Question about Olevia 237T 37 in. LCD TV
My TV fades to black, then comes back to the picture
  • Olevia Master
  • 3,866 Answers
This would be due to a bad inverter or a inverter going out the inverter controls the backlight of the tv and when the back light goes out you cannot see the lCD do its job on the screen. So check the inverter and the backlight on this TV you be glad you did.
Thanks and please do leave postive feedback and ratings for your free answer today.
Posted on Nov 18, 2009
  • 834 Answers
You have a bad cap in your power board these can like deivces will be puffed on the top the values will be on the side of the unit
A tv picture that is freezing than immediately fades to black?
Check to make sure that off the air broadcast (not cable) is having same symptoms. A good chance main board is the problem. If it is less than 12 months old, contact Samsung for warranty service.
Oct 19, 2015 | Samsung UN60EH6003F 60" LED TV 1920x1080,...
The color on my Advent TV fades in and out of the picture, and goes to black and white Why
The problem is in the picture tube board circuit. Sometimes the CRT socket doesnt connect well to the CRT pins. Or maybe there have bad solders from RGB transistors. check those transistors, Also the bad thermistor discolored the entire tv screen.
Sep 29, 2014 | Televison & Video
Picture fades to black
Find the vertical IC and check for very small cracks on the solder joints of its pins and resolder (approx. 10 Pins). Also check in the same area for a 1 micro farad at 50 vdc capacitor that goes bad and replace it.
Dec 18, 2013 | Toshiba CX32F60 32" TV
Sony KPR-53EXR15 pictures fades in and out
Sounds like possibly it could be connection related between any AV/Cable ports. Worst case would be the capacitors of the motherboard leaking. It's possible to fix anything. Just make sure you have the knowledge and the right equipment.
Mar 31, 2017 | Televison & Video
I have a Vizio 37 inch lcd tv. It works fine from
Hi msyaros
In order to have data`s specific to model , i would need the model# written on the back of the tv set.
Be waiting for your reply
Jan 31, 2010 | Vizio VX20L 20 in. LCD TV
Picture fades to black then reappears and repeats fades to black .
Is the sound ok. Yust the Picture. If both dissapear replace power supply board. That is the main big board with the most heatsinks on it. Main power gos from a switch board to main power supply.
Nov 21, 2007 | Vizio P2 42 in. HD-Ready Plasma Television
Panasonic PT-47WX49E
The only thing I can think of that would make the picture fade to black is a loose solder joint on the filament supply. Each of the 3 picture tubes has a filament and if the 6.3 volt supply to those filaments is suddenly lost, the picture fades to black as the filaments cool down. An experienced tech can find and correct this for you quite easily.
Sep 10, 2007 | Panasonic PT-47WX49 47" Rear Projection...
RCA 32" TV - Model #32F531T - Faded to black
Isolate filament voltage from CRT,i.e. unplug Crt socket from pix tube.Measure filament voltage on CRT PCB.If present,suspect bad pix tube.If missing,solder any/all connects in filament circuit,meaning CRT board first then main PCB.
Aug 08, 2007 | RCA 32F531T 32" TV
Picture faded to black, came back, faded again and had stayed black.
It seems your set has a loose conection in the high voltage circuits,in fact by now it should have many loose conections in different areas like the power supply and the horizontal deflection circuits,if you are familiar with tv service you can use the information as the first step to take,some of the loose conections are hard to see even for the trained technician but the one giving you this problem should not be hard to see,if you are not too familiar with tv service be safe and call for assistance from a servicer a least for an estimate.
Oct 11, 2006 | Mitsubishi CS-40507 40" TV
Olevia 237T 37 in. LCD TV Logo
407 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
