Question about Vizio P50HDTV10A 50 in. Plasma HDTV
I have a single blue line that goes up and down the whole screen. I tried in the menu section to clear the screen but bar is still there.
  • mcarthurfami Nov 18, 2009
    its plasma not lcd
  • 834 Answers
Sorry to say you have a bad LCD panel hope it is on warranty
Posted on Nov 18, 2009
  • Dave Naylor
    Dave Naylor Nov 18, 2009
    you can try to clean the connection on the lvds cable located going from the large maonboad to the smaller board on the top of the lcd screen be carful the connector are very very fragile if this doe not take carew of this you will need a new lcd panel big buck
  • Dave Naylor
    sorry about that ok check all the connection along the top and sdes on the plasma panel reseat all connectors if possible
I have a single vertical blue line on my 50CT Libretto screen. It does not show on an external monitor. Any ideas what's causing the blue line if it can be fixed? Thanks Mike H
Just a bad screen. There's not a cost-effectve fix for these things due to the age of this laptop and on top of that, these screens were incredibly rare even when they were first sold. If you must replace it, then your best bet would be to hunt down a whole unit (eBay would be your best bet) - it might take a while but your target price should not be over $20 delivered. That'd be your best bet.
Sep 08, 2011 | Toshiba Libretto 50CT Notebook
I have a samsung 52"
The whole screen or what is called the panel will need to be replaced. the panel comes with all the circuit boards less the power board and main board.
Aug 31, 2011 | Televison & Video
My other computer, G4 Macbook Pro, has a screen issue. When it is turned on and in process of coming up, the screen shows large sections of odd colors such as light pink or light green or light blue. Then...
Connect an external display to the computer. If the lines and distortion shows up on the external display its the video card, which is attached to the logic board. So, the whole logic board will need to be replaced.
If the lines and distortion don't show up on the external display the issue is the LCD module, which will need to be replaced.
Jan 30, 2011 | Apple PowerBook G4 Mac Notebook
Tune in channels
Switch TV on
Press “MENU” on remote until 3 blue arrows appear
Press “VOLUME” keys to tune up or down (shown on blue bar)
When required programme is tuned, input required Channel number (appears on 2 green lines at top) e.g. 02 or 14
Carry on tuning and allocating channel numbers
Select “MENU” to clear or wait until it clears by itself
Channels should now be tuned to allocated numbers
Feb 21, 2010 | Televison & Video
Single Blue vertical line appeared on the sanyo 42'' LCD screen
vertical ic fult or vertical section supplys missing
Jun 12, 2009 | Sanyo Televison & Video
Mitsubishi WT-42413 Blue Green and Red Line
there is a section in the tv working just to keep the screen fitting top to down (vertical section) some capacitors are dry now in that area. this one has not to be a expensive job in the workshop. Try estimates
Apr 14, 2009 | Mitsubishi WT-42413 42" Rear Projection...
VIZIO P42hd PS42a plasma Picture has two vertical lines (one red/orange, one blue) going down the right-hand side of the screen. Lines are clearly visible
The panel is almost certainly bad. The only fix for this is to replace the whole panel which would cost more than the whole TV.
Mar 30, 2009 | Televison & Video
Black bar
On a non H.Def plasma, there is a PCB that runs along the bottom of the screen that is attached to the screen by a several brown/gold colored flat ribbon cables. I've seen where this ribbon cable is not seated properly in the jack. The ribbon cables are generally responsible for that section of the screen. Next possibility is the PCB itself is defective.
Not to scare you, but the plasma screen itself is a possible suspect.
Jun 25, 2008 | Zenith P42W46X 42 in. Plasma EDTV
Thin blue line
I am a Sharp Servicing Technician. You posted this before. Ive got the same model TV as you do LC46D62U. I think the line you are experiencing is simply the broadcast. I notice it on some HD shows that broadcast the side bars. (Always on the Ellen Degeneres Show). Ive taken some picture.
1) Here's the line on the left that i experience
2) Later on in the broadcast, it goes away.
One way to check if its a TV problem or not. When the line shows up again, hit the MENU button on the remote. If the line appears to be "behind" the menu, then it is simply the broadcast.
If the line appears to be "on top" of the menu or shows right through the menu, then it is a TV problem.
Im thinking the reason it takes hours for hte line to appear is because it only shows up on certain shows or certain HD broadcasts.
Mar 27, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Vizio P50HDTV10A 50 in. Plasma HDTV Logo
106 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
