Question about Acer Aspire One PC Notebook
My acer one netbook will not let me connect to wi-fi. , it recognises the modem unit but keeps asking for an ip adress, then all it is doing is searching for a network address ?
  • retehina May 11, 2010
    General Problem
    » Hp Laptop's Solution » Compaq Laptop's Solution » Acer Laptop's Solution » Dell Laptop's Solution » Toshiba Laptop's Solution » Asus Laptop's Solution
    » Gateway Laptop's Solution » IBM Laptop's Solution
    Driver Download
    » Hp Driver's Download » Compaq Driver's Download » Acer Driver's Download » Dell Driver's Download » Toshiba Driver's Download » Asus Driver's Download » Gateway Driver's Download » IBM Driver's Download
    terebin6
    Champion:
  • 206 Answers
Go to network connections, right click on the wifi, properties, TCP/IP, set IP and DNS automaticly
Posted on Nov 19, 2009
I rooted my dragon tablet now I don't have an IP address or Mac address so it won't connect to Wi-Fi or ethernet what do I do do
Every connecting device (ethernet port, wi-fi, bluetooth, FireWire port) has a Mac Adress, it's a physical attribute. If it has been erased, it needs to be recorded in the device ROM again...
The IP Adress is volatile, it just needs to connect to a DHCP server on your network (usually your router) to be regenerated.
Apr 29, 2016 | Computers & Internet
Where do I find the IP adress so I may connect manually.
https://wwwimg.roku.com/static/oldlib/roku_player_documents/rokuplayerug.pdf
page 23 change network settings
then page 14 on wi fi settings
if new service provider gave you the encyrption key and has dhcp on then this should start Roku working on Wi FI.
New service provider would have installed a wi fi router this is most likely on 192.168.0.1 or 10.0.0.1 go to cmd prompt type in
ipconfig
then press enter key
Not the default ip address
the router should have a wi fi security option that tells you if the wi fi is encrypted and what ssid is being broadcasted.
DCHP should be enabled Roku will use this to assign itself an ip address once connected to Wi FI.
you need to know routers admin user name and password as well
Apr 18, 2016 | Roku 1
Is it possible to connect a standard DSL modem - without Wi-Fi (with 1 Ethernet port) and a DSL modem - Wi-Fi (with 4 Ethernet port) to broadcast Wi-Fi singles
Does the non wifi modem give out DHCP addresses?
Can the wifi modem be set up to receive it's IP address from DHCP?
If the answer to both these questions is Yes then that's what to do as a first step. Make sure the wifi modem DHCP service is disabled as it must NOT give out DHCP addresses.
Connect the ethernet port of the non wifi modem to one of the LAN ports of the wifi modem and NOT the DSL/WAN port. The wifi modem is not participating in any DSL connectivity at all so it's DSL light will remain off. The non wifi modem is doing the DSL duty so it's DSL light should be correctly illuminated.
May 01, 2015 | Computers & Internet
My connection keep failing my password is correct.they are asking for my ip address where do i find that,
dont give anyone your ip adress,contact your internet provider to fix problem,if you are using someone elses wifi you will have that problem,use your own
Apr 26, 2015 | Amazon Fire TV Stick
Connect motorola modemsbSB6121 to Belink N600 wireless router with out losing internet signal
Step one turn on PC directly connected to ModemsbSB6121 without Wi FI router being involved.
Step two go to Command prompt type in ipconfig (press enter)
Step three note IP address of default gateway and ip address issued to P.C.
Step four type in default gateway address into browser and log into Modem.
Step five look for DHCP Server and allocate IP addresses from at least 50 for example 192.168.0.50 starting ip lease ending ip lease 192.168.0.254
Step six connect Wi Router to P.C. via ethernet cable only - remove ModemSB6121
Step Seven shutdown and restart p.c
Step Eight go to Command prompt type in ipconfig (press enter)
Step Nine note IP address of default gateway and ip address issued to P.C.
Step Ten type in default gateway address into browser and log into Wi Fi Router
Step Eleven Change IP address on Router to 2 as example 192.168.0.2. (it has to match in that modem device would have been 192,168.0.1)
(if it was 10.0.0.1 make wi fi 10.0.0.2 make sure subnet mask is the same like 255.255.255.0)
Step twelve Change DHCP Server to off
Step Thirteen may need to set default gateway to MODEM IP address for example 192.168.0.1
Step Fourteen plug modem router into Wi Fi router may need to plug into WAN port on WI FI router .
