Question about Pioneer DVD 105S Internal DVD Drive
Disc not releasing and stuck inside - Pioneer DVD 105S Internal DVD Drive
  • 86 Answers
No problem ,in drive a band which use to releasing slider may broken or dis placed.so i recmend that if the drive is not in warrenty , then get it repaired by a responsible person
Posted on Nov 19, 2009
The back brake locked up and released what is wrong with it how do I fix it
It could be the springs inside the drum, could be rusted and stuck or broke, take your tire off and pull your brake drums
Nov 25, 2014 | 2003 Subaru Forester
Stuck disc in Macbook pro
CD and DVD drives have a manual release.On the door,look for a small hole.You an usually insert a paper clip in this hole to manually release the latch and open the door.
Jul 31, 2012 | Apple MacBook Pro Laptop Computer with...
The power on my ps3 does not stay on it powers on then cuts off immediately and the power light keeps blinking red and a bluray disc is stuck inside it will not release the disc
you have a yellow light of death if you look closely there is a yellow flash before it turns red the disc can be removed when its fixed as it needs to be serviced ok sorry to be bringer of bad news :(
Jan 13, 2011 | Sony Playstation 3 (PS3) Console
Left rear wheel will not turn at all and is locked on. The right rear is just dragging. The handbrake appears to have released normally. Car is a one year old small Chrysler - it belonds to a friend and is...
Does the car have drums or disc brakes on the rear? If it has drums then the handbrake lever may not be releasing on the rear shoe itself or a spring or brake lining could have let go and got jammed. If the handbrake lever is the problem then removing the wheel and striking the drum with a large ball peen hammer should release it (may be barbaric but it works), this will not solve the problem the brakes would have to be removed and serviced or replaced depending on the problem. If the vehicle however has disc brakes on the rear then the caliper on that wheel may have become stuck or seized, normally they are replaced nowadays if this occurs since rebuild kits are not readily available. Still with disc brakes could also have stuck pad in its guide on the bracket, although much less likely, also tends to be less costly since you only have to remove and clean it up (rust, etc). If the handbrake is inside the rotor (internal drum), then you could have a problem with the shoes or lever releasing inside the rotor (depending on the setup on the rear). As well if it were not brakes in very, very rare occasions a wheel bearing could lock up, not very likely though. hope this will help you good luck
Mar 01, 2010 | 1997 Dodge Neon
Wont open
ok This is a failure inside the system and can be cause by the disc being stuck in an okward position you can open by turning of your console from the back and opening up your PS3, DON'T DO THIS IF YOU HAVE WARRENTY, if you dont have warrenty open up ur ps3 and release the jammed disc but if you have warrenty dont do anything just send it away to get repaired
Feb 06, 2010 | Sony Playstation 3 (PS3) Console
It won't eject - disc comes oout just a little bit
I am not sure exactly what kind of computer that you have but on almost every cd/dvd/ etc drive that I have ever seen there is a manual eject hole. It is usually located on the faceplate of the drive somewhere. It is literally about the size to allow a pin(like a safety pin) to fit in. Insert the pin into the hole and pish gently until you feel it hit the release mechanism. At this point it may require a tad more force to push the pin more but once that mechanism is released , the door should open atleast enough for you to pull it (gently) the rest of the way and retrieve your disc that was in there.
I have had this happen before...somtimes all those little gears get stuck and after the manual eject they work fine, and sometimes I have had to replace the drive because the gears(theres tons of them) inside are stuck or broken.
Oct 23, 2009 | Dell Studio Hybrid Desktop Computer
Disc stuck in machine. took off cover. can see
Find the electrical motor and try to turn it with your fingers, it should move the gears in order to release mechanism. It its stops and no movement, turn the motor the other way.
Sep 12, 2009 | Sony Televison & Video
Something stuck in disc drive of ps3
There is no need to open up the console! Make sure the power is off! Get someone to hold the PS32_bing.gif upside down (so the disc slot is facing down) then get 2 butter knives insert them carefully one on the left and one on the right of the disc slot. Now gently push the knives away from eachother so that the one on left goes left and the one on the right goes right. You will feel them push the brackets that hold the disc in. As you push the brackets you will release the mechanism that holds the disc in and it should just drop out. I did this with mine when my little boy decided to put a credit like card in it!
Jan 10, 2009 | Sony Playstation 3 (PS3) Console
Pioneer 12 disc cd changer in car
Try unplugging the unit and then powering it up again, this will make it reset and could release the disc's if not, you could have a lok inside the unit, see if and discs are half loaded.
other than that, send it off to a repair agent
Mark
www.blueice-electronics.co.uk
Nov 25, 2008 | Pioneer 12DISC CHANGER
Disc stuck in unit
Unplug power cord. Plug back power and keep pressing the eject button repeatedly while the unit starts up. Do this a couple of times, if you succeed in activating the eject before the system starts reading the disk, then it will eject.
If you do not get the disk out in this way, the only alternative is taking the unit apart, and removing disk from inside manually.
Oct 08, 2008 | Gem Sound CDM-150 Mixer
Pioneer DVD 105S Internal DVD Drive Logo
Top Pioneer Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Computer Links
David
David
Are you a Pioneer Computer and Internet Expert? Answer questions, earn points and help others
