We own a JES9800 model of the Jenn-Air Oven. The
We own a JES9800 model of the Jenn-Air Oven. The electronic panel that sits directly behind the electronic control was replaced after having an F1-8 code. Right after it was replaced, we got an F1-7 code. We turned it off and about a week later, it no longer had the code. The problem is that now several of the pads on the electronic control face don't work- auto set, numbers 8,9,0 etc.
  • michelle_avo Nov 18, 2009
    I don't understand what an oad is?
  • 11,896 Answers
Then oad itself is flty and will have to be replaced. Yo ucan get one at repairclinic.com or partselect.com to purchase your touchpad and the manual, diagrams and whatever else you want for it.
Posted on Nov 18, 2009
  • Nate Stansfield
    Nate Stansfield Nov 18, 2009
    The pad itself, the touchpad will have to be replaced.
How do I find the part number for the touch pad of JES9800?
What color is your range? This site, http://www.appliancepartspros.com/search.aspx?model=jes9800&page=2 , lists several control panel assemblies (black, white, chrome) for the JES9800 . Click on the one matches and you'll see the part number. A parts diagram is also available. The number section of the touch pad is not sold separately.
I hope this helps.
(note: the part will have a Whirlpool part number. Jenn-Air is part of the same company and they use the same parts across all of their ranges.)
Aug 19, 2014 | Kitchen Ranges
Jenn Air oven Model: jgs9900bds16 "warming drawer" lights up
If it is not affecting the performance of the machine, disregard it.
Jul 30, 2013 | Jenn-Air Kitchen Ranges
Electronic panel malfunction
A F1 code on Jenn Air refers to a failure in the ERC (electronic range control). There is not a fix for it other than replace the control.
It looks like the part is still around if your model starts with JGR8850 that is. The price of the part is around $300.00 so.... not sure if it would be worth putting that into this, your call
May 08, 2010 | Jenn-Air JGR8850 Gas Kitchen Range
I HAVE A W136C Jenn-Air wall oven and would like a wiring connection diagram. Icant figure where to connect the orange wire
Look for schmatic behind control panel, open oven door and remove 4 screws that hold upper face panel down, panel should slide up 1/2' or so and lift off.
Sep 14, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
Electronic touch panel unresponsive. Clock blinks, but no other commands produce any activity. Model#:JMW8330DAS Serial #:13679516JN Jenn-Air oven. About 2 years old.
Unplug and let sit for 5 min. Replug and set clock time first. Then see if the other buttons work. Electronics sometime need to reboot if it freezes like your computer does sometimes.
Apr 29, 2009 | Jenn-Air JMW8330DAS Stainless Steel...
Jenn air oven
More then likely your electronic clock control board is going bad. After turning the power off, you can also try cleaning the connectors on the clock board and make sure the connectors are tight.
Mar 23, 2009 | Jenn-Air JJW8230D Electric Double Oven
How do i remove a built-in jenn-air microwave?
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here.
If not, try here.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
If the fuse is good, it may be the magnetron thermal cutout (TCO or thermostat) or the oven cavity thermal cutout (TCO or thermostat).
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Jan 05, 2009 | Jenn-Air Microwave Ovens
Jenn-air jmv8000b DOA
The fuse is located in a plastic inline holder behind the control panel.
At our Web site, we have a video available showing how to remove a typicalover the range control panel assembly in under 5 minutes.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO)/ thermal fuse on or near the magnetron or on top of the cavity / bodyof the oven.
There should also be a "mini-manual" (tech sheet) hidden inside the unit behind thecontrol panel or hidden on the left side behind the grille, which isvery helpful when troubleshooting, testing, and locating components.
If you need to check the oven cavity thermostat, you will need to remove the oven from the wall, and If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download Jenn-Air owner's manuals and installation instructions here.
William E. Miller
prototech@usa.net
Nov 22, 2008 | Microwave Ovens
Electronic Display
Go to, fixitnow.com for a cheap fix on these displays. It worked on my jenn air.
Oct 29, 2008 | Jenn-Air JES9860 Electric Kitchen Range
Televison & Video Logo
187 people viewed this question
Top Televison & Video Experts
Electro Med Services...
