unlocked, then you may be in troubles.
    When it is free do again the procedure, this time follow the document I gave, or the manual.
    Regards
How do you change a jig saw blade
At the front, above the blade, is a finger slot. Insert finger and pull forward. Blade will be released. Insert new T blade and release finger.
Apr 24, 2016 | Dewalt Saws
How to insert MicroSD Multi SD Kit into mobile
our micro sd multi kit will have the smaller micro sd card mounted on the bigger adapter.what you need to do is unlock the micro sd on the side by moving it forward or backward.once you have done that you can take the smaller micro sd card out and this card will fit exactly into the card slot of your mobile phone.
Jan 14, 2010 | Cell Phones
Can not remove sd card from storage expansion slot
Push the card in just a bit until it clicks, then it should release unless it is stuck. Sometimes this happens with new SD cards until they are inserted and ejected a few times.
Mar 21, 2009 | Acer Aspire One Netbook 8.9" Notebook
Micro SD card stuck in cell phone slot
Not other than pushing it in. Make sure the case isn't separating/splitting near the microsd port.
Best way to get it out is with tweezers.
I hate it when cards get stuck.
Hope this helps,
Simon.
Nov 15, 2008 | LG VX8300 Cellular Phone
Installing a Transfer Kit
i got this info from www.partshere.com site - they have most service notes for hp printer and sell most hp parts, including maintenance kits. I hope info. bellow is helpfu.
Replacing the transfer unit
Replace the transfer unit when the printer control panel displays REPLACE TRANSFER
KIT
. The image transfer kit contains a replacement transfer unit for this printer.
WARNING! Remove any jewelry or any other metal items from your body to avoid electric shock.
1. Lift the front door handle and pull down the front door.
2. Grasp the right blue handle. Press and hold down the blue button. Slightly lift the right
side of the transfer unit.
3. Grasp the left blue handle and lift to remove the transfer unit from the printer.
4. Using handles, remove the new transfer unit from the bag. Use the blue handles on both
sides to hold the transfer unit.
5. Place the new transfer unit on a flat surface. Remove the orange shipping locks.
6. Guide the left side of the transfer unit into the front door of the printer. Insert the two
pegs on the left side into the holes, and then lower the right side into the door.
7. Make sure that the blue button on the right blue handle has released (popped up). If the
button has not released, grasp the right blue handle and pull the transfer unit toward you.
8. Firmly close the front door.
9. After the front door is closed, after a short time, the printer control panel displays the
message NEW TRANSFER KIT.
10. If the message NEW TRANSFER KIT does not appear, you must reset the transfer unit
count. To reset the transfer unit count, go to step 11.
11. On the printer control panel, press to highlight YES, and then press to select it. The
transfer unit count is reset, the printer recalibrates, and then the printer is ready to use.
NOTE If the old transfer unit was not at end-of-life when it was replaced (for example, if it was
damaged), the transfer unit count must be reset using the printer control panel.
Replacing the transfer unit when it is not at end-of-life
If you replace the transfer unit when it is not at the end-of-life, for instance if it is defective,
you will need to reset the transfer unit count and then calibrate the printer, through the
control panel.
To reset the transfer unit count, do the following:
1. Press MENU to enter the MENUS.
2. Press to highlight Configure Device.
3. Press to select Configure Device.
4. Press to highlight RESETS.
5. Press to select RESETS.
6. Press to highlight RESET SUPPLIES.
7. Press to select RESET SUPPLIES.
8. Press to highlight NEW TRANSFER KIT.
9. Press to select NEW TRANSFER KIT.
10. Press to highlight YES.
11. Press to select YES.
To calibrate the printer, do the following:
4. Press to highlight PRINT QUALITY.
5. Press to select PRINT QUALITY.
6. Press to highlight CALIBRATE NOW.
7. Press to select CALIBRATE NOW.
8. Wait for the printer to calibrate.
The transfer unit count is reset and the printer is ready to use.
see pictures on link:
http://www.partshere.com/Models/Q5990A/CLJ_3550%203500%203700Installation_n_config.PDF
Apr 18, 2008 | HP Color LaserJet 3500 Printer
Just stopped playing CDs
Hi in most cases the mod kit will fix the problem. other wise its a new unit as Blaupunkt only supply the mod kit or a new mech...
please see: http://carradiospares.co.uk/repair-8619001490-p-256.html?osCsid=b7ce3a0b7b492ec864e29579ad046166
Regards
Mark
Nov 26, 2007 | Blaupunkt IDC-A09 5-Disc CD Changer
Reverse only?
I too just aquired a husqvarna viking 6030 that was stuck in straight-stitch reverse. No forward, no zig zag, no button hole, no cam stitches. I also suspected a broken spring, since the reverse button was slack and had no resistance. But after inspecting every moving part, I realized it was just stuck from many years of non-use. I finally got it free today! I had used some Tri-Flow oil and applied it sparingly to all moving points (but not belts or motor). I exercised all the buttons and like another poster (either here or elsewhere, not sure) I used my hair dryer to apply heat to the inside of the machine through the cam slot. After you remove the white cover on back of machine that holds the two spool spindles, you will see a formed aluminum part just behind the reverse dial that has a rounded-pointed protrusion which sort of looks like a fat flat head screwdriver. It is supposed to travel in an up-down motion when reverse button is pressed. I used a flat head driver to coax its movement, and once it began moving, I continued with heat and drops of oil. Good luck.
Nov 11, 2007 | Husqvarna Viking 1
Bose Lifestyle 30 6-cd changer magazine manual release?
hi, you can release the magazine by inserting a small flat head screwdriver in the slot and pushing the lever towards the back of the unit, this will release the cd but only if ther is not one stuck in the player as it will remain halfway between the mag and the cdplayer. don't force it to comae out. remember to obviously have the dorr to the player open before you try this.
Jul 29, 2007 | Bose Lifestyle 30 System
HP DeskJet 5550 InkJet Printer Logo
522 people viewed this question
Seeker5211
Seeker5211