Step Fifteen shutdown and Restart Computer
Step Sixteen go to Command prompt type in ipconfig (press enter)
Step Seventeen type in PING 192.168.0.1 (if this is modem IP address and default gateway IP addess)
All this above is to avoid IP address conflicts or mismatching
Subnet mask should be 255.255.255.0
either it uses 192.168.0.1 or it uses 10.0.0.1 make sure Wi FI router is set to different address to Modem Router.
I suspect either a clash occurs or your P.C gets a different IP range from ther WI FI DHCP server.
Happy troubleshooting !
Sep 16, 2014 | Arris Sb6141 Surfboard Cable Modem Sb 6141...
Talk talk, technical assistance
How did you connect the computer to the router. If you are using a DSL modem it will have a DHCP server in it that is allocating IP addresses across your network. If you added the router to the computer via a hub or network switch what is the computers ip .
address. Remove the WI FI router - turn off P.C and then Go to cmd or dos prompt if windows based system and type in ipconfig and press enter to see if ip addresses are 10.0.0.2 if they are your dlink router uses 192.168.0.1 so you need to make the dlink router ip addressand subnet setting to match the Modem ip addresses of the DHCP server. Change the ip address of the dlink router to be 10.0.0.2 and change the modem to allocate DHCP IP addresses from 10.0.0.10 to 10.0.0.255. Only do this if IP addresses are 10,0,0,1 to 10.0.0.,254 on the desktop p.c with the dsl or cable modem connected.without the router being involved. (you may need to ask the ISP what the user name and password is of the modem and it should be ip address xx.xx.xx.1 so type this into a browser to change the modem settings. 10.0.0.1 or 192.168.0.1 just remember if the modem is 192.168.0.1 so is the Wi router from d-link and you will have an ip clash problem)
. How do you do this by ethernet connection from only the desktop directly with only the Wi FI . router. Go to a internet browser and type in the URL 192.168.0.1 and then change the router ip address to match what the DSL modem DHCP issues..
Page 14 of Router instructions see http://files.dlink.com.au/Products/DIR-615/Manuals/DIR-615_C2_Manual_v3.10.pdf
in the manual it states to use a direct ethernet connection for the setup program but you need to be connected to the internet for it to work but if the IP addresses are wrong or clashing will have no internet. You also want to set the modem as the DCHP server and disable the DHCP server in the set up of the wi fi tand set the WI FI router default gateway as the ip address of the Modem. if any DHCP server options in the WI FI router sert to the modem ip address. .
Sep 08, 2014 | D-Link D Link Dir 615 Wireless Router...
Wi-fi not obtaining IP address and if turn off wi-fi can not get to turn back on
Assuming you're trying to connect via wireless router. If you connect, but then aren't able to get to the Internet. I would something is wrong between the router to the modem to the wall (DSL/Cable modem) rather then your tablet device. You can connect your device to your router and you device will show it has a wifi connection, but beyond the router something may be amiss. Try seeing what you get from another device like computer or laptop. That might get you closer to your actual issue,
May 31, 2014 | Coby kyros Tablets & eReaders
Finding router ssid
The SSID is not an indication on a label on the Wi-Fi device, it is the identifier broadcasted by the device ; to find it, two possibilities :
1) if you remember its password, access the setup of the wi-fi device (your router) ; this is done thru any computer connected to the router : simply enter the IP adress of the router (try 192.168.0.1 or find the right one using the ipconfig command) in the browser, and navigate to the wi-fi settings.
2) if you can't access the router, go to the wi-fi settings of your smartphone or tablet or netbook, and find he way to show the list of the access points available in the surrounding - yours is probably the first one (the stronger signal) in the list.
Good luck.
Oct 22, 2013 | Samsung Tab Tablets & eReaders
Having troble connecting to internet, an it has to do with the computer
try to turn off your wifi button then turn it on after 1min. or go to network connection and check your ip, it should be obtain the ip address automatically.
Sep 29, 2009 | Computers & Internet
Psp connection to internet
You probably have your wi-fi under secured network.
Oct 02, 2008 | Video Game Consoles & Games
Acer Aspire One  PC Notebook Logo
112 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
